My Grundig M400 will not power up with new batteries,the clock works
I installed new batteries 6 different times since yesterday,the clock works but the radio will not power up
SOURCE: Grundig sonoclock 420 radio/alarm
Hello Sally,
here is the solution :)
https://dex.grundig.de/GIM/internet/document/GKL0151D.PDF
maybe it doesn´t work try this site and choose
http://www.grundig.de/index.php?id=9
Greets
miieke
Posted on Aug 12, 2008
  • 4 Answers
SOURCE: setting clock on jvc radio
Hey here is an instruction page for your clock.
http://resources.jvc.com/Resources/00/01/13/LVT1775-001B.pdf
Posted on Mar 01, 2009
SOURCE: Grundig car radio codes
MC761111184851 9.18429-8152 grundig THANKS
Posted on Apr 10, 2009
  • 814 Answers
SOURCE: Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 15, 2009
SOURCE: Grundig yacht boy 400 radio does not work with mains operations
hello i have a grundig mini-300 radio , the volume control is stuck in high range . i have had many problems with this radio , i would love to talk with one of your representives . please call me at 585-313-3188,,thank you ,,,,nicholas ferrara
Posted on Aug 19, 2009
Dewalt service center
The Grundig S350 (DL) runs on one of three power sources: electrical outlet, DD batteries, and AA batteries. There is a switch in the battery compartment that permits to change battery type. I do not know how different the S350 and the S350 DL are, but you should try to find out if it works with any of the two battery types before having it serviced. Clean all contacts of any acid corrosion. Check the manual to see if you have to specify the battery type in the setup too.
Feb 05, 2014 | Grundig Audio Players & Recorders
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
I can't get the radio to work on battery power
What kind of radio is it? If you have the GRUNDIG S350 DL, be informed that that model can use two different sizes of batteries: D and AA. To select the type, there is a switch inside the battery compartmnent.
Aug 12, 2011 | Grundig Audio Players & Recorders
The a/c power wont work. Tried several different
check the power plug used to connect the clock radio to the mains power,if it does not come on.then you have to open the back cover of the clock radio to check for blown fuses, because this are the common problem found in electronics appliances.
Also check the transformer with the use of an ohmmeter, to read if the components are okay.
Good luck.....
May 25, 2010 | Grundig G2000A Clock Radio
My m400 wont start at all, just an orange light blinks at the power light
have you had any power surges lately?
Try taking the battery out of the laptop and starting just on power.
if this doesnt help then take battery and power and leave laptop for few hours then try again on only power or battery.
Let us know how it goes.
Jan 04, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
My Portege M400 will not turn on with the battery installed. It will work if you remove the battery and use the power supply. The power light only blinks yellow while the battery is installed. I have tried...
You look very much the unlucky owner of a busted battery.
I'm afraid the battery will have to be replaced. Meanwhile, do not use it with the power supply; not only it will do no good, as you already determined, but it might damage the power supply itself.
Jan 03, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
My toshiba portege M400 laptop will not start up, when I turn power on the power light starts blinking yellow and does nothing
This happened to me. The computer will not work with the battery in it.
Solution: Take battery out and plug in without battery... It should work,
You will need to get a new battery
Sep 19, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Hello Sally,
Greets
miieke
Jun 21, 2008 | Grundig Audio Players & Recorders
Clock of the computer
This means that the cmos battery on the motherboard is flat and keeps losing time and date and probably the memory settings, this is only a small disc shaped watch type battery CR2032 and can be found on the motherboard, a pc repair shop would be able to do it for you for a small fee.
Jun 14, 2007 | Toshiba Portege M400 PPM40U01000E Tablet...
105 people viewed this question
 Grubhead
Grubhead
