Question about Sony Cyber-Shot DSC-T1 Digital Camera
Camara not focusing/ zoom not working
There is a flashing E:61:00 on the screen of the camara and the camara will not focus. the image is blury and the more you zoom it is worse
  • 10,594 Answers
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Posted on Oct 26, 2008
I need a manual for vivtiar 3188
Product MPN MPN: 80640 Key Features Features: Red-eye Correction Camera Type: Compact Resolution: 3.1 Megapixel LCD Screen Size: 1.5 in. Optical Zoom: Without Optical Zoom Digital Zoom: 4x Lens Interchangeable Lens: Not Interchangeable Lenses Optical Zoom: Without Optical Zoom Focus Type: Autofocus Macro Focus Range: 7.87 - 11.81 in. (w) Focal Length: 6.1 - 18.3 mm Image Quality Image Sensor Type: CMOS Camera Resolution: 3.1 Megapixel Image Resolutions: 2560 x 1920 · 2048 x 1536 · 1600 x 1200 Video Video Resolutions: 640 x 480 (VGA) Video Speed: 15 fps Video Format: AVI Exposure Control Aperture Range: f2.8/f4.8 (w/t) White Balance: Auto · Daylight / Sunny (Preset) · Cloudy (Preset) · Fluorescent (Preset) · Tungsten (Preset) Storage Memory Type: Built-in · SD Card Built-in Memory Size: 16 MB Compression Type: JPEG Flash Flash Type: Built-In Flash Functions: Flash Off · Auto Flash · Forced On Viewfinder / Display LCD Protected Position: Without LCD Protected Position Interfaces Interface Type: USB 1.1 Video Interface: Video Out Power Supply Battery Type: 2 x AAA Batteries Included Features Built-in Microphone: With Built-in Microphone System Requirements Operating System: Microsoft Windows 2000 · Microsoft Windows 98SE · Microsoft Windows ME · Microsoft Windows XP Dimensions Width: 3.5 in. Depth: 0.8 in. Height: 2.44 in. Miscellaneous Family Line: Vivitar ViviCam UPC: 19643806405 Product ID: 44609540 Return to top
Aug 30, 2011 | Cameras
Brightness of the monitor screen changes when a picture is taken, the final picture looks blurr. Is there any solution?
Are you pressing the shutter button half-way and giving the camera time to lock in the focus before pressing the rest of the way? If not, the good pictures were just luck.
The overall image is out of focus
If Pan focus is being used, the image may be out of focus; use Auto Focus Mode.
Pan focus uses a focus range of several feet, so the image might be blurry but will be captured faster. This could occur in the EX-Z30, EX-Z40, EX-Z50, EX-Z55 and EX-Z57.
If digital zoom was chosen and the image becomes unclear, only use optical zoom, and move closer.
Check the owners manual; hope this helps.
Jan 12, 2011 | Casio EXILIM Digital Camera
Photos are purple and green, it does not focus properly Is my camara finished or is it worth repairing it is about 4 years old s7000 digital.
HI there if your focus having problem then the images will come blury. But as per your problem its a lens sensor error or problem. Just replace the sensor and you will get the proper colored image. Thanks.
Mar 19, 2010 | Fuji FinePix S7000 Digital Camera
I'm having problems with I focus the camera out. It becomes burrie
The camera has limited ability to zoom out. I believe you have a 3x optical zoom, and a 7 x digital zoom. Once you go beyond the optical zoom, the camera attempts to digitally render the zoom which can cause pixalation, or bluriness. This should never be an issue inside the optical zoom range as the image is going directly through the lens.
Dec 19, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Half of the screen is clear and left side of the screen is blury
Its a Common Problem with Projection Tv's ~ If your flash focus is not correcting the problem, And It can Not be Adjusted in your service menu: under Manual Convergence, your IC chips and maybe a few resistoirs may have failed and need to be replaced!... onegeo
Jul 07, 2009 | Sony KP-46WT500 46" Rear Projection...
Focus error appear on screen
i just help the zoom to get out with a thin screwdriver and now the "ZOOM ERROR" message disappear, but i have another problem. The camera does not show the target (what to shoot) on the screen. It shows ONLY pictures on card.
I tried everything, but the target i choose does not appear on the screen.
Dec 09, 2008 | Cameras
Everio gz-mg 155u won't focus
I called Costco, the retailer I purchased the Everio at in Dec. and they said my labor warranty has run out. They gave me instructions to send the video camera to JVC for repair. If this is a common problem with this unit, I am hoping they will not charge for labor. They should provide at least a one year parts and labor warranty!
Jul 11, 2008 | JVC Everio GZ-MG21 Camcorder
Blury and flash problems
Hello Chad,
As you told the condition of the are blurry,This problem is not related to the setting or master reset.This cause is due to malfunctioning of zoom optical motor and sensor who focus the object.Therefore, the solution of it is, You have to change its optical lens assembly.
I often deal these sort of cases in routine in said Model Although it's a very fine camera but dusty and moisturized conditions cause this problem.
Thanks & don't forget to rate.
Apr 12, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Camera doesn't focus
There are many reasons why images can appear out of focus. strangely if you think about it it is not focusing per se like photographic cameras the focus is at infinity by default- from about 50cm - out So if the images appear out of focus these are some of the reasons shots taken in low light with a low ASA setting resulting in long exposure -thus camera shake. Focus hunting- there are various methods used but if the mechanism cannot 'lock' onto something the focus motor will 'hunt' Faulty zoom Optic Zoom mechanism. Inadvertently set to 'Macro' mode Grease on the lens Careful checking of the camera- its settings- with the manual is essential before declaring the camera faulty Don't forget the paper manual is a nodensed version of the full manual on the software disk.
Sep 02, 2007 | Cameras
Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Olympus FE-140 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
251 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
