Lpt gamepad win 7 64 bit diver
Hi there I have an old LPT gamepad which I'm trying to find the win 7 x64 driver for. The model of the gamepad is "Topway SPW 2002". I'd appreciate if you could help me. Thanks
5 Suggested Answers
  • 93 Answers
SOURCE: HP Deskjet 3745 installation on XP x64 bit
We do not have full feature software for xp 64 bit. However install alternate drivers and then try to print.
Posted on Jun 11, 2008
  • 137 Answers
SOURCE: 5652 and Vista - duplex print not working
In Vista the default s the duplexer is "not installed". Go to Start, Settings, Control Panel, Printers, double-click on the Deskjet, Printers, Properties, Device Settings and set the duplexer to "Installed".
If the duplexer prints the back side upside down in Vista once it is enabled you can get a patch as described here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Jun 21, 2008
  • 7 Answers
SOURCE: Lexmark E210 on x64
Lexmark never updated the E210 driver for Windows Vista / Windows 7. Luckily, the printer is identical to the Samsung ML-1210 printer, which has better drivers that are Vista / Win 7 compatible. (The new drivers also work if the printer is connected to an XP machine, but is being shared with a Vista machine on your network.)
Go to the Samsung Support website (www.samsung.com/us/support/) and then type ML-1210 in the search box in the middle of the page. Click on the ML-1210 result, then click the "Downloads" tab, then below that, click "Drivers." Scroll down to get the correct driver for your system.
Uninstall any old drivers before installing the new drivers.
John Dollison
Posted on Nov 17, 2009
mastericpr08
  • 571 Answers
SOURCE: how about win x64 ? I want the win 7 64 bit
Here you can find the driver for your printer, next time especified your country please is more easy for us, thank you. good lukck http://software.canon-europe.com/products/0000524.asp
Posted on Dec 12, 2010
Alps md driver error
For the ALPS printers, make sure you are using Windows XP SP2 or older. There are no Win 7 drivers and there can be problems with a Win XP SP3. Join the Yahoo ALPS group. In the files section they have a full description of the problem along with a work around. It usually is a conflict with the bi-directional communication and the LPT port. The LPT port needs to be motherboard based - not an add-on card.
I hope this works.
Nov 14, 2012 | Alps MD 5000 Thermal Printer
TSP 700 printer on 32 bit windows 7. It doesn't stop printing and the paper just keep coming out. I've tried to reinstall driver and swapped the printer with the same model with another comput
Check if interface at the back of printer is interchangeable to the type of port your computer will support it. Direct USB to USB or direct connection is recommended to avoid future issues.
Oct 04, 2012 | Star Manufacturing Star TSP700 Receipt...
Looking for driver MF5630 canon Win_64
I have spent hours to find a solution... there is no driver. But there are definitely 2 solutions:
1. MF5630 - using ONLY printer in Win 7 x64:
You have to use the drivers for MF5700 Series - http://driverscollection.com/?file_cid=4213082682609f383f81540957d
- http://www.techulator.com/resources/4156-How-add-Printer-manually-your-Windows.aspx
1. First, Click on the Start button in your screen, further click on Control Panel button and then double click on Devices and Printers button.
2. Then click on Add a Printer button in the menu.
3. Further select the Add a local printer button from the available menu.
4. Then choose an existing LPT port and click Next button .
5. Further select the correct driver from the driver list menu for your printer. Suppose if the requisite driver is not available then click on the Windows Update button. After the Windows 7 Update installation finishes in your computer, once again search for the appropriate driver for your printer.
2. FINAL SOLUTION - for printer and scanner - if you have proper PC configuration:)
Win7 has a possibility: http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
you can install the WIN XP environment where you can easily install driver for Canon MF 5630 (or any other by Win7 x64 not supported printer/scanner) and additional software.
BUT YOU NEED to run: Windows 7 Professional, Enterprise, or Ultimate editions. Windows XP Mode is not supported on Windows 8.
Your BIOS must support Virtual Machine.
Jan 31, 2012 | Office Equipment & Supplies
Hi, I have a PC Win XP home SP 2 on CD, now SP 3 updated, Sockel 754 with a AMD Prozessor Sempron 3000+ and Chipsatz NVIDIA Force 6100 nForce 405 and sockel Purchase 2006/Sept. This is my...
have you tried to update drivers at ports(com&lpt)
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps
Jul 22, 2011 | Asrock K8NF6G-VSTA Motherboard
Gamepad drivers for win 7 64 bit
Try the gamepad official support website and download the driver or tell us your gamepad model for further support
Mar 03, 2011 | Computers & Internet
Hello! I have just bought Trust deal stick gamepad Gm-1520T. And the analog sticks doesn't work. I 've read that this pad doesn't require any drivers, so the reason has to lie somewhere else. I've tried...
needing them or not , try going to the manufacturer web page , finding a download for the gamepad that suits win 7 and down load it
win 7 is no longer supported by Microsoft so any late plug and play (pnP) units will not get win 7 to search for a driver
Nov 27, 2017 | Trust Predator GM-1520 GamePad
Got emagic a 6 2 m, worked under win xp (x86), won't work under win 7 (x64). the problem is: damn 64bit system.. didn't find drivers von win x64. anyone an idea?
Yea unfortunately that card is too old to be supported by vista or windows 7. Because you are running a 64-bit system there is no way to make it work without someone developing 64-bit drivers for it. Given the age, its highly unlikely.
Nov 20, 2009 | Emagic EMI 6|2m External Sound System
Canon LBP 2900 drivers 64 bit?
Now official drivers from CANON for lpb2900 win7 x64 !
http://fr.software.canon-europe.com/software/0038030.asp?model=
Jul 17, 2009 | Canon LASER SHOT LBP-2900 Printer
X64 bit driver
there is something called Mombi drivers.. that is not available in HP Website.. thats an internal FTP link available with HP Tech support.. and this Mombi drivers will work absolutely fine on x64 bit XP OS, call up tech support on 18004746836. they will email the link to u..
Jul 03, 2008 | HP Business InkJet 2800 Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
51 people viewed this question
k24674
jasbo
jasbo
