Question about Car Audio & Video
Siltronix slm 100 Amateur Radio Linear Amplifier
Looking for operators manual for Siltronix slm 100 amateur radio linear amplifier
Noggin
  • 944 Answers
SOURCE: AMERICAN PRO MANUAL
You need to contact these guys; http://www.americanproaudio.com/contact.html They still support the model, so thye should be able to help. Sorry doesn't appear to be available online. :)
Posted on Aug 05, 2007
  • 2039 Answers
SOURCE: My amplifier isn't powering on...
basic stuff dude fyses inside amp make sure well grounded had and other ground from radio to metal of car cheers
Posted on Jan 14, 2008
tech48
  • 624 Answers
SOURCE: trying to hook up amplifier to after market 6by 9 using factory radio
You can not connect the speaker lines directly to the RCA inputs of your amplifier. But you can connect them to your amplifier if your amp has a high level input. Most of the time it looks just like the speaker jacks of the amp, but smaller. It will be labeled high level input or speaker input. Sometimes an amplifier will have a jack for a wiring harness just for this purpose. Some amplifiers have them and some don't.
If your amplifier does not have them, you can purchase a line level adapter at most anyplace that installs car stereos. it converts the speaker level to the proper level of the RCA input.
Just follow the instructions on how to connect it.
If you try to connect the speaker outputs directly to the RCA input of the amplifier you will blow up the pre-amp in your amplifier.
I hope this was helpful to you, if so a good rating is always appreciated.
Thanks and let me know if you need more help.
Posted on Jun 22, 2008
tech48
  • 624 Answers
SOURCE: amp
It should have a blue wire from the harness on the back of the player for turning on the amp, it may also be labeled "antenna" or "power antenna" or "P con". That is the one to run to the remote turn on of the amp.
Posted on Jul 01, 2008
vrc_tech
  • 109 Answers
SOURCE: Amateur HF Radio TS-140s
There is no reset for the transmit power. the only thing that effects the power is the slider control on the right hand side of the radio that is marked "PWR" and the ALC/PWR switch located under the clear button.
Pat N5SLI
Posted on Aug 20, 2008
How to reset a yaesu fl-7000 radio.
According to Yaesu, the FL-7000 is a linear amplifier. Do you perhaps mean a FT-7000?
Dec 01, 2014 | Yaesu Radio Communications
I am looking for operational amplifier 56285
http://www.digikey.com/product-detail/en/linear-technology/LT1213CS8-PBF/LT1213CS8-PBF-ND/889812
Jan 30, 2014 | Linear Technology Operational Amplifier Op...
I cant talk on any frequency over 148.000 anyone know why?!
This is an Amateur (Ham) Radio 2-meter Transceiver. It will only transmit on the 2-meter Amateur band (144-148 MHz) but has expanded receiver coverage from 136-174 MHz which includes Public Service and Commercial 2-Way Radio bands. Please note that an Amateur License is required to operate on the 2-meter Amateur Band.
Dec 26, 2013 | Yaesu Ft 1900r Vhf Mobile 55 W Two Way...
Free manual for mosfet phase linear upa424 240watt amplifier
You do have 12 volts connected to the remote connection, correct?
Dec 11, 2013 | Phase Linear UPA424CS Car Audio Amplifier
How do I increase power output for a cobra 148 gtl the latest Chinese version
best way is to leave the radio in piece and obtain a linear amplifier to do the job a 10 meter ham radio amplifier will do nicely but you must re-tune it for the 27 mhz band 10 meter band is 28 mhz.
RF amps work best using side-band mode.
Oct 14, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
New 44 hp wont recieve
According to the heading under Problem with:
Galaxy DX-44HP Mobile Amateur Radio.
If this is correct, Are you a licensed Amateur Radio Operator?
If not, Then You will not be lawfully able to operate any Amateur radio until you are licensed, sorry, but thems the rules, and I'm not going to encourage or help anyone to be able to transmit these radios, without the credentials being made available first.
Cheers,
Peter
Mar 04, 2013 | Galaxy Radios DX-44HP Mobile Amateur Radio
Radio will not recieve
Hi Andy,
What you have is an amateur radio which requires a license to operate it.
Having said that, I don't know where you got the unit from, but obviously, the unit has had the frequencies deleted, so you cannot operate it until you go to a radio workshop to have the unit re-programmed.
You will only get receive(RX) frequencies programmed, no transmit(TX) frequencies. Sorry, but if you want to operate this unit, you will need to approach the Wireless Institute of Australia(WIA), who are responsible for licensing of radio amateur operators in Australia.
web:www.vk6wia.net for all the info re: licensing requirements.
Cheers,
Peter
Mar 02, 2013 | Yaesu FT-101ZD Owners Manual
I have an Icom v-8000 radio.The TX is very good with 75 watts out-put. But have nothing in RX.No signal and no audio.
What you have is an amateur band radio, which requires you to be a licensed operator to use it. It is possible that the frequencies have been removed from the eeprom prior to your purchasing same.
You can have Rx only frequencies programmed by an authorised 2-way workshop, but until you become a qualified amateur operator, you will not be able to get Tx frequencies programmed.
For licensing info for Amateur operators visit www.vk6wia.org.
Regards,
Peter
Feb 20, 2013 | Radio Communications
Ft270r handheld radio mod. issue
Hi Adrian,
Firstly, I take it that you are a licensed Amateur operator, if not, you're breaking the law.
If, on the other hand you are licensed, then I would contact a friendly Ham operator, who would be only to pleased to assist, after all, Amateur radio operators spend most of their time doing just this kind of thing, as you well know, if you are indeed a licensed Ham operator.
Cheers,
Peter
Jul 19, 2012 | Yaesu Ft-270r 5 Watt Waterproof Vhf Two...
Am looking for an owners manual and schematics for a Kicker K-500 Linear Amplifier
I got one from the folks who service them at this phone number (706) 270 3829 they Emailed it to me for FREE!
Jul 24, 2010 | Galaxy Radios DX-66V Base CB Radio
Car Audio & Video Logo
110 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
