Question about GE Dishwashers
Kert commercial dishwasher model #10.
Dishes go through the rinse cycle and come out at 95 F. degrees temperature
  • 30 Answers
SOURCE: Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
Posted on Jan 05, 2007
SOURCE: Dishwasher doesn't rinse
I followed your instruction, but nothing happened, ie. no water came out, so glasses were empty, and the spray arm didn't turn at all.
I don't know if this might cause the problem. On saturday, when I used the dishwasher, I also washed other big stuff (they couldn't been fit in the washer) in sink by using a lot of water. I am wondering if that made the water pressure too low in the washer, which might cause something broken?
Thanks!
Posted on Feb 27, 2008
  • 276 Answers
SOURCE: Dishes not being rinsed thoroughly in our GE Nautilis Dishwasher
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
  • 27 Answers
SOURCE: DIshwasher runs FOREVER and does not seem to rinse
Maybe a filter is clogged.
Posted on May 08, 2009
  • 70 Answers
SOURCE: Even when dishes are rinsed thoroughly, little
1)rinse not happening properly.
problem in filter(solenoid).
2)check the boiler tank any blockage.
Posted on Jan 13, 2010
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
RINSE ONLY LIGHT BLINKING Kitchenaid KUDM01TJBS0
I want to know what was the exact maker/model, part# of your unit
Thanks
Jun 01, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
It won't pick up the rinse aid
I had the same problem. The factory wouldn't help. To correct my problem, I switched dishwasher solution to one with a rinse aid in it and took my hot water temperature up 10 degrees. No more spotty dishes.
Nov 15, 2012 | Dishwashers
Help! My dishwasher doesn't rinse soap off my dishes anymore
try a few applications of jet dry DISHWASHER cleaner to remove excessive build up of calcium/hard water deposits...sounds like the water temperature is too low upon the initial fill cycle to assist in dissolving the soap.the water temp. must 125 degrees to insure soap activation/ and dissolve it.check for obstructed spray arm as well
Mar 06, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishes are rinsed before going into machine but when the cycle is finished they are spotted and have bits of food sticking. I have cleaned the filter - do you know what dishwasher cleaner I can use. I...
Make certain that the spray arms are not clogged and are actually turning during the wash cycle. Try using Jet Dry in the rinse dispenser. Make certain that the dishes, etc. all facing the center of the tub and not nesting (behind are in front of other dishes, etc.) that would prevent thorough cleaning and exposure to the detergent and water. Make certain that the water temperature is at least at 140 degrees.
Feb 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Rinse temp too low, first it comes up to 180 degrees and then drops to wash tank temperature, WHY?
The rinse temp only reaches 180 degrees for a couple of seconds towards the end of the cycle. This will sanitize all warewash and meets most health code regulations. The rinse water temp will drop rapidly as it is incorporated in to the machine and sprayed on the dishes.
Regards
Feb 23, 2010 | Moyer Diebel 24 in. 301HT-40 Built-in...
Can you tell me what temperature the dishwashers reach during each part of cycle--Dishwasher model is WDF902SA Food authority have asked this of me
The wash temperature for a high temperature commercial dishwasher should be around 140F AND 160F. The final rinse temperature should be 180F to meet health code regulations. The final rinse temperature is reached during the end of the cycle for a few seconds. If the machine is a low temperature dishwasher the wash temperature and rinse temp will be around 140 F to 160 F. The sanitizing of your warewash will be done by the use of chlorine or iodine in the low temp application.
Regards
Jan 18, 2010 | Westinghouse Dishwashers
Temp. too hot
First off, the temp adjustment can only be made by a trained service tech, since the dishwasher will need to be reprogrammed to allow for a lower temperature in the rinse cycle but still have the higher temp needed in the wash cycle. Also, since any change in the water temp settings will require a longer wash and rinse cycle to be programmed into the unit.
Of course, you could simply lower the water temp on the water heater that supplies water to this unit, but you'd have lower temp water elsewhere and likely get cited at the next heatlh department inspection on that issue.
Since this is a commercial dishwasher, you might want to reconsider lowering the temp, since health codes and standards for commercial establishments require a MINIMUM water temperarture of 185 degrees F (85 degrees C) for proper operation and to get all the crud off the dishes, etc.
Note, the manufacturer sets these units to the higher temp, 203 degree F (95 degree C) knowing that the water will cool down quickly once the wash cycle starts and the water contacts the dishes, etc. That is also why these units have a added heater element, to help keep the water at the correct temperature needed to both clean AND sanitize the dishes, according to established health standards.
If you really want to change the water temp settings, contact your Hobart service rep and explain the reason you want it lower and see what they say.
Hope you found this very helpful and best regards!
Aug 19, 2009 | Hobart SR24-H Built-in Dishwasher
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dishwasher - Soap Stuck in Cup If you have dishwasher detergent stuck in the soap cup after a full cycle, please check for the following conditions:
  • The water temperature should be at 120 degrees (140 degrees if your dishwasher has water heating capability). Check your water temperature Check your water temperature.
  • Make sure the soap cup is not blocked by anything.
  • Allow the dishwasher to fill and make sure it is getting a proper amount of water. The dishwasher should fill for about 90 seconds. On permatuf models, the water should measure 3/8" above the island near the center of the tub. On all other models, the water should measure about 1/2" below the heating element.
  • Check the lower spray arm for any blockage in spray holes or items that would restrict its turning.
  • Make sure the soap cup has opened at the end of the cycle.
  • Check the sump area inside the dishwasher for any restrictions.
Apr 09, 2009 | Maytag 24 in. MDBH950AWS Built-in...
The correct way to start the wash cycle
we have just purchased a Fagor dishwasher also - the instruction manual is worthless.
in regards to the 2 thin tubes, we just inserted them in the gallon jugs that the soap/rinse agents comes in and it works fine. just make sure the clear tube without the label goes in the rinse agent and the labeled tube goes in the soap jug. we did drill a hole in the top cap of the jugs and pushed the line thru and that helped keeping the tubes in the jugs and minimized the mess if the jugs fell over.
in regards to the temperature problem, we found that running it thru a couple of cycles before you start the actual dishes helped get the water temperature up faster. it seems to like to start with normal tap hot water first, so the 1st couple of cycles get the cold water out of the line.
Dec 29, 2007 | Fagor 24 in. FI-48W Dishwasher
Dishwashers Logo
242 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
