Question about Shenzhen Mizuda DVD-888
SHENZHEN PDVD8088 DISK ERROR
I have a portable DVD player that I believe to be a Shenzhen PDVD8088 (there is no maker's mark, but it looks the same as this player). It used to be region free but now only plays selected disks. For example, Eye Of The Beholder (region 1) works, Harry Potter & The Chamber of Secrets (Region 2) doesn't work, and neither does End Of Days (region 1). My best guess is that it is a region issue - maybe Eye Of The Beholder isn't region encoded or isn't RCE. I'm looking for a region free hack for the PDVD8088 to try to see if this solves my problem. Thanks, Ian
2 Suggested Answers
  • 1019 Answers
SOURCE: Mizuda dvd player wont read dvds
A couple of things To try.
1:) The DVD Player May be Region encoded, can only play certain region Dvds. ** Try different Disks**
2:) The Disk May Be Dirty-Scratched ( Towards The Centre )
** Clean The Disk With A Soft Lint-Free Cloth**
3:) The Laser Head may have a speck of dust or debris on it.
** Try a Laser Cleaning CD**
Hope this works For You.
Mike @ Compurepair.
Posted on Mar 01, 2008
Iview 2600hd dvd player has error "this player is incompatible with the region marking of this disc"
DVDs are coded for different areas of the world. If you bought the DVD from an online source it may not play on your format of DVD player.
Jan 24, 2013 | Iview 2600HD 5.1-CH Digital HDMI...
LG DP450 portable dvd player will not play dvds. No disk appears on the screen & these are new original disks which work in other devices.
This solution worked for me! My portable player would no longer turn the dvd, "no disc error". I bought a disc cleaner at a local office supply and manually turned it with my hand about 10 times. It works now!!
Jan 09, 2011 | LG DP450 Portable DVDDivX Player
Coby vzon portable dvd player says no disk, or wrong disk with any dvd. worked a few times only since i got it. it is a dvd550
This product is junk!!! Save your money and purchase a different BRAND!!! I purchase my player in May and it STOP working within 6 months!! I purchase this unit from BRANDSMART - NEVER purchase anythig from there. My player still has the plastic cover on the screen. Can you believe that. STINKS and a waste of my money and time!!!!
Jan 07, 2010 | Coby TF-DVD7005 Portable DVD Player
Only says loading when started, does nothing
Hi, your problem is the laser lens, it went sour. This device is coded to read only region 1 disks, when U attempt to read other regions disks it will read them once, 2 or 3 times but then... it will stop reading any disk regardless the region they are. Regions codes were implanted on disks to control piracy, so USA has region 1, Mexico 4, Asia I believe is 3 and so on. There are a total of 6 regions worldwide, U have to get disks matching the region U are from or, better solution... get a multi-region DVD player.
Jun 23, 2009 | TruTech PVS12701 Portable DVD Player
Displays "No Disc"
It can be several reasons
1. Disk is upside down
2. Lens is durty. CD/DVD cleaning disk will help
3. Disk is in different formate (for instance NTSC for US but you trying to playback disk in PAL)
4. Disk has different region code (look is the dvd player and disk have the same code, or ALL Regions code)
Good Luck
Dec 26, 2008 | Durabrand DUR7 Portable DVD Player
I have a mintek portable dvd player and i cant get it to stop being split screen
on the remote look for a button marked 'scan' or 'system', when the dvd is in 'no disk' state press that bottom a couple of time, you should get a single screen
Jul 04, 2008 | Mintek Televison & Video
Coby TF-DVD7100 7" portable flat screen...keep getting "Wrong Disc" Error
I have seen this problem on several Yamada & Xoro brand DVD players. If you remove the lid after powering down with the disc tray closed and a disc in it you may well find the ribbon cable to the read head is rubbing on the disc. The ribbon cable is held to the base of the box by a sticky pad under a 45 degree bend in it and a piece of sticky tape !!!. Power up unit, open disk tray, power it down, retape cable to base securely with small strips of duct or gaffer tape (using tweezers helps) and hey presto it will work again. The cable rubbing slows the disk spin speed hence "data read error" unit assumes "bad/faulty/wrong type of disk". All that technology screwed up by using a cheap bit of tape in the factory assembly, amazing eh !.
Mark
Mar 02, 2008 | Coby TF-DVD7100 Portable DVD Player
Mike @ Compurepair.
Mar 01, 2008 | Shenzhen Mizuda DVD-999 DVD Player
DVD player issues
Most likely the dvd is dirty, scratched, or chipped. Try cleaning the dvd disk with a soft cloth (chamois works best). Look at the surface of the disk and if it is scratched lightly, dust and dirt particles, fingerprints, etc will cause refractions from the laser light in the dvd player, which is then read as an error by the dvd player. Cleaning it with a soft cloth will sometimes help.
If that does not work, hold the disk up towards a light source and look for light coming through from the other side. If this happens, the disk is unreadable and unrepairable as the data source has been corrupted.
Dec 17, 2007 | Televison & Video
Open Questions:
Mitsubishi WS-65511 Rear Projection Big Box TV resets with a green flashing light every 5 minutes, Then works fine for 5 more minutes (perfect picture). Acts up worse when cold. Warm it up Works hours It's NOT the DM board caps. I've already replaced the DM caps twice. Not the problem. No repairman will look at the set. Too Old. So am I. I could repair it with help. The power supply must have a safety circuit that will shut down & reset if too much draw. I DON'T have a diagram. I'm not sure how to trace it . Which board? If I unplug boards one at a time, Will it damage other boards ? I know it is NOT the 7 DM board caps everyone keeps telling me. I see no burn't parts, No bulging caps. Tapping on components doesn't reset. What kind of component would act up when cold , But not overdraw when warm? This set has the best beautiful picture when it runs. If you can get past the resetting every 5 minutes for the first hour, You can watch it sometimes for 20 hours. I've left it on at night & it is still on the next morning. Change the channel Or raise the volume, And off it goes. Once or 10 times, Keeps resetting. Then on for 4 or more hours, Maybe. I can't afford a new one. It works GREAT ! when it works. I've notice that even when the set is turned off, The green light starts flashing (resetting itself while it's off) , Then stops. Once in a hundred times it will kick off the breaker & you need to push reset with a pin on the front panel next to the green light. It's probably a 10 cent resistor OR a $ 1.00 cap. If I only had someone with more knowledge than me to help. I know how to use a meter & read a schematic. I built a Heathkit 25"TV in the 70's & all my novice ham gear. I'm 64 & not familiar with digital circuits. Can someone help PLEASE ?
Dec 16, 2017 | Mitsubishi Televison & Video
See all Shenzhen Mizuda DVD-888 Questions
Televison & Video Logo
42 people viewed this question
Top Shenzhen Mizuda Televison & Video Experts
Electro Med Services...
Are you a Shenzhen Mizuda Televison and Video Expert? Answer questions, earn points and help others
