Question about HTC PPC-6800 Smartphone
Mogul Screen black
The phone was wroking fine but then the screen started freezing on me so i decided to turn it off and back on. Well when i tried turning it back on the screen just stays completely black. The buttons light up and the service button flashes but i cant see anything...ay way i could possibly fix this? oh yeah and pressing the reset button on the button doesnt help either.
  • 2 more comments
  • evnoriega Nov 17, 2008
    I'm having the same problem. Thanks for the reset tip...but this is only a temporary fix. I've shut down my phone numerous times and it still reacts the same way. I'm thinking about reflashing my phone to see if it helps :(.
  • Bullitt08 Jan 10, 2009
    Same deal here - it just barely lights up enough in a dark room to see the keys to enter the PIN. Basically useless....
  • rosonowski Jan 19, 2009
    Whenever I press the power button on the side for sleep mode, or the phone otherwise goes to sleep, I come back to a dark screen. The backlight is on, and the device appears to be operating otherwise normally.
    When I open the slide, a chime plays, the phone attempts to change the orientation, there is some visual artifacting (lines mostly), and then it freezes. A soft reset brings me back to the same dark screen.
    I am running the latest ROM as of the time of this posting, 3.5~ I believe, and the issue persisted across the 2.0~, then 3.3~ ROMs I tried.
    I have tried disabling the sprint theme as was suggested elsewhere, but this not appear to make a difference.
    A soft reset will eventually bring the phone back to life, although it usually takes many tries, although trial and error seems to show that it's best to do it right as the phone finishes booting, which is indicated by the red and green "phone" buttons simultaneousy flashing on the bottom of the phone.
    For now I've just set up the phone so it doesn't go to sleep, but this obviously drains the battery quite quickly, and does not resolve the keyboard issue at all. Any help or pointers would be greatly appreciated, I really otherwise like the phone.
  • Anonymous May 18, 2009
    same problem...what did u guys do to fix?
Press the soft reset button located right under the SD mini memory card its a small hole just press there with your stylus (pen)
Posted on Nov 02, 2008
My is get freeze, when people call you, you cannot take their call. and the entire screen go black. then you have to turn the phone off and start again
From the question you wrote, it means that the phone has two problems to be solved:
The freezing of the phone,
and
the black screen display.
What causes a phone to freeze is when the memory of the phone has tampered and has allowed the phone to have memory loss and it will need to be restored for the phone to function normal again.
It can be restored by flashing the phone to restore the memory back.
The black screen is caused when the flex that connects the board of the phone to the front board that enable the screen to be able to display is damaged, it makes the screen of the phone go black.
And it needs to be replaced for it to be able to display again.
After fixing the problem of the phone, the phone will start working properly again.
Have a nice day.
Mar 24, 2010 | Samsung U900 Soul Cellular Phone
My HTC Mogul Smartphone Does not turn on.
i think your phone is pretty much in sleep mode and mine does that also, all i do is press the top small button on the right side of the phone and the screen comes back
Feb 21, 2010 | Cell Phones
My phone is freezing up on the Windows screen. This has happened before but it only lasted for a couple of hours and when I took the battery out & put it back in, it was fine. Not this time, this has...
my phone is doing the same thing. first my mogul wouldn't change views when the phone opened up, its been doing tht for days. today the screen just stopped working. when i picked it up the screen was black and i pushed the button to turn the screen on. i've taken out the battery many times, done a soft reset many times and turned the phone on many nothing is working, does anyone have any suggestions?
Feb 12, 2010 | HTC PPC-6800 Smartphone
Phone will not turn on and red led light flashes
Yep. Take a soft cloth and wipe the 5 or 6 battery contacts, CAREFULLY! Dont use water or cleaners. Put battery back in, dont turn on phone, and let it charge until light turns green. Will likely take several hours.
Jun 01, 2009 | HTC PCMICROSTORE Brand Mogul XV6800...
Hi my sonny ericsson c905 is brand new i started using this phone yesterday and it was working fine. Today it wont switch on and when it does decide to it freezes and switches itself off, and the screen...
i have a very similar problem. ive had mine for 6 weeks, and the other day it started playing up. not all the time but now and again.
the screen goes weird like a very low resolution or goes all lines. when i cancel to the main menu and shut the phone for a min so the screen light goes off or black then re open it goes back to normal. now and again tho it crashes which is a pain. it seems like a software bug, im gonna wait for a software update.
if you havent had long its worth taking back to the shop. especially more so if its frequent!
Nov 22, 2008 | Cell Phones
Computer recieved the blue screen of death but before....
turn it on with a/c and remove battery if it starts normal then the problem is from battery (TRY IT I HAD THE SAME PROBLEM)
REPLY THANKS
Jul 17, 2008 | Sony VAIO PCG-K35 Notebook
Screen becoming blue and flickering white
I fixed this same problem using a registry scanner. Here's a link to a good free one:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hope this helps.
Jul 17, 2008 | HP Pavilion TX1000Z Notebook PC
My phone keeps freezing and restarting
Try pulling out your memory card if you have one. i had the same problem and come to find out my memory card must have come loose from dropping the phone. It's working fine ever since I took i out and put it back in. Good Luck.
Jun 23, 2008 | LG enV VX9900 Cellular Phone
LG cell phone
hi there
hav your phone serviced. that has an issue internal. they might have to replace some chips for that. youve checked the battery and still does the same thing.
hope this helps.
fixya!
Jan 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
HTC PPC-6800 Smartphone Logo
709 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
