Question about Polaroid FLM-3732 Television
Polaroid LCD has Flourescent Lights and a Blurry Screen
My tv screen keeps turning to flourescent colors and the screen is blurry. Any idea what is causing this or what I can do to fix it?
  • info843 Oct 26, 2008
    I am having the same problem. My tv is the FLM-373b and wouldn't turn on anymore. I replaced the caps in order to get my power to turn back on since they were blown, but now its flourescent, blurry, and no audio.
  • wisco5 Oct 26, 2008
    thanks so much! that worked for me too!
Okay I just got mine to work. All I did was: click menu on my remote control, go to setup, go to the very bottom where it says "Default" and press ok on the remote. Everything went back to the default settings and worked.
If the audio still doesnt work, go to menu, audio tab, down to MTS system and hit right or left on the remote to change the audio setup.
Posted on Oct 26, 2008
Dark Screen
It sounds like a back-light problem. Check all the CCFL back-lights.
May 08, 2013 | Samsung LN52a750R1FXZA
Where is lamp location in polaroid 32in hd tv
Your model is a LCD flat panel which doesnt have a lamp. Instead they have a series of flourescent tubes behind the Screen which light the screen. The backlights hardly ever fail its usually the Inverters which fail when you dont have any picture with that model. You can get the inverter board and free technical assistance from www.tvrepairworld.com
Aug 03, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
I have a 37 inches polaroid tv and, it was working fine at night, in the morning when I turn it on, a a black spot show on the right side of the screen
Depending which model, this tv may have an inverter master and slave module set. I find best to replace as a pair. These modules feed the flourescent lamps that backlight you lcd screen. more than likely the one failing is on the same side as the spot you are seeing. I always first look at the power supply panel, to be certain that capacitors on this board have not failed or leaked out.
Parts look here http://www.shopjimmy.com/tvs
Jul 09, 2011 | Polaroid TLA-04011C 40 in. LCD TV
I have a Polaroid tv 32" flat screen tv and I heard a noise like hissing! It got louder and then my tv went out and smoke came from the top of it! So, can it be fixed and how much would it cost to...
99% chance the problem is in the inverter board that provides the AC needed for the flourescent lamps behind the LCD monitor.
There's a small chance it is the power board.
Oct 25, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
We have sound and you can see the sound bar on screen but no picture
Open the back of the TV. Then turn it on. You should be able to see white light indicating the flourescent lamps are on. Don't touch anything tho because there are high voltages there. If the flourescent light dont come on then it is the board that powers it. If the white lights are on at the back then it is the main picture board. I may add though that the power supply that powers the flourescent lamp has higher failure rate.
Jun 26, 2010 | Televison & Video
Everytime i turn on my lcd tv it turns on and the pictur goes off
there are flourescent tubes inside that can be replaced, they help to alluminate the screen. There are these other boards inside that can malfunction too, best to take the unit to a technician.
Dec 13, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Blurry screen on 50in Hitachi LCD
Sounds like you need a bulb replacement, if you watch tv a lot ave life is about 5 years
Sep 14, 2009 | Hitachi 42V710 42" Rear Projection HDTV
I have a new polaroid I735 camera and the pics are very grainy and blurry even when viewed through lcd screen. Any ideas?
maybe you zoom in a lot and then it would be normal and if the pictures come out fine, i wouldn't worry about it but if the print pics come out grainy and blurry i would take it back if you have warranty
Aug 03, 2009 | Polaroid i735 Digital Camera
My 52in big screen just started to get a blurry screen to it
If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Feb 15, 2018 | RCA HD52W58 52" TV
Flourescent Colors on my LCD
try adjusting brightness and sharpness! is this problem something new or has lcd always looked this away
Oct 26, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Televison & Video Logo
188 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
