Question about Grohe Classic Kitchen/Bar Faucet 31.057.000...
Loose handle on bridgeford 33 870 faucet? - Grohe Classic Kitchen/Bar Faucet 31.057.000...
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: low water pressure in my
The first thing to check is the areator at the end of the spout...
They often plug with dirt and drop the water pressure...
Take that off and check out the water with it off...
Then if it is still low then it is dirt trapped internally in the faucet...
heatman101
Posted on Sep 26, 2010
How to tighten loose handles on the 2 handle Delta Vessona kitchen faucet model #21925LF
usually have a setscrew in them!! mine are allen heads very small
Feb 11, 2015 | Delta Plumbing
Grohe kitchen faucet. I have good flow on cold water, but virtually none for hot water in Grohe bridgeford kitchen single faucet, is this a cartridge problem or worse?
try looking at the service valves located under the sink, the screwdriver slot should be in line with the flow of water,but some times the valve appears to work but it may have jammed shut even though it is in flow position,replacement is straightforward ,make shore the water is shut off elsewhere before removal.
Jan 28, 2014 | Home
Low water pressure in my grohe bridgeford kitchen faucet what could be the problem
heatman101
Sep 26, 2010 | Grohe Classic Kitchen/Bar Faucet ...
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
The handle is loose and the screw seems to be as tight as possible. It is a Moen single handle tub set.
might be that the spacer is missing. there is a small brass spacer located between the handle and the stem. if this is missing, your handle will feel like it's loose.
Jul 24, 2010 | Moen 3189 Legend One Handle Tub And Shower...
Delta shower faucet with a single handle lose
You need a faucet handle puller, you can get these at most home center and hardware/plumbing stores.
Once you get the handle and cover off you might just find that the control was never fully mounted.
May 26, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Handle is loose water flow weak
to tighten handle, you hold lever(top of handle) while unscrewing round piece below, entire assembly should come off.look down and should be screw down there, tighten it up. flow problem could be the areator, unscrew and clean if need'd. check supply tube's,shut off valve's, (if you have them)make sure they are wide open.
Mar 22, 2010 | Moen Bathroom Sink Faucet - 4-inch...
We are trying to remove the handle on a delta 172 single handle kitchen faucet. The hex screw won't budge now, but we were able to get the handle a little bit loose. Now not only is the faucet dripping,...
Make sure the exact allen key is in the screw. take a small adjustable wrench, close it onto the allen key, and loose with wrench turning the allen key.
good luck
Oct 09, 2009 | Delta Faucet Delta 172-WF Waterfall Single...
How do I take a loose handle off of an American Standard Hampton faucet?
The following link is the installation instructions for your faucet.
http://www.americanstandard-us.com/assets/documents/amstd/install/Install_555.pdf
Basically, what you need to do is gently pry the cap (with the hot/cold indicator) off the top of the handle. This will expose a screw-head, that you tighten to fix the looseness or loosen to remove the handle. If it's the other part of the handle that's loose (the bit that sticks out sideways rather than the whole handle). I've attached a diagram of how that is attached.
http://www.americanstandard-us.com/assets/documents/amstd/parts/Parts_555.pdf
Sep 07, 2009 | American Standard Town Square Two Lever...
Grohe Classic Kitchen/Bar Faucet  31.057.000... Logo
32 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
