Question about E-Machines eView 17f 17" CRT Monitor
Monitor settings The power went out recently and when I started my computer the monitor was messed up. The pictures and everything are still there but I can't make the horizontal size smaller. The side pin is also horrible and will not change. The OSD button works for v shift and size but the h size will not get smaller. My monitor has never done this before and I've tried everything. What else can I possibly do?
Try to see if the resolution in your Operating System is not to small, Most likely the smallest for that monitor is 1280 by 1024, and see if the color quality is at 32 bit
Posted on Aug 08, 2008
LG TV will not connect to windows 7 laptop anymore.
no laptop stated or service tag
nor OS< opr.sys.
so the local screen is still OK
reload the video driver?
make sure power setting in CP are set to on all time no sleep.
make sure close lid, power settings is set to oFF. ?
Mar 23, 2017 | HP Pavilion dv9628nr Notebook
Screen is tinged yellow
It sounds like you're going to need a new VGA/DVI cable. (from PC to monitor)
I suggest you try another one, then post back here if it doesn't fix the problem.
I hope this helps,
Yannick.
Jun 19, 2009 | Samsung SyncMaster 172N 17" LCD Monitor
Monitor has a red outline especially on pictures.
Probably there's an internal electronic part/s of your monitor that is cold sholdered or defective. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 21, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Compaq TFT5010 went black.
Good, I have seen this before. Thanks for asking at Fixya!
Mar 31, 2009 | Compaq TFT5010R 15" LCD Monitor
No picture on monitor 997M
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 08, 2009 | Microtech Computers & Internet
Blank Screen
Be sure that the power cable and the video cable are plugged into your monitor, the power cable is plugged into a good outlet, and the video cable is plugged into your computer. It's possible that you simply have a loose cable.
If everything is installed correctly, and if the screen is completely blank (no "cable disconnected" or "test mode" messages), then it sounds like your monitor is simply dead. Since there was a heavy wind storm recently, it was probably hit by a power surge. If you don't already, I recommend that you use a surge protector for all digital equipment.
Nov 12, 2008 | Computers & Internet
Kogi monitor ... it goes blank
Where can I buy the power cord for my KOGI L5QX?
Feb 09, 2008 | Kogi L7CH Monitor
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
Acer LCD Monitor
It is with your system. You might have hibernation enabled and many advanced video cards cannot recover from a bios or control panel timed hibernate. Start by using the Power Options from the control panel. Select "Always On" for everything and select the Hibernate tab to be sure that the Hibernate check box is not selected. Make sure you APPLY the settings. If the problem goes away, you can tweak the settings to get the power savings features you want without losing your system..
Dec 11, 2007 | Acer AL1711 17" LCD Monitor
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
E-Machines eView 17f 17" CRT Monitor Logo
87 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
