Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter programable thermostat
When i turned it to heat it flashed the letters RECO. It kept flashing this. What does it mean.
RE CO means Auto Recovery. In my users manual it states:
Hunter's Auto Recovery feature meets the Energy Star guideline for energy efficiency by allowing the heating or cooling system to recover gradually from an energy-saving set-point temperature to a comfort set-point temperature.
Auto Recovery calculates how early to turn your system back on. so that the room temperature is already comfortable by the start of the comfort temperature program period. Auto Recovery works in both heat and cool modes.
*When the thermostat is in Auto Recovery mode, the display will alternate "RECO" with time and the program indicator will flash.
*Auto Recovery can be disabled by sliding the Recovery switch on the circuit board to disable. (this is located inside the thermostate)
*Auto Recovery can be cancelers manually if HOLD/RETURN is pressed during the recovery process.
*Auto Recovery will be canceled and change to temporary manual override mode if the set-point is adjusted during the recovery process.
Hope This Helped!!
Posted on Nov 11, 2008
Flashing 4
Reprogram it and then hold down the button that says hold until it goes back to the screen that should fix it the blinking 4 is just saying you are in the 4th programming stage of the day. Mine was blinking on 3 yesterday and when I reprogrammed it it stopped blinking
Jul 03, 2012 | Hunter Fan Company 5/1/1 Programmable...
Flashing time on a Hunter Programmable Thermostate #44665
Teresa
have a cental air guy in for a check up on your units. they may need servicing
Jul 22, 2010 | Hunter Fan Company 5/1/1 Programmable...
HUnter thermostat reading RECO, Not cooling off house only blowing air.
Press & hold the HOLD button down to manually turn off the RECO error. This can happen when your unit goes into PS Mode.
May 22, 2010 | Heating & Cooling
Manual or directions
We have the same model. From the manual:
STEP 1: Slide the system switch to the HEAT or COOL position to program the corresponding system
STEP 2: Press PROGRAM to enter program mode. Heat or cool will be displayed on the LCD.
STEP 3: Press the UP or DOWN arrow. The Program hour and AM or PM indicator are flashing. Press to change the hour.
STEP 4: Press PROGRAM to change to the minute position. The current minute will be flashing. Press the UP or DOWN arrow to change the minute.
STEP 5: Press PROGRAM to change to the program temperature. The current temperature will be flashing. Press the UP or DOWN arrow to change the temperature.
STEP 6: Press PROGRAM again to move to the next program number. Repeat Steps 3-5 to change the remaining Weekday and Weekend Programs. [there are a total of 8 programs]
After cycling through all 8 programs, press PROGRAM again to return the display to normal. Press HOLD/RET at any time to exit the Program Mode.
TEMPORARY MANUAL OVERRIDE:
To temporarily change the current set temperature without affecting your program:
  • Press either ARROW and hold for about 1 second to enter the Manual Override Mode. When display flashes, you can release the key.
  • Press the ARROW to change to your desired Temperature
  • Press HOLD/RET to return to normal mode, or wait 15 sections for it to return automatically.
  • The current program number will flash to signify the Temporary Overide.
  • At the next program change time, the Temporary Override is cancelled, and the next program temperature becomes the setpoint temperature.
Hope this is what you need. God Bless.
Jun 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter thermostat need manual
Hi
u can fine your manual here...
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
Gary
Feb 28, 2008 | Computers & Internet
Flashing re co
Re Co stands for Recovery Mode. That means if you have programed your thermostat to be at say 72° at 5:00 then it should kick on in Recovery Mode several minutes before 5 in order to reach that temperature. This is normal and doesn't indicate that something is wrong, just that your thermostat is trying to reach or recover the programed temperature.
Feb 08, 2008 | Heating & Cooling
Error Message RE CO on Indiglo
Auto recovery – allows heating and cooling systems
to gradually recover from an energy-saving setpoint
temperature to a comfort setpoint temperature. Auto recovery
calculates the time needed to adjust the temperature to
the next program setting. When the thermostat is in Auto
Recovery mode, the display will flash alternating messages of
RECO and the time. Auto Recovery can be disabled by sliding
the recovery switch on the back of the circuit board to the
disable position.
(Auto Recovery will not operate if Permanent or Temporary holds
are on.)
Press Hold/Return during the Auto Recovery process to
manually cancel the recovery.
Jan 05, 2008 | Hunter Fan Company 5/1/1 Programmable...
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
Programmable thermostats at discount prices at hunter-thermostats.com.
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
1,704 people viewed this question
Top Hunter Dryers Experts
Fan Fair Of Boca
Fan Fair Of Boca
Paul Bade
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
