Question about AGA Kitchen Ranges
My 2 door Aga oven,oil-fired, won't get up to temperature.Help?
Cleaned out oil lines and burner. Lit first time but overnight will not get up to temperature
  • 22 Answers
SOURCE: Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago
If they ignitors worked properly before you aunt cleaned them, the problem could be with the way they were cleaned and what they were cleaned with. Please tell me how she cleaned them and with what. Also, had she cleaned them before without incurring any problems, or was this the first time she had cleaned them?
Posted on Dec 03, 2007
You have water left over from cleaning and it is shorting out the igniters at the knobs, not the burners. I guess the solution is to wait until it dries out unless you can open the top and maybe use a hair dryer.
Posted on Mar 31, 2008
  • 3 Answers
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
Posted on May 28, 2008
VOTIT
  • 2071 Answers
SOURCE: my oil fired aga will
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN?
small_13_33.jpg For a detailed Range/Stove/Oven illustration, click below.
redarrow.gif Gas Free Standing
redarrow.gif Electric Free Standing
redarrow.gif Gas Cooktop
redarrow.gif Electric Cooktop
redarrow.gif Gas Walloven
redarrow.gif Electric Walloven
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It's stopped completely
It won't bake
It bakes poorly
It won't broil
A burner doesn't work
A burner works only intermittently
I can't adjust the burner temperature
It won't bake or broil
The clock stopped
The temperature is wrong
The oven light doesn't work
There's a self-cleaning problem
The oven door won't close
An indicator light doesn't work correctly
The oven is hot on the outside
I see sparks!
The drip pans need replacing
Posted on Jul 15, 2008
huuum
  • 750 Answers
SOURCE: top burners often wont light if oven is already lit
Hello and welcome,
If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
This will need to be diagnosed hands on at your location.
But this is the fault!
Thank you for using fixya.
Huum
Please remember to leave a solved rating before you leave!
Posted on Dec 07, 2008
Oil fired Aga is making wheezing sound
Sounds like air passing where it should not be, try checking that all the components of the burner are seated properly for example the cap on the centre resivour and the other thing is that the wicks are high and causing a taller flame
Mar 31, 2014 | AGA Kitchen Ranges
Oil aga is not getting very hot
Hi Rich.
You might like to follow my Oil Burner servicing videos if you think the burner needs servicing.
I also sell a tool for removing the Barrel or Hot Plate AGA Hotplate Hot Plate Barrel lifter Crane
Oct 20, 2013 | AGA Kitchen Ranges
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
I have come down to find my aga cooker out the fire has gone out. There is oil around the burner but I can see no reason why it has gone out. Any suggestsions?
Much better than a microwave, any day!
It is quite common, if the fuel tank is not checked yearly, that condensation may build up in the fuel line and finish up with water in the fuel, causing the problem you describe. Also a sharp downdraft from the chimney can blow the pilot flame out.
Make sure it is cleaned before you re-light it. Preferably get the system serviced.
Hope this helps.
Oct 29, 2010 | Microwave Ovens
Kitchen Ranges Logo
154 people viewed this question
Top AGA Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Paul Carew
Tom Chichester
Are you an AGA Kitchen Range Expert? Answer questions, earn points and help others
