Panasonic SDR-S70 Camcorder Logo
A
Anonymous Posted on Feb 18, 2012
My panasonic SDR-S70 keeps coming up with check card every time you turn it on and does not allow you to record how do i get rid of the problem??
5 Related Answers
A
Anonymous
  • Posted on Mar 18, 2007
SOURCE: "check card" error
if you are using a sdhc card, a regular card reader will not recognize it... need to buy a special sdhc card reader... i found out the hard way
Anonymous
  • 10594 Answers
  • Posted on Jan 30, 2009
SOURCE: Manual SDR-H40
Hi
Please click HERE to download instruction manual of SDR-H40
Thanks.
Anonymous
  • Posted on Feb 04, 2009
SOURCE: SD CARD
Normal size SD card could do. http://www.dc-battery.co.uk/index.php/cPath/1467_1557
Anonymous
  • 3 Answers
  • Posted on Feb 08, 2009
SOURCE: Need Panasonic SDR-H40 software download
You can connect to any computer with a USB port. It appears as a hard drive after you tell the camera to connect (in the menu). Then just copy the .mod files to a spot on yor computer; there will be one for each movie clip.
Your next chore is changing them into MPEG files at the correct aspect ratio. If you shot in 16:9 they will be squished together unless you use the SDCopy freeware utility to set the widescreen flag. It also renames and downloads files for you, and it's small. There's a link from this tutorial page, which also explains a lot about aspect ratios and such:
http://www.elurauser.com/articles/JVC_Everio_mod_files.jsp
omtronixom
om sharma
  • 172 Answers
  • Posted on Mar 18, 2010
SOURCE: My panasonic sdr-s10 mentiones a ' card door open'
Card door switch is broken
tip
Convert/Import, Edit Panasonic SDR MOD Files to Mac, iMovie, FCP
Panasonic SDR camcorder mainly contains SDR-H and SDR-S two series. Most Panasonic SDR series camcorders record videos in MOD MPEG-2 which is a standard definition video format, such as some popular Panasonic SDR camcorders: SDR-S26, SDR-S10, SDR-H60, etc. However, there are also some Panasonic SDR camcorders recording videos in AVCHD /MPEG-2 like Panasonic SDR-H86, SDR-S45, SDR-T56, etc.
To get more details of Panasonic SDR camcorders, you can check the list of most popular Panasonic SDR series camcorders as follows:
Panasonic SDR-H Series: SDR-H18, SDR-H40, SDR-H60, SDR-H80, SDR-H85, SDR-H81, SDR-H86, SDR-H200, SDR-H80S, SDR-H80K, SDR-H80A, SDR-H80R, etc.
Panasonic SDR-S Series: SDR-S10, SDR-S26, SDR-S50, SDR-S45, SDR-S150, SDR-S25A, SDR-S26K, SDR-S26R, SDR-S7K, SDR-S7A, SDR-S7R, etc.
Panasonic SDR-T and other Series: SDR-T50, SDR-T55, SDR-T51, SDR-T56, SDR-T50K, SDR-SW21S, SDR-SW21D, SDR-SW21G, SDR-SW20S, etc.
"I have a SDR H85 panasonic camcorder and can't seem to get the videos to download on my mac. Any suggestions?" ---from Yahoo Answers
Actually, for Mac users, you may have these similar problems when you want to import Panasonic SDR video to Mac, or edit these video in iMovie, or FCP, FCE. Because some Panasonic SDR series camcorder are not compatible with Mac, so you cannot directly import these camcorder videos to iMovie, Quicktime, or FCP . See here to know iMovie '09: Camcorder Support http://support.apple.com/kb/ht3290
Now, a professional Panasonic SDR Video Converter for Mac is specially designed to convert MOD(MPEG-2) to MOV, MP4, AVI, DV, H.264, 3GP, 3G2, M4V, WMV, MKV, etc on Mac. It supports converting MOD, TOD, AVCHD MTS/M2TS, etc to Mac, iMovie, Quicktime, iDVD, FCP, FCE, iPad, iPod, iPhone, Blackberry, PSP, and other popular mobile phones. This Mac MOD Video Converter can also help you extract audio from your Panasonic SDR videos to MP3, MKA, WAV, M4A, AC3, OGG, AAC, WMA, etc.
Instruction for you to convert Panasonic SDR video to Mac, iMovie, FCP, etc step by step
Step1: Install and Launch MOD Converter for Mac
Step2: Add Panasonic SDR Video on Mac
Click "Add File" to upload your chosen Panasonic SDR video to Mac MOD Video Converter after you launched it.
Step3: Set Output Video Format for Mac, iMovie, Quicktime
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, Quicktime, iMovie, FCP, FCE, etc.
Step4: Convert Panasonic SDR Video to Mac
Press the "Start" button to convert Panasonic SDR MOD/MPEG-2 files for Mac, iMovie, Quicktime, FCP, etc. After conversion finished, you can edit converted Panasonic SDR videos with iMovie, FCP, FCE, iDVD, etc.
More details: If you want to convert Panasonic SDR AVCHD/MPEG-2 files to Mac, you can click here to get more info of AVCHD Converter for Mac.
Related: How to get video off camcorder to Mac OS?
How to convert AVCHD m2ts/mts/ts files to MP4, MOV, DV, etc on Mac?
on Nov 05, 2010 • Computers & Internet
tip
MOD Files on Mac OS, How to Play Camcorder MOD Files on Mac
Similar to TOD, MOD is a kind of recording format being used in digital tapeless camcorder like JVC, Panasonic, Canon. MOD video format is comparable to XDCAM EX, HDV and AVCHD.
MOD is used exclusively for standard definition video files, while TOD is used for high definition files. Both MOD and TOD are file-based formats that are stored on a random-access media. Directory structure and naming convention are identical except for extensions of media files. Standard definition video is stored in MPEG program stream container files with MOD extension; in most other systems these files have extension MPG or MPEG.
The following list is about JVC, Panasonic, and Canon MOD camcorders.
JVC MOD camcorders
* 2004: GZ-MC100 (SD), GZ-MC200 (SD)
* 2005: GZ-MG30 (HDD), GZ-MG70 (HDD)
* 2006: GZ-MG37 (HDD), GZ-MG77 (HDD), GZ-MG505 (HDD, SD/SDHC card)
* 2007: GZ-MG130 (HDD), GZ-MG155 (HDD), GZ-MG255 (HDD), GZ-MG555 (HDD, SD/SDHC card)
* 2008: GZ-MS100U (SD/SDHC card)
* 2008: GZ-MG7230 (30 GB HDD, MicroSD)
* 2009: GZ-MG630 (60 GB HDD, MicroSD), GZ-MG670 (80 GB HDD, MicroSD), GZ-MG680 (120 GB HDD, MicroSD)
Panasonic MOD camcorders
* 2003: SV-AV100 (SD card)
* 2005: SDR-S100 (SD card)
* 2006: SDR-S150 (SD/SDHC card)
* 2007: SDR-S10 (SD/SDHC card), SDR-H18 (HDD, SD card), SDR-H200 (HDD, SD/SDHC card)
* 2008: SDR-H20 (HDD, SD/SDHC card), SDR-H60 (HDD, SD/SDHC card)
* 2008: SDR-S7 (SD/SDHC card)
* 2008: SDR-SW20 (SD/SDHC card)
* 2009: SDR-SW21 (SD/SDHC card)
* 2009: SDR-S26 (SD/SDHC card)
Canon MOD Camcorders
* 2008: FS100 (SDHC), FS10 (SDHC), FS11 (SDHC)
* 2009: FS200 (SDHC), FS21 (SDHC), FS22 (SDHC)
For Mac users, when they want to watch MOD files shot by JVC, Panasonic, Canon camcorder with iPad, iPhones, iPods, in Quicktime, in iMovie, in iTunes, or on PCs, etc. They may be annoyed that how to upload MOD files to Mac and play MOD video on Mac OS.
Now, there are tutorial and guide for you below will help you solve these problems.
1. Connect your JVC, Panansonic, or Canon camcorder to your Macs or PCs with cable USB or Wifi.
2. Turn on your camera and select the mode of camcorder like PC mode. iMovie on Mac will open automatically the Import Window.
3. You can review your video or select "Import All"and select your JVC, Panasonic, or Canon camcorder on the computer screen and click "OK."
4. All camcorder MOD videos will have the file extension "MOD" Once the backup is complete, then close the program.
After uploading your camcorder MOD files to your PC or Mac, you can use
a MOD Video Converter for Mac to convert MOD files to Mac firstly, and then you can play JVC, Panasonic, or Canon MOD files on Mac. More information about how to convert MOD files on Mac and edit MOD files on MacOS you can click here.
on Sep 13, 2010 • Computers & Internet
Cannot re use a formated SDHC card in Panasonic HDD camera.
after formating the card u can re use it ,somthing is wrong with the card.Try once again after cleanning the card and card reader.
tip
How to Upload/Put and Play JVC, Panasonic, Canon Camcorder MOD Files on Mac
JVC MOD camcorders
After uploading your camcorder MOD files to your PC or Mac, you can use a MOD Video Converter for Mac to convert MOD files to Mac firstly, and then you can play JVC, Panasonic, or Canon MOD files on Mac. More information about how to convert MOD files on Mac and edit MOD files on MacOS you can click here.
on Aug 12, 2010 • Computers & Internet
Panasonic SDR-H40-Date/time missing when transfering video to PC
get a capture card, an AV cord ( red, yellow and white cord) and record it onto the computer. This will push the date and time stamp onto the video. There really isnt any other quick solution :-(, unless you sport 800$ for a highend camera, then all harddrive cameras have this problem.
"check card" error
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
