My hp g61 laptop wont turn on
The laptop power jack lights when adaptor is put in it ,but nothing comes like powering
4 Suggested Answers
kd6rhd56
  • 400 Answers
SOURCE: HP pavillon dv6000 boot troubleshooting !
First take out the battery, and run it on AC power alone , if it runs ok its the battery that has died, it you still can run the laptop with orw/o a bttery then the internal power supply has died.
Posted on Jul 14, 2009
  • 3 Answers
SOURCE: my laptop won't power on (EliteGroup G320 PC Notebook)
Sounds like the infamous electrolytic capacitor plague (see http://en.wikipedia.org/wiki/Capacitor_plague -- also read the discussion page)
In the early years of this century chinese spys stole a formula for novel electrolyte from a leading Japanese chemical company but unfortunately they only copied page 1 of the two-page recipe. The incomplete electrolyte went into many millions of capacitors reducing their life span dramatically. I understand these capacitors were made until 2004. That's about the time the G320 was manufactured, at least mine.
I opened and disassembled everything, I saw some "swollen" 1500uF/6.3V capacitors, replaced them and the G320 would start again.
This may sound easier than it was, however. I live in a country where computers aren't made no more and spare parts are hard to find. The G320 has 4 of the above caps in upright position and 4 placed horizontally. I could only get some larger types that do fit horizontally but not vertically. Thus I had to replace a bad vertical one by one of the remaining good horizontal ones and then replace the horizontal ones by the bigger ones.
Warning!
If you re-assemble your G320 make sure you use the shortest 3 screws for the the points where the upper cover is fastened to the metal sheet frame that presses the cpu against the heat sink. If you use a longer screw (which I did) you may experience that a destroyed 4x56 ohms resistor network chip on the mainboard can also be hard to be relaced in non computer producing countries.
Mittwoch
Posted on Nov 14, 2009
SOURCE: advent 5421 wont power up,iv bought new power
when i turn my laptop on the advent logo comes on and the bar at the bottom goes up 3 quaters but then stops and thats it. the screen freezers.
Posted on Jan 03, 2010
0xc190003 HP b010
"Gondo" <nowingspaanspam@yahoo.com> wrote in message
news:fsv880din9khpu7e9p8olvrc8uj1u1uj3o@4ax.com...
> This has been an ongoing problem with this laptop, and now I can
> hardly get it to power up at all.
> First, the AC/DC power adaptor jack in the back is very loose and
the
> power is lost intermittently when you move the jack around on the
> receptacle.
> Once the green power light does come on, you press the power switch
> repeatedly to the left to turn the laptop on and nothing happens.
Only
> by the combination of wiggling the power adapter jack around while
> pushing the power button repeatedly can you maybe get lucky and get
it
> to start up.
> I was just wondering what else might be bad internally besides the
> power adaptor jack. Possibly the connection to the power switch or
the
> switch itself? The AC/DC adaptor was replaced recently, so I'm
pretty
> sure that isn't the problem.
> It appears it will need replacement parts, so I'm looking for
> recommendations on where to find the applicable parts online.
To Fix Your Hp Issue,In Case You Still Having Problem Then Follow Us For On : HP Support
Feb 26, 2013 | HEWLETT-PACKARD Hp Ac Adapter Power...
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
My hp pavilion dv6-2117ax laptop won't power up (no power light on where adaptor meets laptop). Replaced power adaptor / charger and laptop powered up and operated for a day and then next day woul
The laptop probably isn't charging. Could be a bad d/c connector on the laptop or the battery is bad. Remove the battery and plug in the a/c adapter and see if it powers on. Wiggle the a/c plug in gently while pressing the power button on the laptop. It powers on and off briefly then I'd say it's the d/c jack on the laptop, bad sodder joint.
Dec 04, 2012 | Computers & Internet
Laptop shows thunderbolt to show its connected to power adaptor, but wont turn on at all. BTW, i replaced both the power cord and the battery, and it still wont turn on- no noise or fan, nothing at all....
The motherboard may be bad. Make sure the harddrive is securely connected. Reseat the RAM boards. Verify you are getting DC voltage out of the adapter tip by measuring it with a volt meter for around 19 Volts DC. If it's good, then check the power jack and verify you get a blue light around the jack when you plug the adapter. If you verified you're getting power successfully and still doesn't come on then the motherboard is bad.
Nov 01, 2010 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
My HP will not turn on and the charge light wont come on either... would it be my ac power chord?
hi
you might be right.try testing it with another hp pavillion power cord.if you are still experiencing this problem then your power pack is faulty.and you should have it changed
Goodluck!!
Feb 17, 2010 | HP Pavilion ze2000 Notebook
Laptop won't power up
if there a battery, try to remove the battery and put the charger..try to check if the power come or not come.
second, if not come the power without battery..you must check first the charger output,working or not working..and third, check the power jack...thats the last...
Jan 04, 2009 | Compaq Presario Notebook
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
Lack of Power
1) Battery can be derect.
2) Power adapter can be defect.
3) Power jack can be defedt.
In about 50% of such cases it is the power jack.
Bring it to a repair shop. They can check very easily the battery and the adapter to find out the problem.
Nov 17, 2008 | HP Computers & Internet
No power
Do you know if the other battery you tried had any charge in it?
If the battery was charged then it will not be a power jack or adaptor problem. As far as changing power jacks it is not for the faint of heart. I have done several with success on them all but it is not easy. If you are comfortable with opening the laptop go ahead and check all the connections on the inside. Sounds like a motherboard problem
Nov 20, 2007 | HP Compaq Presario V2000 Notebook
Help
sounds like you have an intermittent problem with your AC adaptor or dc input jack. Does the light on the AC adaptor light up when you plug it in? If it does then your dc input jack may be faulty. If the light on the ac adaptor does not light then replace the ac adaptor. Good Luck!
Sep 16, 2007 | Toshiba Satellite M30-S350 Notebook
Computers & Internet Logo
216 people viewed this question
David Payne
David Payne
