Question about NEC MultiSync LT265 Multimedia Projector
NEC LT265 Focus Ring - Problem - Need Help
Can anyone direct me to the repair manual or give me tips on repair for this problem ? (I've found lots of user-manuals, but they're not deep enough to address this problem)
The Focus Ring on this NEC LT265 rotates, but seems to be cross-threaded as it gets tight at the end of it's travel and gets slighly skewed.
The Picture Size adjustment rotates smoothly and looks fine. But the Focus Ring seems to have been mis-installed, and may be cross-threaded.
I've taken the machine cover off and have exposed the lens, but cannot see exactly what needs to come off now, to expose the Focus Ring operation.
Any clues would be greatly appreciated.
Thanks in advance,
Fredster.
fred-cooper@comcast.net
SOURCE: NEC VT37
you auto focus or you can manually rotate the lens for focus
Posted on Feb 23, 2008
  • 3 Answers
SOURCE: NEC VT670 Blown Fuse
Try replacing main power supply it should take care of your fuse problem.... Not the ballest power supply the main one.
Posted on May 29, 2008
SOURCE: Nec Lt265 extremely dim
I had this same issue and it was the bulb. We had 2 of the NEC LT265 projectors so we swapped the bulbs between the 2 and it tracked with the bulb.
Posted on Mar 31, 2009
SOURCE: How do I focus the NEC VT47 projector? I have
I eventually fixed it; just a mechanical problem;I had to use strength to make the ring move again; 5586904.jpg
The arrow shows the direction of my movement; I had to use both hands; be very careful but also be aware that I had to put a lot of strength to manage to unlock it; good luck!
Posted on Mar 06, 2010
  • 89 Answers
SOURCE: NEC LT265 projector keep blinking status led
Download user manual from http://www.projectorcentral.com/NEC-LT265.htm
Posted on Aug 10, 2010
How can I adjust focus?
Turn the grey ring around the lens (where the light comes from) until the image is sharp.
Apr 11, 2016 | NEC VT595 Projector
All extensions ring on oncoming call on NEC Dterm series i
.. I don't have a solution, I need a solution.
NEC Dterm Series I, through internal calls my phone flashes notifying me that I have a call coming through but it doesnt ring. I have tried the volume key ^, that didn't work. Can anyone help me?
Aug 27, 2012 | NEC Dterm DTP-2DT-1 Phone
How to reset lamp hours lt265 nec
Select the Menu [Reset] → [Clear Lamp Hour Meter] to clear the Remaining Lamp Time and the Lamp Hour Meter
Mar 05, 2011 | NEC LT265 Multimedia Projector
The lens projector was pushed in and does not turn enough to adjust the focus.
hello therese prof, Hi, the lens is out of alignment, this could be aligned by disassembling the unit up to only on the outer part. of the case. once the cover is removed, you can re align the focus lens. no need to totally dismantle the entire unit. the lens is a separate passive device not connected to the electronics board.
Mar 03, 2011 | NEC LT265 Multimedia Projector
NEC LT265 PROJECTOR WILL POWER UP BUT WILL NOT COME ON. BULB IS A YEAR OLD. WAS PLAYING A MOVIE WHEN IT WENT OFF AND WILL NOT COME BACK ON. NOR WIL THE FAN RUN. POSSIBLE BALLAST?
It cannot be a ballast because the fan would not run off a ballast. Sounds like a serious hardware failure, I would check with the manufacturer.
Mar 10, 2010 | NEC LT265 Multimedia Projector
How do I focus the NEC VT47 projector? I have tried to rotate the focus ring and it won't move
Jan 08, 2010 | NEC VT47 Multimedia Projector
Im looking for an audio device for my NEC LaVieG PC-GL17FLGM5.
i found something on driverguide NEC Lavie G, this is direct link.
but you will have to be registered free,,, if you want give me e-mail and i will send it to you, or i will open ftp for you so you could download..
Apr 30, 2009 | Edirol UA-4FX External Sound System
Mar 23, 2009 | NEC VT676 Multimedia Projector
NEC VT37
Feb 22, 2008 | NEC VT37 Multimedia Projector
NEC MultiSync LT265 Multimedia Projector Logo
147 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
