Question about Hotpoint Aquarius WMA42 Front Load Washer
How do i get the top of my hotpoint wml540 aquarius?
I have taken out 2 screws from back of washer, but top still wont budge
SOURCE: Hotpoint Aquarius WMA42 Front Load Washer
to remove top, remove plastic luggs on each side carefully with a knife under which ther is a screw, this screw has a special head, this can be found in a screw driver attachment set avilable from any diy shop
Posted on Sep 17, 2008
  • 135 Answers
SOURCE: i have a hotpoint washer/dryer
This is usually caused by a poor feed to the hot water valve.
Posted on Nov 14, 2008
barkencoa
  • 3463 Answers
SOURCE: door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
barkencoa
  • 3463 Answers
SOURCE: HOTPOINT AQUARIUS WML540, hOW TO RELEASE THE
Remove the plastic cover at bottom front of washer.
You should see the filter at the right hand side.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thanks.
Posted on Nov 21, 2009
barkencoa
  • 3463 Answers
SOURCE: water goes in then straight out of the waste pipe
The waste pipe is probably too low, this is letting the water syphon out.
Try lifting the outlet pipe higher up, this should solve the prob.
There is a line on the back of the washer, which incates the min hieght for drain outlet.
Thanks.
Posted on Nov 24, 2009
Accessing control panel on a Kenmore Elite model #42192900
Did you check on the inside of the door frame... lots of times you need to remove the front first .
Apr 22, 2018 | Kenmore Washing Machines
LG Tromm front load washing machine WM2688HNM, does lid on this washer remove differently from other LGs? Trying but won't budge HELP SOS!! How do I remove lid to get to inner works of this machine?
You need to remove the front panel there’s 2 screws behind that panel once you remove those screws the top from the front push it towards the back and slide it up at the same time
I’m happy to help further over the phone at https://www.6ya.com/expert/george_106a9535a98aec8a
Nov 18, 2017 | LG Washing Machines
Can't get the top of a Hotpont Aquarius WML520
I've just taken the top off mine, unscrew the 2 screws at the back then push the front with the palms of your hands rearwards, it takes some doing and you may need to get your fingers underneath the lid at the back and just give it a good pull!!
Jan 21, 2013 | Hotpoint Aquarius WD63 Front Load...
I cant get the back off hotpoint aquarius wma56 to change bearings
the back does not come off but the front does.
remove top lid ( two hex head screws on side of lid, under plastic covers)
take out dispenser drawer. reveils 3 screws
remove screws and slid front panel to the right (reveils 2 scrwes left and right)*
remove bottom kick strip ( reveils 2 more screws)*
undo door seal retainer, and remove 2 screws holding on door lock.
now remove 4 screws holding on front panel.*
panel now lifts up and off.
Jun 25, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
My Hotpoint WML540 door lock light flashes and clicks 3 or 4 times then wont do anything? Is it a fault with the lock (which looks easy to replace) or something more serious?
First try unplugging the washer machine for about fifteen minutes or so. Then plug it back in. If the problem still there, then it is the board. It can be fix.
May 05, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
567 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
