Question about Planar PL1910M (Black) 19 in. Flat Panel LCD Monitor
Planar 19'' model #PE1901BK---REMOVE THE BACK PANEL.
I removed all screws,went around the edges with a credit card,no room for a credit card. back panel will not budge without breaking something.
  • Planar Master
  • 5,568 Answers
Check to see if the various connectors are mounted on a separate subpanel that is independent of the back cover or if you must perhaps remove some of the protruding connector hardware. The 'F' connectors (the threaded coaxial type for cable or antenna input) for example, may have a fairly large diameter (but thin) nut securing them.
Posted on Oct 26, 2008
Picture failed - how does one remove back panel to access capacitors?
Lay TV flat on face. Remove all screws around the outside edge and depending on screen size, the ones that are about 1/3 and 2/3 of the way across the back. On most TV's it is also required that you remove the pedestal base or the screws that held it in place. (if some of the screws are longer, or shorter, they must go back where they came from when you reassemble the set )
After all of the screws have been removed, it is usually easier to start to separate the front and back in the center of one of the sides.
After the back is out of your way, the capacitors that you assume are causing the trouble are on the printed circuit board that the AC line cord goes to. It sometimes has a metal shield over or around it.
The capacitors in question are beside or beneath another metal bracket. Make sure to replace them the same way that you took them out, they do have a + side and - side. Don't use the $2 capacitors or you will get to do this over again very soon.
Mar 29, 2016 | Polaroid TDX-01930B 19 in. LCD HDTV
How do I remove/replace powersupply for dellinspiron one 19 computer
the service manual for this computer (download
Product Support Dell US )
has a section titled Power Supply (link from menu on first page) which sections titled "Removing PS" and "Replacing PS"
21.February.2015
Feb 22, 2015 | Dell Inspiron One 19 All-in-One Desktop PC...
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
My Dell All in One Inspiron One 19 will not power on!
Dell Inspiration One 19A Dead - Repair
Face down. Remove the plastic panel covering the sockets at the back. Remove the stand, 4 small black countersunk screws. Turn over and unclip the bottom panel. Unscrew the plastic piece across the computer under that panel. The escutcheon around the screen should now unclip. Unscrew ~8 screws around the edge holding the back to the metal-work. Carefully invert, face down, and lift off the back. The power supply is in the middle. Another bottom piece of metal may need to be unscrewed first. Remove the cover from the power supply. Four screws hold the PC board in the power supply box.
Two green 820 uf, 25 volt capacitors are likely to have bulged tops.
Replace them anyway. Reassemble after testing.
Nov 22, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
Rear panel for a mitsibishi montero speacker removel
1Lift the rear seat all the way up and towards the front of the vehicle.
  • 2Remove the five Phillips screws holding the scuff plate at the rear opening of the vehicle. Remove the scuff plate.
  • 3Use a panel tool to pry off two screw covers on the edge of the headliner in the cargo area. Remove the Phillips screws located behind each of the covers.
  • 4Pull the carpet away from the edges of the rear-side panel. Remove four Phillips screws located below the carpet at the bottom of the rear-side panel. Remove the two Phillips screws holding the cargo cover hooks located on the rear-side panel.
  • 5Pry around the bottom and back edges of the rear-side panel and pull the panel out far enough to access the speaker.
  • 6Remove four Phillips screws from the edge of the speaker with a Phillips screwdriver. Pull the speaker out of the door and unplug the wiring harness connected to the back.
  • Nov 12, 2011 | 1995 Mitsubishi Montero
    HI I HAVE A DRYER MODEL DLG5988WM I WOULD TO KNOW HOW TO REMOVE THE FRONT PANEL
    Step 1, remove dryer top: remove three phillips head screws from the back edge of dryers top.
    stand in front of dryer and push back sharply about 2 inches on the dryer's top using the palms of your hands. Lift top up and off.
    Step 2, remove control panel: remove phillips screws from back side of control panel corners and release clips along top edge of control panel, allowing panel to be taken off and set on top of dryer.
    Step 3, remove front panel: Open door, remove phillips screws located at 4 and 8 O'clock positions at door opening. remove phillips head screws along fron panel's top edge. tilt panel forward and unplug light, door switch, and moisture sensor (at bottom of panel) and then set panel aside and out of your way.
    Feb 03, 2011 | LG WD-3243RHD Front Load Washer / Dryer
    What is the easiest way to get the front panel off of my LG front load washer to replace the large rubber drum gasket which ripped? Is it screwed on or pressure fit?
    It can be changed out without removing the front panel. There are special tools designed to remove and re-install the spring clamps which hold the gasket on, but you can do it with long nose pliers or other implements. It is more difficult to do with the panel on, but it can be done. If you want to remove the front panel: Remove bottom screws from plastic parts on the back edge of the washer top. Stand in front of machine and use the palms of your hands to sparply push back the washer's top about 2 inches, then lift it off. Remove screws from support frame to control panel. Remove dispenser drawer by opening it and pushing the tab on the top back side down while pulling the dispenser the remaining way out. Remove screws from behind dispenser drawer. Release tabs along the top edge of the control panel (watch out for sharp edges) and swing the control panel up on top of the washer drum. Remove spring clamp from front of rubber door gasket. Open access door panel on lower left of front panel. Use small hose to drain out remaining water. Remove phillips head screw in recess, then use plastic putty knife to push inward on the left or right edge of rectangular housing around the recess to remove recess. Remove screws at bottom from bottom of front panel into frame (located behind plastic recess) Remove screws along top edge of front panel. Tilt front panel forward and unplug door switch. Set front panel to the side.
    Feb 01, 2010 | Washing Machines
    Remove back panel on gateway plasma tv
    jeff
    I just took the back off my Gateway for a simular problem
    I just took the screws out of the legs on the back of the set and all the screws around the edge then the support where the legs were attached and then the screws around the box with all the video jacks that pulls off. Hope this helps
    brucep63
    Mar 21, 2009 | Gateway GTW-P42M303 42 in. Plasma...
    Acer AL1717 Back Panel Open Screws
    Taking monitors apart can be a pain and tough.
    I do quite a few and some are really rough to unsnap !!
    Remove the stand and cords.
    Remove all rear screws.
    Then the hard part is unsnapping the trim from the case without using a crow bar or breaking it.
    Start at the bottom first that way if you leave a couple marks they are not so visible. You'll need something thin with a beveled edge to slip between the two plastic parts to release the catches as you rock the trim back and forth from the screen.
    (the edge of a pocket knife works- a credit card can have an edge sharpened with a file- sometimes real good fingernails work)
    ebaysbammbammfran
    Oct 12, 2008 | Acer AL1717 17" LCD Monitor
    Planar PL1910M (Black) 19 in. Flat Panel LCD Monitor Logo
    227 people viewed this question
    Top Planar Computers & Internet Experts
    Clive Gray
    Joe Goldman
    Joe Goldman
    William Miller
    William Miller
    Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
