Question about Whirlpool Washing Machines
Noise when in washing cycle in Whirpool awoe 9140.
When washing machine is in cycle it makes loud grunting noise?
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
  • 7 Answers
SOURCE: loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Posted on Apr 08, 2008
dauphine
  • 207 Answers
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Posted on Apr 11, 2008
Lumpy816
  • 246 Answers
SOURCE: loud noise at end of spin cycle
The most common cause of the symptom you are describing is a bad drive block which has probably ruined your basket drive as well. Let me give a quick explination. The weight of the basket you put your clothes in is supported entirely in the center of the washer underneath your agitator. It rests on an aluminum block called your drive block. So that the basket will move back and forth while the washer agitates, there are two tabs on the drive block that lock your basket drive underneath in place. Once the drive block wears out or round down these tabs, the basket will raise slightly and "skip" across the top when the spin cyle is stopped. To verify this, you can check one of two things. First (and easiest) is put a heavy, large load in the washer, get it wet then spin it out. Once the washer reaches the maximum spin speed, open the lid. The washer should snap to a halt when functioning properly. What I belive you'll find is that even with the lid open, the basket will continue to spin. The other method to verify this is take the top of the agitator off. Next remove the bolt in the middle of the agitator and lift the agitator off. In the middle, you should find a large flat metal colored nut.In the middle of that nut, you should see two tabs across from one another. There should be two straight pieces of metal coming up from the bottom which have nice, straight sharp corners. Again, if I am correct, you will find they have been rounded off and there may even be shavings of metal visable.
To replace a basket drive and drive block, you will need to purchase the parts and also a specialty tool from removal and instalation. These will probably run you around 125-175. If you are interested in giving it a go, reply back to me and I will get you some step-by-stpe instructions typed up.
Posted on Jun 26, 2008
  • 35 Answers
SOURCE: Knocking noise during agitation cycle - GE WNSR2100T8WW
I believe you must have one of the bottom of the line cheapo washers, as I do--the one with the plastic, rather than steel wash tub and basket? These are pretty poor machines. They cut corners drastically in every part of the design. I've replaced the aluminum hub that supports the spin basket ( the hub is bare aluminum and corrodes within about 5 years use from the highly alkaline detergent, then it fractures under mechanical stress. Then the motor burned out. I was able to get a nearly new motor on ebay for $90 incl. shipping. (BTW, if you need appliance parts try GOOD Appliance on ebay for new and salvaged parts--they're excellent! 100% feedback rating) However, I now have the same problem--a fairly loud knocking noise during the agitation phases of the cycle. This is cause by a really crappy transmission design that does not wear well. My advice is just ignore it as long as it works and isn't leaking oil and the tub seal is still good. If it does finally go to pieces get one on ebay--that is if you feel up to doing the job yourself since a repair person would charge more than it's worth to install it. I believe new ones can be had on ebay for about $80, some are sold with seal kits. Bottom line is--if you want a machine that will last you for 15-20 years--don't buy a cheapo model. The front loaders are better as they use far less hot water (energy and water savings) but a good one is going to be anywhere from about $800 to $1600.
Posted on Sep 17, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Wont rinse
As rinse cycles are cold fills you may have a problem with the cold water supply valve. If you put your machine on a cold wash only and it does the same thing this problem should show up while filling and lead you in the right direction for repairing it.
Dec 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine making loud banging cracking noise.
Sounds like something's got between the drum and tub and is resting on the heater element. Remove the heater and check in the gap
May 09, 2012 | Washing Machines
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
Loud noise in washing machine
Hi, Raise the lid and stick something into the hole to activate the lid switch. Start the washer in spin cycle and after 30 seconds or so, release the lid switch and see if the tub continues to turn and make the rumbling noise. It sounds to me like the block that holds the inner tub has gone bad.
Has nothing to do with the move but, might have just happened.
Please let me know if this is the case or if I can assist you further.
Thanks
Vic
May 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 82110 - Loud Noise
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Mar 31, 2009 | Kenmore 22422 Top Load Washer
Apr 11, 2008 | Washing Machines
Washing Machines Logo
207 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
