Question about Compaq S 200 Flatbed Scanner
Scanner does not stop....
The scanner moves back and forth ok. But when it goes back, it keeps trying to go back, causing it "bounce" and will never stop unless unplugged from outlet. any help greatly apprecitated!
  • James Jones Aug 22, 2006
    i havent the manual. not sure how to reset it. its the compaq s200
  • Anonymous Feb 09, 2008
    i have same problem with my hp psc 2410 photosmart scanner i don;t know waht to do .please help. emil-impressive_cba@yahoo.com
    Problem Solver:
  • 6 Answers
Try resetting your scanner, check the manual for the directions.
Posted on Aug 22, 2006
IS showing L 1 in the screen and stop working
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Sep 12, 2010 | Sharp AL-1540CS All-In-One Laser Printer
I have a AL 1655 CS and it stopped working! I've stopped it and started it, changed the cartrige and open and closed dorrs!! It says System Error [L1-00] what next?
Aug 16, 2010 | Sharp AL-1655CS Laser Printer
HP Laserjet 3330 Multifunction monochrome printer,copier,scan and fax. This machine will warm up, and after it reads "scanner lamp warming", the scanner lite lights up, the carriage moves back and forth,...
This type of problem is usually caused by dirty mirrors in the scanner. After a few years of use the mirrors and lenses in the unit will get a fine coating of dust particles on them. The dust interferes with the scanner initializing the optics. When this happens the unit displays the Scanner warming up message on the screen and keeps trying to move the scanner assembly to get a good reading from the pickup. To solve the problem you will need to disassemble the scanner portion and clean all of the mirrors with window cleaner and a soft cloth or q-tip. To get dis-assembly guides just do a google search for the 'scanner warming up' error.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 04, 2010 | HP LaserJet 3330 All-In-One Printer
When I turn on my 2410 printer the hourglass stays on endlessly.
try uninstalling and reinstalling
Don't forget to rank the advice!
http://www.aa1consulting.com
Jul 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
The scanner bulb goes back and forth about an inch in hp 3330 prt
The scanner blub mirror needs to be cleaned and possibly the underneath side of the scanner glass. The scanner is not finding the marks to make it function correctly.
May 15, 2009 | HP LaserJet 3330MFP All-In-One Printer
Sharp AR-337 COPIER SCANNER LOCKS UP
Do you know how to get into the simulation mode
Like Clear ,exposure mode, clear , interrupt, are you familar with the service manual procedures ?with Sharp, are you an independant dealer. ? into simulation mode and run the Scanner mode, make sure it run back and forth ok, lubricate the track, if it gets stuck it will produce and error or stop running.
Before i can help you I need to know your expretise.
Mar 08, 2009 | Office Equipment & Supplies
Scanner feaking out
Unlock the scanner !
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=11463
Dec 19, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
Scan head/carriage not parking in one spot -- keeps moving.
The scanner is having trouble getting its "white reference" usually due to dusty mirrors, but can also be the bulb losing brightness. These are not a easy machine to pull apart if your not used to it.
Good colour laser MFP, depends on volume of prints and remember colour dont come cheap, but dont use refill cartridges, Kyocera and Oki both have good Models
Dec 01, 2007 | HP LaserJet 3320mfp All-In-One Printer
Laser Jet 3300
Hi, when you lift the cover where the flatbed glass is can you see the scanner trying to move back and forth? Also you might want to check and make sure the scanner lock didn't get moved to where the scanner just goes back in forth ? Are you getting any error codes?
Nov 29, 2007 | HP LaserJet 3300 All-In-One Printer
Compaq S 200 Flatbed Scanner Logo
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Computer Links
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
