Question about Hotpoint Refrigerators
My hotpoint ff40p/ff40x keeps flashing warning lights and sounds and freezer not defrosting
My freezer is not defrosting and the yellow lights keep flashing and the warning sound keeps going off
SOURCE: Hotpoint FFS70 fridge/freezer
water keeps appearing beneath salad bin we have checked to see that nothing has come into contact with back wall of fridge ,and we have used a straw to keep the defrost gutter drain hole clear but water still appearing beside gutter drain hole .
Posted on Mar 02, 2008
SOURCE: I have a hotpoint fridge
I have tried the above solution without success. The only solution to the problem that works is to empty the fridge/freezer switch it off and allow it to do a full defrost. Then switch it on again. This appears to have sorted the problem
Posted on Jun 01, 2008
  • 139 Answers
SOURCE: my fridge freezer Hotpoint Mistral
E8- Evaporator thermistor short circuit
Well this is a sensor,, found in the freezer compartment of the f/f
what you have to do is reove the draws fro mthe freezer and you will c a panel which has 6 screws., remove the panel and and you will c a fan, toward the right of the fan you will c a yellow plug with a bit of wire on it,
This is what you have to replace
try connect distributions you can find them on the net if your in the uk that is
hope this helps
cheers
washdoctor
Posted on Aug 25, 2008
  • 1462 Answers
SOURCE: Hotpoint Ultima Fridge/Freezer keeps leaking underneath
yes this is probably the source of the problem - the defrost water doesn't flow down the drain.
melt the blockage with hot water till you get free flow down the drain - takes a bit of patience
tresilla
Posted on Aug 29, 2008
SOURCE: hotpoint frost free ff200e flashing lights and
Make sure fridge OFF freezer OFF ... then turn mains on. ONLY turn freezer to max, after 30mins put fridge to 1care ... this should overcome the problem of the flashing lights. When both nice and cool turn settings down. it worked for me
Posted on Sep 27, 2009
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
I have a Fridge Freezer The HotPoint FF40P. The Freezer is working fine but the Fridge Part does not seem to be cooling.???? What can I do to Fix This
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 03, 2011 | Refrigerators
I have a hotpoint freezer which is self defrosting but its icing up and warning message keeps flashing up
There is defrost timer, that will shut off the freezer and turn on a heating element that quickly defrosts the cooling fins. then it cycles back on. If any part of that system goes out the freezer will not defrost.
Sep 21, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
The freezer keeps defrosting and re-freezing again
First you need to remove plastic cover inside freezer compartment back wall at the bottom and check for build up of frost in the freezing unit if so your defrost system is faulty
Mar 18, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
Light on top of fridge keep flashing
Hi I found the hotpoint site, from there i found the manual for my fridge freezer.
Dec 08, 2009 | Refrigerators
Freezer and fridge are not cooling but we hear the sound of the refrigerator
your defrost heater or timer is not working . rotate you defrost timer until it clicks and check if its is defrosting if it is let it defrost for about 10 mins and turn the timer some more to take it out of defrost. replace timer
Jun 02, 2009 | Hotpoint HSS25GFP Side by Side...
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
HOTPOINT FRIDGEFREEZER
Sounds like frosting up. Defrost completely...that can take 2 days. Restart. Also, clean the condenser. Check door gaskets, clean and replace as necessary. Don't keep door open longer than necessary.
Dec 20, 2007 | Refrigerators
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Oct 16, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Open Questions:
Refrigerators Logo
300 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
