Manual for Sony laptop pcg-41217L
MANUAL
chris252
  • 84 Answers
SOURCE: DIAGRAM FOR SONY VAIO PCG-k45 (service Manual) free download
i might tell u but only if you tell me how to post questions thks
Posted on Mar 31, 2008
  • 207 Answers
SOURCE: manual for my sony vaio pcg-u1 notebook
go to the wbsite enter ur laptops model no and download it
Posted on May 22, 2008
  • 5 Answers
SOURCE: sony laptop driver model PCG-7G2L
http://b2b.sony.com/b2bMicrosites/landingpage/vaio_drivers/download_vaio_drivers.html
you can download from this web site
Posted on Apr 01, 2009
  • 8073 Answers
SOURCE: Need pdf manual for sony vaio pcg-394L
hello
Go to the Sony web site serving your contry and download a manual. Here is a link I obtained from the US site after entering the model number you provided.
www.docs.sony.com/release/VGNFZ200series.pdf
Apparently, it does not coorespond to your model. But not knwowing from what country you sail from, I cant't be more accurate.
Hope it gives you a starting point.
Posted on Aug 29, 2009
  • 846 Answers
SOURCE: sony pcg-tr1f laptop
The hard drive is hidden inside, and you have to take the palm rest off to get to it. Take the srews at the bottom out, take the keyboard off and replace the screws underneath. then pry off the palm rest. There are Laptop Repair Guides that show how to open a Laptop. Watch out for the ribbon cables, those tear easily. Replacement parts are usually available on Ebay. There are third party services that can do it for you, like Sony Repair NYC.
Posted on Dec 27, 2009
REPLACE POWER JACK
http://www.ebay.com/itm/pcg-41217L-sony-vaio-DC-JACK-POWER-JACK-FOR-Input-Port-Socket-vpcsc-VPCEL-VPCF-V-/370628762815
Has two channels on the sides, to slide down into a channel formed in the outside edge, of the laptop Base Enclosure. (Bottom Cover)
Wires are soldered to it. Two of them. If there is a Red wire it goes to the Center terminal on the back of the jack. The Center hole is the Positive connection.
The Black wire goes to the outside terminal on the back of the jack.
(Negative)
Use good de-soldering/soldering skills. Do not make a cold solder joint. (Solder connection)
There are no exact Service Manuals listed for the Sony VAIO PCG-41217L Notebook PC. (It is also part of the VPCSC series. It is a VPCSC31FM)
However after you disassemble 100 laptops, or so; you find disassembly of all laptops follows a basic pattern.
http://www.ebay.com/itm/Sony-Vaio-vpcsc1afm-pcg-41217l-s-series-laptop-I5-blu-rau-MS-OFFICE-installed-/271101863505?pt=Laptops_Nov05&hash=item3f1eee2651
This shows me different key views of the laptop. I have also opened a separate window, with the User Guide from Sony eSupport.
The Ebay link shows detail of the Palm Rest Cover.
Shows it to be one piece with no separate Switch Cover.
(Switch Cover: Flat plastic strip above Keyboard, and below Display Assembly.
Usually has the Power On button, LED indicator lights, speakers, etc in it)
Also shows me a Bottom View.
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Lay the notebook on a clean, static free cloth, on your table.
Helps protect the table, and the laptop from scratching.
Lay the notebook bottom side up, Battery Compartment facing away from you.
Use a multi-compartment container, and label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws. Advise DO NOT mix them up.
You should be wearing an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Average cost is around $3 to $6. Do not wear it, and/or connect to a good ground source, and when you are finished you can use your laptop for a doorstop.
Static 'kills' computers.
Example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case. I feel an Anti-Static Mat is unwarranted.
You can set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or a large metal knickknack. (Unpainted)
You are going deep into the laptop, and the Static sensitive Processor, and other hardware components could be 'zapped'.
Use ESD wrist strap.
All screws are removed from the bottom of the laptop. All around the perimeter (Outside), and the inner ones.
The optical drive (CD/DVD drive) will slide out.
After the optical drive is removed, look to see if there are any hidden screws on the outside edge of the laptop, that may have been covered by the optical drive. Remove them if so.
Remove the Harddrive.
Remove the Ram Memory.
Remove all peripheral components. (Dummy PCI card, etc)
I don't know if the Palm Rest Cover removes on this model, or the Bottom Cover. (Base Enclosure)
Bottom Cover removal style,
http://www.insidemylaptop.com/take-apart-sony-vaio-vgn-cs215j-laptop-replaciong-dc-jack-harness/
Yes. The bottom cover access panels are different than yours.
Posted for Keyboard removal, and Bottom Cover removal.
NOTE*
The Keyboard Cable STAYS attached to the Keyboard. It removes from the motherboard. There is NO plug connector on the end of the Keyboard Cable.
The Keyboard Cable is a FFC. Flat Flex Cable,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
It ONLY plugs in, in one direction. Must go back the same way it was originally. Even if it was originally twisted.
For this reason you may wish to make a mark on one side of the cable, and a matching mark on the same side of the motherboard connector. (Sharpee?)
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is composed of two separate pieces, but DOES NOT come completely apart.
There is a larger rectangular Bottom part. This is the Body, and it is stationary. Mounted to the motherboard, and doesn't move.
There is a smaller rectangular piece on Top.
This is the Locking Bar.
There are two styles presently used;
1) This style slides. Slides up towards the LCD screen.
ONLY slides about 2mm. That is a little more than 1/16th of an Inch.
A) Closed, or can be said as Locked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-11.jpg
B) Open, or Unlocked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-12.jpg
The Locking Bar is barely seen on top, and the sides. The 'tabs' of it on the sides, are eased towards the LCD screen, with the thumbnails.
2) This style flips up,
A) Locked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
2) Unlocked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
IF, the Locking Bar is removed from the Body, it is broken; or the Body hinge pins are broken.
EITHER way means MOTHERBOARD REPLACEMENT, and why I am being so detailed. Use care.
Here is what the Keyboard looks like,
http://www.ebay.com/itm/SONY-PCG-41217L-Keyboard-Silver-/261121017591?pt=PCA_Mice_Trackballs&hash=item3ccc0686f7
Put your mouse in the middle of the photo, and slide to the right side of the Keyboard.
See that half-moon tab sticking out, that looks to have a threaded hole in it?
Screw comes up from the Bottom of the laptop, and goes into this tab.
Looking closer at the open laptop view of the Keyboard, it almost looks like the Keyboard is under the Palm Rest Cover, and cannot be removed until the Palm Rest Cover is removed.
May just be the view, or my eyes.
That is about as far as I can take you.
Post the problems you run into in a Comment, and we'll try to work them out together.
Regards,
joecoolvette
[ Just in case it will help,
http://www.insidemylaptop.com/category/7-sony-laptops/
Nov 11, 2012 | Sony VAIO Computers & Internet
Service Manual for Sony VAIO PCG-7184L
Try www.ebay.com Type make and model of laptop, refine search to screen or scroll through the list.
Jul 04, 2012 | Sony VAIO Notebook
Manual for sony vaio PCG-7183M
manual for sony vaio laptop model pcg-7183m
Mar 06, 2012 | Computers & Internet
Need a manual for Sony Vaio model PCG-632L
I have this laptop (the PCG-632L). My laptop shiped with the "Vaio Notebook Quick Start" manual for the "PCG-R505 series". You could seach the Internet for this manual instead of the "PCG-632L" manual. The manual says "quick start," but it goes into slightly more detail than the average "quick start" manual (such as changing RAM).
Nov 12, 2011 | Computers & Internet
I NEED THE WEB SITE FOR A SONY MANUAL MODEL #PCG 81114l
http://www.docs.sony.com/release/PCGK30series.pdf
Jan 29, 2010 | Sony VAIO PCG-K35 Notebook
The screen on my Sony Vaio VGN A250 model PCG 8R7L is showing enterference is there a service manual from Sony for the Sony Vaio VGN A250 model PCG 8R7L I can obtain?
Hi kyle662919.
You may download the Service Manual from the below link:
http://home.comcast.net/~nw_systems/vgnA.pdf
Please open the above link to download the Service Manual for the VGN-A200 Series Notebooks.
Hope this helps.
Please feel free to contact for further assistance.
Jan 22, 2010 | Sony VAIO A250 Notebook
Manual for my sony vaio pcg-u1 notebook
May 22, 2008 | Sony VAIO PCG-U1 Notebook
Computers & Internet Logo
1,043 people viewed this question
David Payne
David Payne
