Question about Radio Shack Radio Communications
How do i take the L/O off on pro 404 scanner
Every time I hit the Scan button it says that the channels are " L-OUT " , and when I hit the L/O button It still doesent unlock them. Ive tried holding the button down for a few seconds as well, and still nothing.
Garfunkel01
  • 56 Answers
SOURCE: 1000 scanner radio shack
press the manual button a few times, and make sure there are actually some freq. programmed into the unit. if there are freq other than 000.000000 in there, press the s/s (lockout) button and see if this unlocks the frequencies to allow them to be scanned.
Posted on Sep 12, 2007
sir fixalot
  • 146 Answers
SOURCE: Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Posted on Jan 04, 2008
Mechanic688
  • 204 Answers
SOURCE: All channels locked out!!!
You might have to reset the scanner, refer to page 70-71 of your manual. If you need a manual go here,,,
http://support.radioshack.com/manuals/ome20-496.pdf
Hope this helps,,, Mechanic
Posted on Jan 25, 2008
One Wire
  • 126 Answers
SOURCE: all channels locked out pro-2055
I hope this will help. It shows locking and unlocking ids while scanning and while in a bank.
Locking/Unlocking IDs Contents You can lock out IDs you don't want to hear such as telemetry, MDT's, dog catcher, etc. To Lock out an ID while scanning, quickly press L/OUT while the ID is displayed. To Lock or Unlock an ID manually: 1. In Manual mode select any channel of the bank you want to lock or unlock an ID in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the bank number (0-9), list number (0-4), and the list status (ON or OFF) on the 1st line, the ID# in the list (0-29) on the 2nd line, the ID on the 3rd line, and bank tag on the 4th line (if programmed). 3. Press TRUNK (each time) to select the ID list (0-4). 4. Select the ID# (0-29) by pressing up.jpg or dn.jpg (or press and hold; faster) then press L/OUT to lock or unlock the ID. An L will appear to the right of the ID# if the ID is locked out. 5. Press MAN to exit programming. To Unlock IDs in a bank: 1. In Manual mode select any channel of the bank you want to view the locked out IDs in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the ID list. 3. Press FUNC then L/OUT (each time) to view the locked IDs. Press L/OUT to unlock the ID. The next locked out ID will appear. 4. Press MAN to exit programming. Note: You cannot unlock all IDs at one time.
Posted on Jan 28, 2008
  • 43 Answers
SOURCE: want to scan cell band?
This non-trunking scanner made by Uniden can store 200 channels, and has a frequency range of 25-512mhz with some gaps in the broadcast bands. so cell phone is not possable
Posted on Oct 25, 2009
Press scan, then press a number button and it will scan that bank -pick a number from 0-9 and it should scan that. If you did truly lockout everything hit 'manual' then hold down the L/O Lockout button for 3 seconds and you'll hear a beep- that should unlock everything.
Mar 21, 2014 | Radio Shack Pro-97 Handheld Scanner
Dear Staff: I have a Pro. 97 hand held scanner. I
Hi, my name is John. Press the FUNC and hold down the L/O button until it beeps twice......hope this was helpful..Rate this solution on the four thumbs-up......John
Sep 08, 2010 | Radio Shack Pro-97 Handheld Scanner
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
Pro 82 Scanner from Radio Shack problem!!
While its in scan mode press the # of the channel to select.. you will see the bar go under the # Then it will scan the channel
Jun 04, 2009 | Radio Shack Pro-82 Scanner
How do I unlock a channel that I previously locked out on accident by hitting the wrong button and how do i see the locked out channels
go to the channel by pressing manual,then the channel number,then manual again,then press LO or lockout, and scan
Jan 18, 2009 | Radio Shack Pro-96 Scanner
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
I have a radio shack pro 96 digital trucking scanner.the other day we finally put up my outside antenna for it.it worked fine all through xmas and new years.the other day turned it on and it would not pick...
The very part of your scanner that makes it a scanner is inop. YOU can find it but IT won't scan. Back to radio shack for warranty before they change their mind.
Jan 09, 2009 | Computers & Internet
Aug 19, 2007 | Radio Shack Pro-94 Scanner
Radio Communications Logo
52 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
