Question about Makita Drills
Schema makita 6095d - Makita Drills
  • 22 Answers
SOURCE: I have a makita 6095d
set it on the drill setting
Posted on Dec 13, 2008
rowdy45176
  • 2176 Answers
SOURCE: how to replace forward and reverse switch
If you are mechanically inclined you should have no problems but if not this is involved. First I would recommend going to the Makitatools.com website and on the right side type in your model number and look at a breakdown for this unit. To start with you have to remove the chuck, then the collar with the 2 springs under it and then remove all screws from the housing separating it carefully so none of the parts jump out. The switch is polarity sensitive so make sure of the wiring. If you still want to tackle this let me know and I will go into more detail on this. Good luck
Posted on Apr 08, 2009
  • 302 Answers
SOURCE: how do I change the bit on makita 6095d
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Posted on Oct 06, 2009
SOURCE: charger for makita 9.6volt 6095d not working
revisar las terminales del cargador que hasen contacto con las del taladro yestas tambien porque puede ser que esten oxidadas y linpiarlas con limpia contactos y con lija n400 o mas fina
Posted on Oct 05, 2010
rowdy45176
  • 2176 Answers
SOURCE: Problem taking batteries out of older Makita drill
there is a clamp on the bottom that has to be unlatched and the battery should just pull out of the bottom, unless it is stuck by corrosion and then you might have to "TAP" gently to remove. You can download a breakdown of this tool at makitausa.com to see what I am talking about.
Posted on Jun 26, 2011
Problem taking batteries out of older Makita drill (6095D) to recharge/replace them.
Jun 26, 2011 | Makita Drills
Charger for makita 9.6volt 6095d not working
Oct 05, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
Oct 05, 2009 | Makita Drills
What is the procedure for removing the chuck from a makita 6095D 9.6v drill?
Most chucks use a tapered shank that allows you to remove it with a good tap on the bottom. Other chucks have slots in the slots in the shaft that allows you to tao it off with a wedge type key. You could always use a dent puller and chusk on the screw.
Good luck, Jack
Aug 21, 2009 | Drills
How to replace forward and reverse switch on a Makita model 6095d cordless drilldriver
Apr 08, 2009 | Makita Drills
Can't get the keyless chuck off cordless Makita 6095D drill.
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
Dec 31, 2008 | Makita 12V Cordless Impact Driver -...
Drills Logo
35 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
