Question about Philips HTS3566D/37 Theater System
Do no have 5v stby on board lcp107610-0001
Ic 902 ap3843gm-e1 dont have oscilator the ic i remplace for ap3842b
2 Suggested Answers
  • 476 Answers
SOURCE: RE: Needs the IC # for Location 902
According to the service manual:
IC902 9965 000 29296 IC 8P FSDM0365RN DIP
Posted on Mar 17, 2008
Where is horizontal output ic in my t.v?
There is no horizontal oscillator IC. The horizontal oscillation is generated and outputted by the main system control IC LA76810 itself. Refer some circuit diagrams using LA76810 to get more details about the horizontal oscillation output from the IC. Measure the frequency at that output pin. It should be some ever near 15.62KHz.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the IC number, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Jan 31, 2015 | Televison & Video
I bought a 32' ctgv-3249 series at a aucton and there is no color
Hello
If the picture is correct in black and white mode and sound is Ok, your TVs chroma section is in trouble. At present sets, this section consists of an Ic. That Ic may be not working. There are many reason for which chroma section cannot work. Consult an experienced technican to rectify the trouble. There is an oscillator section inside the chroma Ic which receives its oscillations from an ouside crystal oscillator, usually oscillates at a frequency of 4.43361879Mhs or 8.86Mhz or may differ its frequency according to the circuit designs of that tv. Your technician will detect it and rpace the same if needs. You yourself cannot detect the exact point of fault. It need digital multimeter which can count frequency also.
Oct 15, 2010 | Broksonic TV
Have Ge model 52GW945 tv, it went blank no picture, nothing, I checked fuse its ok what next
Check the swithed mode power supply section. Some sets uses Ics for control the power regulation, while others uses transistors as oscillators and choppers. If the power to the oscillator section of the SMPS is absent, the supply system won't wake up. So many reasons are there. You just check the resistor, usually connected from main DC rectified supply, to energise the oscillator section of the SMPS. In most sets it may be two resistors in serial, usually 270k 1W*2. If any one of this get opened, the power supply will not start up. Check it first and preceed. If the set uses Ic as regulator controller, check the positive supply voltage at the respective pin of the Ic.
Oct 15, 2010 | GE Televison & Video
12.5 HP Briggs starts ok but constantly hunts or oscillates.
check air filter it sounds like its blocked if that dont fix it strip the carb and clean out the running jets with card cleaner dont go poking wire into the jets or you could distroy them
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Nec pf-68v21 pwr led flashing red green after horizontal output
check the supply at horizontal driver trans former ,if voltage is correct at ho/driver trasistor ...then check allthe fusible resistances from power supply,,,if tv is taking h/oscillation for awhile ,,give more screen control in lot,,, & see for a horizontal line ,,,before tv becomes off,,, if so vertical ic problem...
Mar 16, 2010 | Televison & Video
Oscillator out. No radio and clock is locked up
could be a 555 ic. 555 is the widest used timer ic or "clock" chip. you will need to check the gates of this ic.
May 06, 2009 | Car Audio & Video
Turns on but quickly turns off
hi
you have defective power oscillations! in this model you have to replace the vertical output ic. because the power oscillation for Jungle IC is passing by from Vertical output.
Thanks!
Dec 29, 2008 | Sharp 32U-S60 32" TV
Mar 15, 2008 | Philips HTS3400/37 System
ABOUT PHILIPS TELEVISION
The 8V at pin 36 won't show unless there is oscillation, the primary voltage pin is pin 10, 8v. Don't mind me asking, you have checked the B+, right? Because the blinking LED is often because of power supply problems. And if that's okay, desolder the horizontal driver output legs and connect an LED to find if it is oscillating, if it does, forget the ic part and move on with the FBT and things. Good luck.
Jan 31, 2008 | Televison & Video
No eht
Disconnect the horizontal driver transformer output pins and connect an led there to find the it is oscillating, if it does, then it could be the LOT. Try replacing the oscillator ic if there is no oscillation.
Dec 28, 2007 | Televison & Video
Philips HTS3566D/37 Theater System Logo
675 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
