FixYa.com
Tags:
Celestion S8 Subwoofer
Celestion S8 Subwoofer (by 3 users)
posted by Oberon on Aug 22, 2006
Hi folks,
My S8 has started humming all the time, with or without the phono lead in, and in all on/off/auto positions. It's been a pretty good sub so far so I'd rather try and fix it than dump it! Could it be a coupling cap or a resistor gone high in the amp? Any help much appreciated!
Oberon
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Aug 08, 2008
I have an S8 with the chattering relay issue and we are not alone - looking about a few forums it is a widespread problem.
I got hold of the schematice for a kef psw2000 which is broadly similar and after browsing the diagram and a few forums I plan to replace the main smoothing caps and also c52, which sits after the relat and smooths the full supply voltage, it has a hard life and I suspect the 63v part that is fitted has not lasted.
Comment by Guest, posted on Jan 02, 2008
i have the same problem with mine it seems to be the blue relay chattering , voltages and cappies seem ok, the reason for the chatter is unknown anyone out there got a circuit diagram.
Best Solution
posted on Sep 03, 2006
FixYa! (100)
The Marv
Rank:Wiz Wiz
Rating: 84%, 252 votes
I would check the electroltyc caps in the power supply They general are in the first part of the power supply and there will be two of them . What they do is filter out transformer hum and help stabalize the circuit. I am not saying this is absolutely the problem but the capcitors are relatively inexpensive, Easy to change. And have a habit of going bad after a couple of years in use.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Mar 07, 2008
Not Rated (0)
shaneuk
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The relay chatter is because its getting AC from the board. I took the relay off the board and tested it with 24VDC it works fine - checking with a multimeter it seems the relay is getting about 20vDC and at the same time 8V AC ! Normally my multimeter wont read AC if its DC and vice versa - very strange! But the question is what is causing the circuit to get AC?
Solution #3
posted on Feb 24, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
It's a problem in the grounding of the unit all you need is receptacle adapter that takes away the ground plug on the power cable.
Solution #4
posted on Nov 13, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
i too found my subwoofer humming after about 3 years... weird thing is i found the solution to my problem... i turned on my sub, it hummed, i disconect the cable from my tv, IT STOPS!!! i am going to radioshack tomarrow to pick up a device that connects my cable to my tv to stop the interference
Solution #5
posted on Oct 05, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
If the sound source is on a different circuit or plug it produces some kind of a loop (dont know the technical name) Go to radio shack and get a ground loop disrupter that goes on the audio cables right before the speaker and it eliminates that hum.
Solution #6
posted on Nov 02, 2006
Not Rated (0)
Spook
Rating: 0%, 0 votes
When you say check the caps what do you mean? I also have a Celestion S8 Sub that is about 3 years old and has just started doing this exact same thing. Celestion say they'll fix it for about £50.
Could you be a bit more specific for those of us that don't know much about electronics :o)
This Problem Also Relates To: GE MA90559 Rear Speaker Jensen JW250 Main / Stereo Speaker Kenwood KVS-64 Speaker Kenwood SW-303 Speaker Panasonic SB-AFC500 Main / Stereo Speaker Panasonic SB-TP10 System Sony SA-WM500 Subwoofer
Can you Help with these Home Theater Speakers and Subwoofers problems?
cyberhome ch-dvd 505
i can¨t conect speakers Answer This...
bose cinemate with...
how do i wire it in with my... Answer This...
home theater
my rear speaker wires are too... Answer This...
Problem with sub-woofer
I Disconnected the system to... Answer This...
home stereo
home stereo from 1990 's brand... Answer This...
Repair Service
Find Home Theater Spe. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
