Question about iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba Stops I've had a Roomba for about 2 months. Lately, it runs for about 45 secs, then stops, makes a two-tone (descending) sound, and flashes the CLEAN button while the STATUS button is red. I've emptied the dustbin on it. Can you help? I am seeing the same problem on my roomba today. I cleaned all that I could., the brushes, the pins on the sides and all that and it still gives the same problem..Any other fix?
  • 32 Answers
Run your roomba through a self diagnostic test. I have posted the link below. Tell me your findings. http://mysite.verizon.net/gsplews/Diagnositic-Tests_Proc.v.0.5.htm
Posted on Jun 15, 2009
Roomba 560 fully charges. Runs for 2 seconds fully green and just stops. And lights up red.????
Set him on the floor, after powering him off and then back on, and press the "Clean" button three times. This will reset him.
Sep 11, 2014 | iRobot Roomba 560 Robotic Vacuum
Roomba 530 is clicking when running then stops
The battery is not charging and has died a noble death. Buy a new battery.
Nov 28, 2013 | iRobot Roomba 530 Robotic Vacuum
My roomba 530 runs in a circle and does not move forward. After 2 minutes it stops with 11 beeps and a flashing red light to the left of the power button. It has no clicking noise. Does anyone know what is...
Hey'
This means Roomba is not registering obstacles. Roomba may be stuck in one place.
Roomba may be in extremely large room, try setting up virtual walls to create smaller area.
If Roomba is not in a large room, tap Roomba's bumper to confirm it is properly working.
Hope this helps
Avi
Nov 09, 2009 | Roomba Robotic Floor Bagless Vacuum
IRobot Roomba Dirt Dog sounds weak and stops
Generally the unit will beep or play the "uh-oh" tone or do something. I wish I could tell you what's going on with this Dirt Dog, but it's not communicating the problem. The best thing to do would be to give us a call when you have the robot with you. That will enable us to do any necessary troubleshooting as well as set up any orders that might be necessary. We're here M-F, 9a-7p, and Saturdays 9-6, EST. 1-877-855-8593 Look forward to hearing from you!
Aug 25, 2009 | iRobot 1100 Dirt Dog Bagless Robotic...
Roomba starts and stops.
try pulling the battery out and holding down on the power button for 5 secs. if this doesn't fix the problem--you need a new battery.
Jun 06, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Roomba can't make a turn and stops working
make sure the wheels are not clogged with something like hair or carpet strands if that don't work it sounds like your right turn sensor might be bad.call the roomba people or go to roomba.com and look for your model and find troubleshooting
Apr 28, 2009 | iRobot Roomba 410 Robotic Vacuum
Good Morning, My Roomba makes a banging sound and the brushes don't turn. It stops after about two minutes. Thank you & regards, Judith Halls
Hi Judith,
after removing and cleaning your Roomba's brushes & bearings (see the manual for instructions), try running the unit without the dust bin. You can watch the main brush while the Roomba runs. If it's not turning, it's time to call support.
Fembot
Feb 27, 2009 | iRobot Roomba 530 Robotic Vacuum
Roomba Stops
I just fixed mine by cleaning the shaft that the spinning brushes is on. I used an eyeglass screw driver to tke out the screw. it is running great now. I didn't realize my brushes werent spinning at the time of my post. Cleaning this part seemed to have fixed the problem.
Jun 03, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba just runs in small circles
It's little brain is having a seizure. Really! It's a programming fault. If you look on the machine, usually the bottom, you'll find a 1-800 number you can call and they have a solution for it. It's fairly common for this to happen and it cannot be solved with any mechanical solution.
Jan 26, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot Roomba 4210 Bagless Robotic Vacuum Logo
570 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
