Question about Panasonic TC-32LX60 32 in. LCD Television
Flourescent Colors on my LCD
The colors on my Panasonic are all blurry and turn flourescent. Any idea what is causing this problem?
  • 1 more comment
  • wisco5 Oct 26, 2008
    no this problem is new. i can barely make out the picture, so i don't think it's a matter of brightness or sharpness. any other ideas?
    i know i said panasonic, but it's actually polaroid...my mistake. polaroid flm 3732. do you think is with the actual tv or with the cable box? thanks for your help.
  • wisco5 Oct 27, 2008
    actually i think i figured it out. went to menu-setup-default, and everything seems ok right now. it used to go back and forth, but hopefully this works for good. thanks for your help!
  • 31 Answers
Try adjusting brightness and sharpness! is this problem something new or has lcd always looked this away
Posted on Oct 26, 2008
  • 1 more comment
  • cassidy barr Oct 26, 2008
    what model specifically is it.
    thanks
    C
    what cable provider do u have and do u have a box setup or just to wall with coaxial
    tell me all the specifics please like if you have a set top box who makes it model number off the back and so on cable or satellite.
  • cassidy barr Oct 27, 2008
    not a problem it deffinatley sounds like a source problem ex. cable or satelitte box
Flash pictures have orange tint
Check the settings for white balance. It sounds like the camera has been set to balance to flourescent light which is a different color (and temperature) than flash.
Aug 15, 2014 | Panasonic Lumix DMC-ZS25 Digital Camera...
I installed the PR180 switch in my garage with a 4ft dual t-8 flourescents bulbs. When the motion sensor timer turns the light off the flourescent bulbs stay slightly lit, as if it were on a dimmer...
There is nothing wrong with the switch or your wiring. The Leviton R01-PR180-1LI is not designed to work with flourescent lights. A lot of electronic controls will bleed through a small voltage when in the "OFF" state. It's just enough voltage to make the ballast in the flourescent light try to fire but not enough to let it fire the way it is supposed too.
What you need is a motion switch that is rated for flourescent lights, such as this :-( :
http://www.smarthome.com/2520W/Leviton-ODS10-IDW-Commercial-Grade-Wall-Mounted-Occupancy-Sensor-White/p.aspx
Nov 28, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
Photosmart A512v: colors are not true, more bluish....is it the ink cartridge that needs replacing or is it the paper????
In the setup menus, try changing the ambient lighting from flourescent to incandescent or daylight. This is the most comon culprit when pictures have a definite bluish hue to them.
Aug 18, 2010 | HP Cameras
Monitor is very very faint but you can see it in the light. Any Idea whats wrong
1. Check to make sure the display brightness is turned all the way up. Sometimes this gets turned down. Look for the symbol on your keyboard that looks like a light or sun with the arrow up mark.
2. Laptop displays use a backlight tube(s) to transmit light though the LCD appetures that give you color and graphics. This one or more of the flourescent tube may be out. You will need to have a Toshiba qualified tech replace the lights for you.
Mar 26, 2010 | Toshiba Satellite A55-S1063 Notebook
My screen on my syntax turns pink after it warms up for 10-20 min
it could either be a lcd control board or a main bd causing this problem
im not sure you can get either part as of now
Feb 09, 2009 | Syntax LT27HV 27 in. LCD HDTV
Polaroid LCD has Flourescent Lights and a Blurry Screen
okay I just got mine to work. All I did was: click menu on my remote control, go to setup, go to the very bottom where it says "Default" and press ok on the remote. Everything went back to the default settings and worked.
If the audio still doesnt work, go to menu, audio tab, down to MTS system and hit right or left on the remote to change the audio setup.
Oct 26, 2008 | Polaroid FLM-3732 Television
Kodak v550 easyschare camera
As long as the pictures look fine it is something going on with the lcd display.
If it was taking pictures the same, it could be a special effect that is turned on or the CCD is bad. It sounds like the LCD display is bad. Some cameras can be repaired at a reasonable price with a new LCD display.
Have you replaced the batteries in the camera? That might take care of the problem.
Jun 15, 2008 | Kodak EasyShare V1003 Digital Camera
Picture color
IHave a look under my solutions for this model... You need to have the convergence adjusted in the I2C menu..
Bill
Nov 20, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Panasonic TC-32LX60 32 in. LCD Television Logo
114 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
