Question about Dell Precision M70 Notebook
Dell Precision M70 PC booting problem
When i switch on my Dell Precision M70 PC, the very first screen is the boot up screen. At the bottom is a status bar which moves from left to right after which the computer continues booting and loading the operating system (win xp sp2).
The problem i face is in the boot up (very first screen after the computer is switched on). The status bar indicator goes to almost the end towards the right hand side and freezes. Thereafter i switch off the computer and after a couple of seconds switch it on again. This time it boots properly without any problem.
This has been happening for the last one month only and occurs all the time.
I would like to know the reason for the same and if there is anything wrong with my computer.
Thanks in advance.
  • Dell Master
  • 998 Answers
There’s probably an issue with your boot-up files or the hard drive. Suggest you start backing up all your documents, pictures and anything else that you don’t want to lose. Press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. If no errors are detected, your software has a problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Oct 26, 2008
I need to make a download drivers for my PC
Posted on Mar 22, 2009
Dell precision m70 is not booting. Power lights
Run chkdsk/f to check for hdd errors.
Oct 21, 2014 | Computers & Internet
I have a dell precision m70. It fails to boot. The
How many times! Check the file system in the hdd.
Dell precision m70 administrative password is is locked. ehat can i do
Use a program called Kon-Boot
it will bypass all Windows security altogether
Apr 16, 2013 | Dell Precision M70 Notebook
Os boot failure after restore. dell precision m70 with win 7. tried everything. starts to boot then reverts back to bios screen
This is normally caused by a corruption in the windows software. Since you have restored it all ready, I would go ahead and run a full factory restore and wipe the system. If this does not work check your memory chips. There is a good tool here: http://www.memtest86.com/
Hope this helps
May 04, 2012 | Dell Precision M70 Notebook
How to reset my dell precision m70 to factory settings
need the windows disk and serial code then you need to boot up your computer and as soon as it begins to turn on press the corresponding button for boot devices this will bring you to a list showing you hard drive CD drive and other peripherals , insert the windows disk and then use the arrow keys to select the CD drive from there just follow the basic next,next,agree installer then i would suggest installing the drivers then all your programs hope i could help =]!
Mar 04, 2012 | Dell Precision M70 Notebook
I have a dell precision M70, and I am wondering where the switch that shuts off the display when the lid is closed is.
Windows 7 Control panel => Power Options
On the right hand side of your power plans you will see CHANGE PLAN SETTINGS then on the next page you will see on the bottom CHANGE ADVANCED POWER SETTINGS under there you should see the lid settings. Hope that helps.
Jun 24, 2011 | Dell Precision M70 Notebook
Im having many lines in screens starting from boot until win. pg
Graphics card and possibly the LCD are bad, Replace as such.
Apr 13, 2010 | Dell Precision M70 Notebook
Dim screen dell precision m70 too dark screen
try this press and hold Fn then tap on arrow up key check if the display will become bright. if fails try connecting an external monitor to your laptop check if display is fine. if not then uninstall video driver then install a latest one. if fails replace the video card drive or motherboard if video is built-in. if display is fine from the external monitor then reseat the LCD cable if fails then replace the LCD panel with the LCD cable.
Oct 24, 2009 | Dell Precision M70 Notebook
Dell M70 laptop won't boot up
If you have a Windows installation CD, you can use the Recovery mode to attempt to fix the problem.
Turn on computer, insert CD into drive.
Press any key to boot from CD
Windows installation process will start
After a few minutes, a screen will come up telling you to hit ENTER to install Windows, or to press R to enter the Recovery Console
Press "R"
You will be asked which operating system
Most times there is only one option, select 1
At command prompt, type "fixboot" and press ENTER, if it asks if you're sure, type "Y" press ENTER again
Then, at command prompt, type "fixmbr" and press ENTER, again, type "Y" and press ENTER if it asks.
Type "exit" and press ENTER to exit recovery console and reboot.
Give that a try and see if it will boot for you.
Mar 08, 2009 | Dell Precision Mobile M70 Notebook
Dell Precision M70 Notebook Logo
422 people viewed this question
Alun Cox
