Question about Coleman Heating & Cooling
Coleman echelon 9.t series - Coleman Heating & Cooling
3 Suggested Answers
  • 2557 Answers
SOURCE: coleman echelon 9.T furnace will not turn on. Red light blinking
sounds like it is the pressure switch try jumping it out on some models you fool the heater in too working or see if the tubes are blocked , there should be some codes on the front panel or the fan panel
Posted on Apr 27, 2010
heatman101
  • 43501 Answers
SOURCE: Describe your Problem my coleman Echelon 8V
That pressure switch is not closing... When it senses that the blower is running, through the tubing that makes the pressure switch see a pressure differential...then the switch should close and the ignition process should start...
Check for a blocked or water filled vent...
Check for water in the small hoses going to the pressure switch...
Check for broken wires or a loose connection...
The switch in the pressure switch it's self may have gone bad....
You can often start the furnace by jumpering the pressure switch once the inducer has started...but it must be opened after each cycle for the system to refire...
heatman101
Posted on Nov 29, 2010
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
I have a Coleman Echelon 9.C Series furnace that is blowing cold air. The red light flashes 5 times and the green light is flashing slowly.I had it checked several times by techsbut that can'
This code Signifies that your furnace's ROLL-OUT-SWITCH or auxiliary switch, may be open. This switch can be reset by pushing the center of red button on your furnace roll-out-switch. Make sure the heater has been cleaned out good, make sure the flue is clean, have the service company check to make sure there is not a cracked heat exchange. Call a reliable service company, not the cheapest there is no reason that they can not find the problem unless they are not qualified. If you have had a company out for the same reason and you have payed them to fix it then they have to fix the problem.
Nov 19, 2014 | Coleman Heating & Cooling
Coleman echelon 9.T furnace will not turn on. Red light blinking
Apr 27, 2010 | Coleman Propane Forced Air Heater...
Modulating Gas valve coleman echelon
Can you unscrew the gas valve? If you can unscrew ther valve, repipe
dope it and then tighten it so its in the correct position. If the valve could be serviced in a upflow position then you just have to pretend in your
heade that you are replacing the gas valve. You shouldnt have to flip flop
it end for end. The position of the gas valve probably has no effect on the operation of the unit. It is convienent to be able to see the main part
of the valve. Gas Switch on, 24 volt connections.
Jan 18, 2010 | Coleman Heating & Cooling
I need an owners manual for a Coleman Spa Horizon series 447
Chuck, did you find the manual? If not I have one with my spa maybe I could copy it for you.
Ron
Sep 04, 2009 | Coleman Sport & Outdoor - Others
U-Line CO2175FS-00 Echelon
Depends, if you have the later models, you can able to retighten it a the handle, it is removeable, but if you have the old version, too bad, you have to replace the whole door. You can try to call U-Line at 800-779-2547 to see which one you have.
Nov 08, 2008 | U-Line Echelon (CO2175FS01) Compact...
Heating & Cooling Logo
224 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
