Does this machine normally change water only one time when it is on wash.? Therefore there are still bubbles after finish everything. Another problem is when the tub turns there is big sound .... which is really terrible to hear.
SOURCE: ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
SOURCE: Tub filled with water. It's not washing, rinsing,
looks to me ur timer or programmer is faulty possible needs replacement or looked after from a tradesman.....call manufacturer for help
SOURCE: bought used washer porcelain tub finish is worn off in bottom
get rid of the machine
cant imagine a machine that old really cost that much.
pocelain is baked on and is glass so any edges will catch and destroy cloths
SOURCE: Making constant buzz, tub not moving, will not finish spin
you need to replace a component called the"capacitor".this should solve the problem.
Please dont forget to vote if you liked my answer
thanks
