Question about Quinny Buzz Jogger
Lubricating front wheel of Quinny Buzz Stroller
The front wheel still rotates fairly easily but not as much as before. It sometimes gets stuck when I am taking it up an incline or even just turning it in a store.
  • katrina40 Oct 29, 2008
    I read on another website that it was better to use a silicone lubricant rather then WD40. I did that and cleaned the whole stroller and it is working much better now.
    Thank you,
    Katrina
I had that problem and just used some WD40 on it.  Works much better now.
Posted on Oct 28, 2008
I just purchased a second hand Quinny buzz 3 and I believe I need a new front tire. When I go to turn the tire bumps on the cement and prevents me from turning with ease. Where can I find a new spare tire?...
hi you can get a new wheel unit from quinny direct or eBay
the folding is something else turn the buzz over and check the groove on the middle tube to see if it is clean try an oil like wd40
if that doesn't work it may need a re gas which can done by quinny
Feb 16, 2011 | Quinny Buzz Three Wheel Stroller
Where can I find a Stroller seat replacement for Quinny Buzz 3
HI,
You can purchase the seats at www.quinny.com or on eBay fairly easily, should be in the region of £65 GBP.
Hope this helps.
Mar 26, 2010 | Quinny Buzz Three Wheel Stroller
Quinny buzz front wheel just swivels.
Hi you can buy new & used very cheaply on ebay
Mar 11, 2010 | Quinny Buzz JUICE 2007 complete Brand...
My front wheel is sticking on my buzz. It gets
yes give it a good sqwert of WD40 and spin it round by hand till its free again it sounds like it may also be a bent shaft have you hit any big bumps? or has the baby put on a lot of wate?
Oct 24, 2009 | Quinny Buzz Three Wheel Stroller
Problem with the front wheel Quinny buzz 3
This does sound like you have got a build up of dirt within the wheel assembly unit. I would suggest that you remove the entire wheel (push the two black buttons either side of the axle and pull) then clean the entire wheel in warm water. Lubricate the moving parts with a thick lubricant (something like vaseline, not DW40 as this attracts dust) then pop it back on, that should sort it out.
If the wheel is still not working, then contact your retailier if still within warranty (two years chassis and one year fabrics). If this is out of warranty, contact www.quinny.com who will be able to sell you a replacement wheel assembly.
I hope this helps.
Oct 10, 2009 | Quinny BUZZ 3 Capri Stroller
One wheel moves when brake is released
take both the wheels off give all parts a rubb down in wheel area then try again if it persists lubricate the inside of the wheels as the breaks are pin type and settle into a groove to stop pram migh be getting stuck x hope this helps x
Sep 25, 2009 | Quinny BUZZ 3 Capri Stroller
My quinny buzz front wheel does the same.
lubricant is fine on moving parts as long as all previous lubricants have been cleaned off as lubricants can react and counteract each other x
Aug 26, 2009 | Quinny Buzz Three Wheel Stroller
Front wheel of quinny buzz always gets stuck and hard to turn. i always check to make sure it's in the unlocked position.
I would suggest that you completely remove the wheel (pinching the two black plastic buttons and pull it out). Fully clean the assemble and re-attach. Also, a good idea would be to lubricate the moving parts with a thick lubricant, such as vaseline.
I hope this helps.
Aug 03, 2009 | Quinny Buzz Three Wheel Stroller
Unable to fold and front wheel keeps sticking
Hi Kelly,
Over the years we have seen customers having trouble folding the Buzz. Mostly it's a combination of factors that make a Buzz a bit stiff.
Most important is that the main silver central tube must be clean and preferrably lightly lubricated. (Put some WD40 on with a rag.)
The second point of attention is the grey release knobs: Remove (blow out) any sand or debris and spray in some WD40. Especially the knob on the left that is slide-push needs this attention. (Left-right viewed in the driving direction.)
These grey knobs have to be pushed firmly to properly fold the chassis. (The left one is first-slide-then-push.) When it folds and gives a loud 'clack' you didn't push them in far enough. We know from experience that this sometimes remains difficult for some customers.
Later revisions of the Buzz have slightly larger buttons that are somewhat easier to operate.
Your front wheel probably needs some care. At the side of the black plastic front 'fork' that holds the wheel you will find a small hole. Rotate the front wheel until you see a small button come by. Push it with a pointed object. (A small screwdriver will do)
You can now remove the front wheel from the black front fork. Clean the internals and lubricate, preferrably with a teflon loaded grease or teflon spray. (Spray is less durable than grease)
This will take care of your steering problems.
Alternatively you can have a look at the Quinny Buzz All Terrain wheels. It's a sturdy drop-in replacement for the original wheel:
http://www.babycare.nl/quinny-buzz-all-terrain-voorwiel-p-1819.html
Please contact us through the contact form on our website if you need further assistance.
www.Babycare.nl
Erwin de Raad
Jun 23, 2009 | Quinny Buzz Jogger
Front wheels on quinny buzz are a nighmare....
http://www.babycare.nl/quinny-buzz-all-terrain-front-wheel-p-1819.html?language=en&name=Quinny%20Buzz%20All%20Terrain%20Front%20Wheel
Mar 26, 2009 | Quinny Buzz Three Wheel Stroller
Quinny Buzz Jogger Logo
190 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Al Toledo
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
