Question about Schwinn Cycling
Schwinn 126 exercise bike resistance no longer changing (gear)
When changing gears, resistance is not increasing
SOURCE: battery missing for exercise bike
I have a Schwinn airdyne (model AD-3) that uses a button type battery in the count-down timer, which is above the work load indicator or the 'speedometer'. According to the manual I was given with the bike, it utilizes a 1 1/2 volt watch - type battery (LR44, A 76 or equivalent).
Hope this helps.
Posted on Apr 23, 2009
  • 921 Answers
SOURCE: How do I operate 10 speed road bike?
the gear lever on the left controls the front derailleur which will have two different size sprockets...when you first start to ride you want it on the smaller of the two. The gear lever on the right controls the back or rear derailleur with a gear cluster of five small to increasing larger sprockets...when first starting to ride you want that on the largest one .....five in the rear and two in the front (5x2=10 variable speeds to chose from). as you increase speed slowly lift up (because this lever will be located down) on the right shifter to help maintain an even speed to help you go faster..when your on the smallest gear in the back and want to go even faster then pull down on the left shifter to go to the larger sprocket you are now in ten gear.When coming to a stop reverse the shift levers and repeat...if the chain rides off the sprockets when shifting especially in the front derailleur it means the shift guide is bent to far to one side or you derailleur needs adjusting same goes for the rear..there are two little screws stops with springs that you use to make these fine adjustments. My family owned a Schwinn shop, i was a mechanic for a good 12 years and i havent heard the name La tour in a long time i owned one myself and have a traveler still today. Tip..keep chain lubed, WD-40 will work fine, and also lube the gear cables with a light grease...also dont rotate the handle bars up for easier comfort because in an emergency stop situation all your weight will transfer to the brake levers and you fly forward over the handle bars.
Posted on Oct 03, 2009
  • 108 Answers
SOURCE: No resistance when I pedal the stationary exercise bike
I looked into this thinking is must be a simple belt, or tention wheel, but these devices are much more complex than the average exercise machine. See the Recumbent selection here.
It appears that the tentioning device is a magnetic brake.
This would require that it be plugged into a power source and programmed to provide a desired tention.
I've never used one of these so I can't say what kind of programming options there are or where they are found.
Hope this helps.
Richard.
Posted on Dec 07, 2009
SOURCE: the resistance belt on my Schwinn 205p recumbent
http://www.fitnessrepairparts.com/equipment/SelectEquipment/100 lists all the parts for this model
Posted on Jan 03, 2010
agent91
  • 2100 Answers
SOURCE: how to use thumb shifters on a 21 speed Schwinn Highplains bike
OK, for a beginner in the world of 18 speed bikes, put the chain on the big sprocket up front, it should be about 46 teeth, make sure it is center and doesn't make noise, if it does, adjust it just a hair either way, now, the rear, put the chain on the big sprocket in the rear, make sure the front didn't start making noise, if it did, adjust it again. You are now ready to take off, in low gear, as you start out, it is easy to pedal, soon you will be peddling air, shift into second gear in the rear only, don't touch the front. Just a little push with the thumb will make it shift, now were going faster, easy peddling, shift into 3rd, then 4th, etc, coming to a stop, down shift the back sprocket back into low gear (big sprocket) and be ready to take off again. Soon you will be shifting that thing like a Ferrari! The front sprocket, will be used for moderate terrain, wheelies, and mountain climbing, that will come later, learn how to shift the rear first. As each gear climaxes, hit the shifter, it will get smoother as you go, and keep the chain quiet, no climbing on the next sprocket or falling out of gear. Hope this helps.
Posted on May 03, 2010
I've had a Schwinn 270 recumbent bike for 4 years. The resistance is completely gone. Suggestions?
I suggest you check the troubleshooting guide in the manual, as there are several causes for the resistance not changing. http://download.nautilus.com/supportdocs/AM_OM/Schwinn/SCH.270-MY17.AM-OM-W.EN.pdf I would suspect that no resistance at all might have to do with a failure of the servo motor, which appears to control resistance through interaction with magnets on the wheel.
Secondly, you can try contacting Schwinn Fitness: Customer Service
If you still can't figure out the problem you may need in-person help. Find a place that sells Schwinn exercise bikes or see if someone at a local gym that has recumbents can help you. The bike is apparently made by Nautilus.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Dec 06, 2017 | Schwinn Cycling
Does the schwinn recumbent 270 bike have a battery? It has an AC adaptor. The resistance will not increase when i press the higher resistance button.
It does not have a battery. Your resistance motor is most likely faulty. The only thing is, with schwinn, you will most likely have to replace the resistance motor, the console, and the wiring. All of this is very hard to find and will probably be more of a hassle than it's worth.
Jun 10, 2017 | Schwinn Exercise & Fitness
Life gear exercise bike
This bike looks to be of the Lemond Revmaster series.
first, dial the resistance knob back until the leather break pad is no longer touching the flywheel. Get down on the floor and postion yourself between the flywheel and pedal cranks. Slowly turn the cranks arms and listen and feel for a roughness in the bike.
This has bike has bearings and a belt. It should not make any noise.
Now with the right pedal at a 2:00 position tighten the resistance knob down all the way so the flywheel will not turn. Then get on and push very hard on the right pedal. If the belt is loose, the pedal will move. Austin Fitness Rentals Rent Commercial grade Fitness Equipment in... ">
May 16, 2014 | Exercise & Fitness
My schwinn 460 elliptical resistance cannot be changed
see the following details. God bless you
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced
Dec 04, 2012 | Schwinn 460 Variable Stride Elliptical...
My Schwinn doesnt gain speed
axel bearing either is bad or needs grease or not adjusted correctly
Oct 08, 2012 | Schwinn 700c Mens DSB Dual Sport Bike
The tension does not increase on my schwinn 220
adjust the magnet very well, tigh the bolts if there loose the tension will be not o.k
Apr 24, 2012 | Schwinn 220 Recumbent Exercise Bike - 2012...
Cycling Logo
24 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
