Question about Ovens
Model HJA 3220 removal of internal glass panel
Lamona HJA 3220, need to know how to remove internal glass panel for cleaning purposes
I have the manual if any one needs it... can't upload it here but email me if you want... faisal at citydealestates dot com - no spaces. covers HJA3220 HJA3320 and HJA3212
Posted on Aug 24, 2012
5 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Posted on Feb 22, 2008
aborcass
  • 2651 Answers
SOURCE: I took apart to clean glass - think it is assembled wrong!
that glass( slanted one) is supported on top by the metal plate ( problably 3 inches wide) running across the top of the metal cover(covering the insulation level) the glass inserts inbetween 1 or 2 tabs in the metal support, it then lays on an angle against the metal cover( hoilding the insulation level) and is secured by the 1 in thick angled metal retainer. hope this was helpfull.
Posted on Mar 14, 2009
  • 17 Answers
SOURCE: Whirlpool double oven - model RBD305PD82
Please take a look at the diagram if you think you want to do that.
if you still want to do it and need more details to disassemble feel free to email me. nguyen@ite.net
Posted on Jun 09, 2009
bozcro
  • 867 Answers
SOURCE: the inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Posted on Jun 27, 2009
How do i replace the drop hinges for the oven door on a lamona HJA 3400
You will be taking the whole door apart to do this task.
You may need to improvise some tools and equipment, as the door-closing springs are pretty tough.
God bless your efforts.
Apr 30, 2018 | Ovens
How can I clean the inside of the glass on a Lamont 3400 oven door
Hello, Johnny -
The instructions I found for cleaning the glass inside an oven door are generic and not just for a Lamona brand oven. (You did mean "Lamona" and not "Lamont", didn't you?)
See the instructions here:
https://www.mom4real.com/how-to-clean-in-between-glass-on-your/
Read through the instructions, in full, first.
This is a link to other instructions in video format:
https://www.todayshomeowner.com/video/how-to-clean-inside-the-glass-on-an-oven-door/
Best wishes.
Mar 07, 2018 | Ovens
How do you remove and adjust the oven door to sit squarely on the rubber seal Its a Lamona HJA 3220
open door half way,pull out on the door,it will slide off the hinges
May 09, 2015 | Ovens
No temperatures on the oven
Easiest thing to do is to Get your Model Number, log onto www.searspartsdirect.com and order the new knobs... Or go to your local appliance repair center or Appliance parts store and order them and you will be able to get fix it for the future.
Download LAMONA HJA 3300 HJA3300 User Guide English
Mar 03, 2014 | Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Has anyone had a problem with the inner glass on the Lamona oven door exploding. Mine just has! It's only 18 months old and hardly used. I wonder if it's the difference in temperature betweeen the hot oven...
We bought our kitchen from Howden's as well about 15 months ago. They installed a Lamona double oven and hob. Last night when opening the door to the bottom oven our glass on the inner door exploded as well. Maybe there was a batch of defective ovens as ours sounds as though they mat have been bought/manufactured at the same time.
Mar 07, 2011 | Ovens
HJA 3300 Diplomat Oven Door Issue
my inner glass door exploded while cooking at 200 degrees.
Aug 17, 2009 | Ovens
The inside glass needs cleaning on siemens
Jun 27, 2009 | Ovens
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
734 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
