What's your problem?Am using old ISA Sound card,it locks up when a tape backup unit is used on the system
2 Suggested Answers
SOURCE: Sound card problem
i have a sound card an i installed but driver s not installed ,an i need the right driver
Posted on Apr 24, 2008
Reassembled my componet stereo but don't get sound from Tuner or Casset Tape Deck
It could be a bad interconnecting cable OR the fact that the connector inside the unit has broken solder joints. That is why these types of units that I have worked on often have many problem in that the wave soldering used in manufacturing is not made for a lot of abuse or thermal cycling. The problem can be solder by getting into the unit and applying the correct amount of solder onto the connector using good old Kester 44 not the cheap other stuff.
Dec 22, 2012 | Audio Players & Recorders
Tip
Backup Best Practices
Here are some of the best practices to take into consideration in any backup & recovery system:
  • Usually perform system state backups of your servers frequently. Each computer on a Windows network has a corresponding computer account in Active Directory. Like a user account, the computer account has an associated password. The difference is that the password is assigned, and periodically changed, by Windows. If you try to restore a system state backup that is too old, the computer account password that is stored in the backup will no longer match the password that is bound to the computer account in Active Directory. As a result, the machine won't be able to participate in the domain. There are workarounds, but it is usually easier to just make frequent system state backups of your servers, & use these backups to recover the servers when needed.
  • Always backup the data, the server's operating system, & the applications installed on the server. Although it is true that, if a server fails and you need to perform a full recovery, you can reinstall the operating system & the applications & then restore any data. However, time is of the essence when trying to recover from a crash. It is much faster to restore everything from backup than it is to manually install an operating system and a set of applications. More important, it is often difficult to manually configure a server so that it matches its previous configuration. Backing up the entire server ensures that its configuration will be exactly as it was before the crash.
  • Periodically test your backups to make sure you are able to use them for recovery when the disaster strikes. Always remember that we perform backups in order to be able to restore from then when we need to. So, we have to make sure our backups are usable.
  • For some applications (for example, Microsoft SQL Server, Microsoft Exchange Server, Lotus Domino Server, ... etc), a file-level backup is insufficient. These applications usually utilize open databases that need a special backup agent to back them up consistently while they are being in-use. Usually make sure that you are using the correct backup agent needed by your application.
  • While you should keep backups off site, consider waiting until the end of the business day to remove the previous night's tapes from the building. This way, if your server fails early during the day, you will not have to wait for hours till you can get the tapes on-site again & start the recovery.
  • Construct your backup architecture in a way that avoids (at least as much as possible) having a single point of failure. If possible, have a backup for your backups, or configure 2 independent backup schedules to run everyday.
  • Do not rely solely on a disk-to-disk backup solution. Although disk-to-disk backup solutions offer many advantages over traditional tape backups, they should not be the only backup solution to rely upon. In such a scenario, the backup server is prone to the same risks as the servers it protects. A hurricane, lightning strike, fire, or flood could wipe out your backup server along with your other servers. For this reason, it is important to dump the contents of your disk based backups to tape on a frequent basis, and then store those tapes in an off-site secure storage.
  • When deciding to replace your current backup technology with a newer one, do not get rid of the old tapes, tape device(s) & backup software. At least, do not do this unless you are sure that your newer tape device(s) support the older tapes, or that you have moved the older backups to newer media supported by the newer tape device(s). This way, when it is required to retrieve data from the old backups, you will be able easily to retrieve the required data. This also could apply to the older backup software if the newer backup application does not support the older tapes or tape device(s).
  • There is no denying that it is important to secure your backups, but it is equally important to consider the consequences of your security measures. If you find yourself having to restore a backup after a major system failure, the last thing you need is an ill-conceived security mechanism standing in the way of the recovery. For example, if you are planning to use hardware-level encryption, do not forget (when time comes to upgrade your backup hardware) to make sure that your new hardware supports the previously used encryption.
  • Always use a long tape rotation scheme, or at least keeping some of your backup tapes as long-term archives.
on Jan 04, 2010 | Computers & Internet
A coma computer enthusiast has installed an old ISA sound card in his PC. However, it locks up and doesn?t work when a tape backup unit is used on the system. What is the most likely cause of the problem...
ISA is a very old technology and cards usually require switches or links to be set to avoid conflicts with other cards. ISA is not plug-n-play like PCI or PCI-e.
The software talks to an ISA card by knowing parameters such as IRQ number, DMA number, address range. These values may be permanently set on some cards, while others allow changing via the DIL switches or jumper links. To get two ISA cards working in one PC, the two cards need to use their own IRQ, DMA & address ranges. Make sure there are no conflicts of settings on the sound card and the tape drive card.
Try changing the settings on one of the cards. The tape drive may be the easiest for this. The tape drive is probably connected via a ISA to SCSI interface card. This should have DIP switches or Links to allow the above settings to be changed.
Oct 08, 2011 | Creative Labs Sound Blaster Live! 5.1...
Will a soundblaster ct4180 work in a del demension 3000 computer
Hello Nathan, hi, Nope, the CT4180 is to old for your dimension PC, the sound card uses an ISA slot. Your dimension has no ISA slot.
Sep 25, 2010 | Creative Labs Sound Blaster Live! 24-bit...
Sun L25 Tape Library
what drives are inside as these units can come in several configs. For all SCSI units the Adaptec 29320 is good for fiber the qlogic cards are my prefered cards.
Drivers are available from sun for the library and drives although you can sometimes use the standard windows drivers for many drives. (search for LTO as the tape drive manufacturer in win drivers for LTO) Although best to use sun drivers if at all possible.
Library comes up as a medium changer in device manager.
What backup software are you using? If Backup exec then the latest version already comes with their drivers built in
hope this helps
Aug 27, 2009 | Sun StorEdge L25 (SG-XLIBL25D-BASE) DLT...
MOB ITOX G4620-N won't reconize ISA Cards
WOW must be a fairly old system if it still has ISA slots.
Are you running XP or something else?
I assume you have the manufactures drivers that match the operating system you are using?
Have the isa cards worked in this system before?
My memory of isa cards is they are really useless at managing interrupts and I/O addresses. Go into device manager and see if there are any conflicts.
Try installing one card at a time. once it is recognised you can try the second one.
Also go into the bios settings page and turn off devices you are not using like serial ports and parrallel ports. if you have a sound card remove it or disable it if is onboard.
If you know what Interupt the cards is tyring to uses you should be able to reserve it in the bios so that plug and play devices won't touch it.
With a some trial and error and a combination of all these settings you should be able to figure it out.
Apr 01, 2009 | Computers & Internet
Replacing a sound card for a dell dimension 3000
Check if your PC has a PCI slot. It is this white strip on you motherboard. Go to your PC shop and ask for a PCI sound card. Just insert it and install the Drivers CD. If it doesn't, You may have the old ISA slot and stores may not be available of any ISA sound card. But dont worry, generally all computers starting from pentium 2 has a PCI slot. You may worry only if your computer is as old as the 486 computers.
Oct 22, 2008 | Dell Dimension 3000 PC Desktop
Sound card problem
Apr 24, 2008 | Creative Labs Sound Blaster Live! 5.1...
PCI card not been detected via Windows.
the sound card is installed into the ISA slot not the PCI slot.
clear the cmos for a minute, set it normal again.
install the sound card to the ISA slot carefully - i mean a working sound card and couple the system unit and boot, surely you will have your sound card working.
UZOWUANYA
e-mail:uzowuanya@yahoo.ca
Feb 12, 2008 | ASUS A8N-SLI Deluxe Motherboard
Bus Priority PCI - ISA
actually there is a solution for this
i found a usb 2 driver somewhere and now i can attach ipods to my compaq same model as his
Dec 31, 2007 | Compaq Deskpro 2000 PC Desktop
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
