Question about Alpine CDA-7892 CD Player
Error message with new CD-R copies.
I play copies of cds that I buy so the original doesn't get scratched and ones I've made recently won't play in the player once I make them. I'll flip down the face and stick it in and it immediately says 'Error' on the display. My older burned cds work just fine. I'm using the latest version of Nero to copy them should I use the older version like the others were made with or is there another problem?
DUUUDE...I am having the exact sasme problem!!! I almost threw the damn stereo out the window on the way to work.
Posted on Jun 01, 2007
When I try to listen to the cd's, it won't play them. It tries to acknowledge them but the player won't play them
CD players commonly will not recognize some types of CD, eg MP3 recordings, or maybe CD-RW recordings.
However if this is happening with CDs that would previously play OK, then it could be
- scratched or dirty CD surface
- contaminated laser lens in the player
- laser lens has become misaligned
The last 2 need a service technician, but it may be cheaper to buy a new player.
Nov 19, 2011 | Audio Players & Recorders
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
DVD-RW PROBLEM
Your CD might be damaged. Have a closer look at the CD holding it against a light and you will find where it is scratched.If you are able to access it on a different PC drive. please back up the data on that PC and make a fresh copy of the data on a different CD. You may lose some information BTW.
Dec 28, 2009 | Acer TravelMate 4200 Notebook
CD Player does not work. Error 03 message is
Dirty CDs can skip or just stop playing For best results, use a CD cleaning fluid and anti-static cloths made for cleaning CDs. If these tips don't help you might have to buy another copy of your CD, but first try it in another player because some CD players are more sensitive than others to scratches.The last option is to replace the CD Head by taking to a nearest service provider.
Dec 28, 2009 | 2004 Mitsubishi Endeavor
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
CD changer will not play reads "player error" .
Most new car-stereo's don't have an "oldschool" CD-drive, but really a CD-ROM drive; meaning that they won't (properly) read and/or play copy-protected CDs.
Most CD protections are specially designed not to work in CD-ROM drives to prevent copying. As a side-effect most of those protected CDs won't work in car-stereo's.
Try a CD without copy-protection (like an homemade audio CD using burning software on your computer) and see it that works ?
In case that doesn't work either, your car's CD-drive is probably broken ...
Mar 22, 2009 | 2004 GMC Envoy
MY GRAND THEFT AUTO 4 WONT PLAY IT KEEPS STOPING THE GAME AND TELLING ME 2 CLEAN THE GAME WITH ACLOTH THEN PLAY IT THERE IS KIND OF BIG SCRATCH ON IT BUT ITS NOT THAT BIG SHOULD I JUST BUY ANEW ONE
you could buy a new game, but it,s worth trying this disk repair solution first. i,ve been repairing game-music cds/dvds for a couple of years, with 80% sucessful results.
1:) Find an empty jewel Case ( plastic cd holder case ) put the game-disk into the case upside down. ** Underside Facing Up**
2:) Take a soft-cloth ** Yellow Duster Type** and apply a small amount Of T-Cut Or Toothpaste. to the cloth.
3:) holding the disk with one hand, to stop it moving. use your other hand to work the cutting paste into the disk, around the scratched area. using light to medium pressure.
4:) once you,ve polished the area around the scratch, using a clean piece of soft cloth, buff to a polish.
5:) once the scratch has been removed, polish with a light solution of furniture polish, to fill in any surface inperfections.
If your in the UK, i can repair the disk for you.
mike @ Compurepair.
Jul 02, 2008 | Video Game Consoles & Games
Error code 6 & error code 4
hi try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
May 21, 2008 | Clarion DXZ438R CD Player
Prblem with samsung dvd hr-737
Hi, I have the same problem. Have called Samsung, those **** don't know ****. The player also doesn't recognize DIVX. This is what you get when you buy Korean cheap ****. I've sent mine in the garbage. I was smiling as the garbage collectors came and took it to hell.
Mar 16, 2008 | Televison & Video
Alpine CDA-7892 CD Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
