Instruction manual thor th 85 front loader washing machine
Thor th 85
3 Suggested Answers
SOURCE: Require Manual for Thor TWM 800 Washing Machine
Where can I find the instructions to my Thor WM800 front loading washing machine?
Posted on Dec 19, 2010
  • 6277 Answers
SOURCE: thor front loading washing machine the
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 16, 2011
Can i run my thor front loader on cold water only
If this machine has two hoses connected to it then it says feed me hot and cold if you only have a cold supply hose then you can cheaply buy a Y piece connector that would Split the cold supply into the two feed hoses onto one cold supply pipe, Hope this helps.
Feb 16, 2015 | Washing Machines
Where can I get a 2015 Thor motor coach Vegas service manual or 2014?
Chassis will be one manual, coach will probably be generic from Manufacturer.
May 24, 2014 | Thor Motor Coach 2014 Vegas 24.1
Extremely loud, unbearably loud Dometic a/c 2010 Thor Outlaw
have some one remove cover on roof to track noise down.
Feb 08, 2013 | Dometic Rooftop RV Air Conditioner
Thor Elite twd 1000
I need an instruction manual for THOR elite TWD1000 Washer / Dryer.
Satch
Nov 20, 2011 | Washing Machines
Thor front loading machine door won't open.
Please check the link below to see how the door can be opened. Once this is done the program controller section must be checked for proper cycle of the functions.
http://www.espares.co.uk/advice/washing-machines/a/7/1294/how-to-open-a-washing-machine-door-thats-stuc.html
Aug 22, 2011 | Washing Machines
Need operting instructions for THOR ST100X washing machine
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 07, 2011 | Washing Machines
Thor 806 washing machine buzzes, doesn't fill
Check the water supply. Possible problem with the solenoid on inlet. Or timer if old machine.
Sep 20, 2009 | Whirlpool WFW9200S Front Load Washer
Require Manual for Thor TWM 800 Washing Machine Front Loader
Aug 22, 2009 | Whirlpool WFW9200S Front Load Washer
No instructions!
i have the same problem.
did you find one?
thor@millennium-lifestyle.no
regards from thor
May 08, 2009 | Brandt WTC0815F Top Load Washer
Washing Machines Logo
236 people viewed this question
Top Washing Machines Experts
