Hi my laptop aspire 1362 NLC is turn off after 2-3 minutes it will be turn off automatically.plz solve my prolem.
5 Suggested Answers
Ravege
  • 327 Answers
SOURCE: bluetooth prolem on acer aspire 5720
welcome to FIXYA
Set up a Bluetooth enabled deviceTo set up a Bluetooth enabled device, you need to do three things:
  1. Add a Bluetooth adapter to your computer.
    This is usually done by plugging the adapter into a USB port. (If a Bluetooth adapter is already built in or attached to your computer, ignore this step.)
  2. Set up the device so that your computer can find it.
    To do this, you must:
    • Turn the device on.
    • Make it discoverable.
    To learn how to make a device discoverable, check the information that came with your device or go to the manufacturer’s website.
  3. Install the device.
    To install most devices, such as a mobile phone, keyboard, mouse, or personal digital assistant (PDA), you can use Bluetooth Devices in Control Panel. If you have Bluetooth wireless technology installed on your computer, follow these steps:
    To install a Bluetooth enabled device
    1. Click the Start button getcontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=signed1, click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
    Click Add, and then follow the instructions.
i hope this helps you out have a good day :)
Posted on Jul 19, 2008
firesnake09
  • 2923 Answers
SOURCE: external widescreen monitor for laptop
You have to make sure that the laptop could provide the required resolution of the monitor, because of the laptop could only give1280 x 1024 and the monitor is requiring 1600 x 1024, then expect that you will get that result.
Try changing the resolution of the laptop. Set it to 1024 x 768.
Have a good day!
Posted on May 18, 2009
benwabnick
  • 2404 Answers
SOURCE: why my acer laptops 2303 nlc date changes every
Go into your BIOS and change the date there and the save changes and exit. Hopefully on the reboot when you get into windows the dtae will read prroperly If it does then turn off the laptop and then turn it back on and see if the date is still reading properly. If it does then you know it was a BIOS issue.
If the date still doesn't read properly then you know that the BIOS battery is weak and not holding memory and so the battery would need to be replaced.
Posted on Aug 06, 2009
  • 1542 Answers
SOURCE: Hi, i got acer aspire 4930
Hi
not knowing what operating system your are running i cannot navagate you there so go to control panel power options and hopefully you will see how to tell your computer when to sleep when to turn off hard drive and monitor etc so click on the when to sleep button and extend the time to what you think you may need and you can do the same for the hard drive because i think they are normally set to cut off after half and hour by default
hope this helps
have a good Christmas
Posted on Dec 18, 2010
My acer 5720 keeps overheating when playing games and shutting down any tips to overcome this .
  1. Buy a laptop cooler
  2. put your laptop on a leveled surface such as a table
  3. do not put your laptop on your bed while its on, that causes the laptops vents to block and no air can be sucked in eventually the laptop gets heated and automatically turns off
  4. plz dont forget to vote if i solved your problem :)
Sep 05, 2009 | Acer Aspire 5720 Notebook
I m having acer Aspire 1362 NLC laptop. Its battery life had shelved. I obtained similar configuration battery i.e. BTP 58AI , Li-ion.after inserting into the laptop although power to charge battery was...
I think your charger(battery) is not giving the right amount of charge and most probably its not of the same type which you should exchange from where you bought it for a compatible battery. Best would be to take ur Laptop and physically check that its charging because I doubt your laptops charging capacity has gone because it was charging your old one................sodeep
Jul 30, 2009 | Computers & Internet
I want to dawnload windows xp
You can't just download software, that is illegal. You can purchase Windows XP in every computer shop.
Jun 17, 2009 | Acer Aspire 6920-6621 Notebook
Vista to xp professional
Addition to previous post: You can also try Safe Mode to correct your video issues, too. Restart your computer or turn it on. Count to three, then start rapidly tapping the F8 key on the keyboard. Choose Safe Mode or Safe Mode with Networking. Let it load up. Try info from previous post in Safe Mode.
Feb 22, 2009 | Acer Aspire 5315 Notebook
Aspire 7720-6569 laptop automatically shutoff and won't turn on.
hi,
Please try following DIY
1.Please remove the battery and then press the power button for a minute without connecting the adaptor then refix the battery and check whether it is working.
2.Check after removing the battery with adaptor only.
3.If then also it is not working check whether the num lock is responding if yes then this is a RAM refixing or changing issue otherwise a motherboard issue if the adaptor is working fine.
Feb 21, 2009 | Acer Aspire 7720-6569 Notebook
Acer aspire 4710
If you have getting dull display it's a inverter problem in laptop.or if you not getting no display(screen) then two types of problem in your laptop please try to solve that problems.
  1. Please check RAM is working or not.
  2. If RAM is good then it's a Mother Board Problem.
Thanks
Rammohan
Oct 06, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 9304 lan connection problem
is your operating system vista? update your operating system in the internet / microsoft so that it will download all the patches it needs to make your computer works better
Apr 10, 2008 | HP Pavilion dv6000z Notebook
Tv wont turn on
i have a nlc-3204bc funai hd ready, the stand by light keeps flashing red on and on, can not switch it on
Feb 17, 2008 | Televison & Video
Aspire 3002 Nlc note book DVD Comboo is not recognised
Hi, sorry you might need to explain a little better, but i will try. The DVD Combo drive doesnt need any drivers to work, the only thing you need is somthing like powerdvd to watch films, if the drive is not reading cds or dvds and in device manager you have a yellow tag, probably next to Primary ide its windows drivers, but if you could explain in a little more detail will be happy to help.. All the best John
Feb 11, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
