Problem. I have a Konica Minolta Bizhub C350 Copier Machine and it displays a message on the LCD reading Error C0510 I can't copy or anything. Help!.
    Problem Solver:
  • 17 Answers
Open right side door of your machine and check check all gears are working properly this code belong to main motor
Posted on Nov 05, 2008
What does error code C-0510 mean?
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
Sep 08, 2014 | Konica Minolta Bizhub 8031 Copier
Bizhub C350 - C-0510 error code how fix copier
Turn OFF the copier.
Press and keep pressed the Uitlity key and turn ON the copier.
Keep pressed the Utility key when will Trouble reset message displayed.
Release the Utility key,touch the message and turn OFF the copier.
Wait 1 minutes and turn ON.
Apr 12, 2013 | Konica Minolta DiALTA Di200 Copier
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
Konica minolta bizhub 363 error message c-2201
remove the toner bottle let machine thur its paces when it says install toner bottle install correctly
Feb 24, 2012 | Minolta Office Equipment & Supplies
Hi, I have KONICA MINOLTA Bizhub 160 and there occured Eroro C0510. Do you know how can I solve this problem?
C0510: Abnormally Low Fusing Temperature
turn off machine and hold down the utility button while powering up until machine complete it's cycle
Dec 22, 2010 | Konica Minolta DiALTA Di200 Copier
Error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Jan 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
LCD Display displays Error C0510 Can't do anything about it.
low temperature issue. There is a trouble reset procedure that should be performed by a Minolta tek
Oct 26, 2008 | Office Equipment & Supplies
Konica Minolta Bizhub c350 error code c-0510. What is it? How do I fix it?
Sep 25, 2008 | Office Equipment & Supplies
207 people viewed this question
jasbo
jasbo
