Question about NetGear WGR614 Router
Router connection problems
I have a netgear router hooked to 2 computers, it lets one go on line but the other one does not go on line.
    Novelist:
  • 143 Answers
I assume that you are using 2 hardwired computers. if so, make sure that the cables are connected to the correct ports. the modem should be connected to the wan/internet port of the router and the 2 computers should be connected to the ethernet ports. try to do a power cycle by turning off the all the devices then turn on your modem first, then the router, lastly the computers. if you're getting the same problem, make sure that the router is properly configured according to the settings of your ISP. for example, if your ISP is dsl, you need to set you router to pppoe but if it's cable, you need to clone the mac address of the computer (the one that can access the internet directly to the modem) to the router.
if you're using wireless computers, you need to check if you are using the correct wireless settings to your computer. log in to your router's page to check the wireless settings.
hope this'll help you
ciao!
Posted on Oct 27, 2008
How do I disconnect belkins from my computer
If you're not using the Belkin anymore, unplug it. Removing power from the device will inhibit it trying to take over your network connection.
Jan 20, 2014 | Belkin Computers & Internet
I just bought a laptop computer and I already had a desktop. My internet provider is Hugesnet Satelite. I bought a Netgear N600 wireless dual band router thinking I could just hook it up to my desktop...
The HN9000 should have an ethernet port. You will require two ethernet cables to connect the desktop to the router.
1. Connect the ethernet cable from the Modem to the Ethernet Input port on the Router (It is generally placed away from the other ports on the back of the router.) 2. Connect another ethernet cord from one of the output ports on the router to the desktop computer. 3. On the laptop, turn on your wireless card. The process for this differs from computer to computer. If you were to provide the model of laptop, I could provide you specific instructions. 4. The network setup should be complete.
If you need more help, let me know by replying to this solution. Thank you for using FixYa!
Apr 01, 2011 | NetGear Computers & Internet
I can not get by daughters compute to hook up to my netgear wireless router. My other computers had no problem in getting connected. We have tried everything and can not get it to take the router
Hello
Have you tried going to control panel,network and sharing center.
Once there, make sure all pcs are on the same network,either homgroup or public.
Your daughters needs to be on the same network as the others.Also be sure the firewall is not blocking any connections.
You may also want to reboot the router do this by...
1 shut down all pcs
2 Unplug all cables from router including power.
3 Let router set for a min then plug all cables back in and power up
4 Once you get stedy lights on router restart pcs.
Jan 12, 2011 | NetGear Computers & Internet
How to hook it up to computer
alright man routers are easy look you need to have a MODEM!! INternet MODEM.. that has a LAN LINE or cord
1. connect your modem LAN line to the router, the router MUST have a HUB where you can plug it in the router hub it should say LAN connect it there!!
2. connect the ethernet cable that came with your router ,connect the ethernet cable to the router on the hub that says 1 connect it and the other side connect it to your computer!!.
3. now insert your disc that came with your router!
adjust your router settings!! allow wi-fi if available and put your password!!
4. your router is set!!
thank you i hope this helped you!! leave a testimonial!!
Aug 02, 2010 | NetGear WGT624 Wireless Router
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
One computer connected the other limited or no connectivity
When using a router your IP is assigned to your Router. Then Your router assigns IP's to whatever is hooked up to it. Set everthing to detect automaticly. Might delet connection and create a new one.
Mar 11, 2009 | SMC Netgear 5Port Gigabit Ethernet Switch...
Problem with routers
i have a problem of phone line,in the router the phone line doesn't and it doesn't work,internet line is OK but phone line doesn't blink so please help me
Jan 27, 2009 | Linksys (RT31P2) Router
Hook up
Hi Cheryl,
From your cable/dsl modem please take the cable that comes out of it that looks slightly larger than a phone cable and plug it into a port on your NetGear Wireless Router that is labeled either Internet or WAN. After that is done, unplug the power to both your cable/dsl modem and your wireless router. Plug the power back into the cable/dsl modem and wait about 30 seconds then do the same with the wireless router.
Next on your computer, there should be a wireless icon by your clock near the bottom right corner of the screen. If you double on it, you will see a list of connections, yours will say Netgear and should have a good signal strength. Double on it and give it about 10 seconds to connect. Voila, you should be on the Internet.
Please let me know if this solves your problem.
Thanks,
Adam
Nov 28, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
The netgear router has problems connecting with the intetnet please help me
I have a problem here.
1) When i connected the modem to the computer, it works good.
2) I have more computer now, so i bought a router.
3) This time, when i plug in the modem to router and router to my 3 computers.
4) The local network is working but not the internet.
Any solutions? I have tried trendnet router, netgear. It's definitely not the router problem.
I have tested the same router in other ADSL line, it works.
Please help
Thank you
Aug 23, 2008 | NetGear WGR614 Wireless Router
Problem with netgear wgr614 v6 daisy chain
I am assuming the Verison was setup and working before this started, if not let me know.
Do you know the address and subnet mask for the lan side of the Verison Actiontec router? assumed like address 192.168.0.1 subnet mask 255.255.255.0 This means all addresses 192.168.0.? belong to the verison router's subnet.
Assuming the Netgear router is being daisy chained using a lan port from the Verison Router to the WAN port of the Netgear, the WAN side of the Netgear router needs to be either dynamically addressed or statically addressed in the 192.168.0.? uniquely outside the DHCP range for the Verison router.
The LAN side of the Netgear Router must not be addressed the same as the LAN side of the Verison router in this configuration.
There is another potential configuration where lan ports of both routers are connected. however in that configuration there are additional considerations. Please let ne know which connection you are attempting between the two routers.
There is some additional informatin you can gather
Assuning you have windows XP for the operating system on your computers hook a computer wired if possible to the LAN side of each router and issue the following commands
Click Start then All Programs then Accessories then Command Prompt in the new window that opens type the following command and press enter
ipconfig
write down th IP Address, Subnet Mask and Default Gateway for each adapter
Then issue the following command once for each default gateway not = 0.0.0.0 where {...} is replaced in its entirety with the default gateway.
pring {default gateway address no {}}
the expected responses will be either 4 timeouts or 4 lines with elapsed times. Timeout is failure -- elapsed times means it was connected.
For each router I need to know the default gateway and the subnet mask for the successful pair. Plese reply ina comment to this problem and additional steps will be forthcomming.
Dec 21, 2007 | Computers & Internet
NetGear WGR614 Router Logo
52 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
