Question about Maytag Neptune MDE5500AY Electric Dryer
Removal of maytag MDE5500AYW lint filter housing
2 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: How do I remove the lint housing of Maytag Neptune dryer
Hi Kate,
Gaining access to the lint housing sounds more difficult than it is. As a matter of fact, I could get to it and have it back together in the time it takes me to type out the instructions!
Tools needed;
1.) Phillips screwdriver
2.) 5/16" nut driver or socket
UNPLUG THE DRYER FIRST!!! Or risk a funky new hair-do...
Open the door and remove the four screws at the hinges then remove the door. Opposite the hinges, you'll see 4 more screws, remove these too. Now grasp the front panel on both sides near the top and pull it toward you. Lean it out to about a 45 degree angle and lift it off the clips that are holding it (at the bottom).
Now you'll see the lint trap housing. Look around the housing, you'll probably see a yellow wire near the 5 o'clock position, remove it. Now, on either side, you'll see four 5/16" screws... Don't remove the top ones, just remove the three below the top ones. You can now pull the entire panel off of the frame for cleaning.
Rebuild in the reverse order (and don't forget to re-connect that yellow wire!)
There ya go! Please don't forget to rate this as "FixYa", OK
SG
Posted on Apr 11, 2009
Spinning not heating
First check the lint trap top & bottom of dryer could be plugged, if not heater coil is out.
Jan 28, 2013 | Maytag MDE5500AYW Electric Dryer
Maytag neptune mde5500ayw chirping, buttons wont do anything. was told to replace control board. that did'nt help at all. any ideas?
The blower wheel on these tends to wallow out. That makes the dryer overheat and take twice as long to dry the clothes. Lint begins to build up in the filter housing. Finally the temp exceeds 350 and the round white fuse on the blower housing melts. Boom you has got a dead dryer. To get into the slopefront type dryer seems a bit intimidating bit really is not. Remove the door. The door is reverseable so 2 more screws opposide need to also be removed. Then the goalpost shaped front pops off. Then that reveals the top hold down straps. Remove them and top can be popped. Next you remove the front shroud the drum rides on. then get the drum out. Did I mention you do not work from the back at all on this model? Do not try to fix it in the wash room. Take it ouitside and put it on the picnic table or a tailgate to repair it. You will need a phillips head screwdrivers pliers 1/4 and 5/16 nutdriver and snapring pliers.
Shopvac to clean it up and probbaly a new fuse and blower wheel.
SERVICE MANUAL
Jul 31, 2012 | Maytag Neptune MDE5500AY Electric Dryer
We have a Maytag Neptune mde5500ayw electric dryer, with a three prong cord. Our new house has a four pronged outlet. I purchased the correct 4-prong cord, but need to know the proper way to wire it into...
It seems to get confusing where the wires go in the back where the cord connects to on your brand new,or previously dryer that you have brought to a home thats new to you
4 wires goes as such with oldtech2332.jpgthe red wire going on the right side,the black wire going on the left,the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where that link was just attached to a minute ago.
GENE
Oct 12, 2011 | Maytag MDE5500AYW Electric Dryer
I need to remove the lint housing in a Model DE 713 Maytag dryer. How is this done?
To access that housing what ya need to do is remove the front panel by removing the 2 phillips headed screws on the bottom of the front panel and tilt the panel out at a 45degree angle and it will come free from the cabinet. directly behind the front panel once removed will be the lint filter/blower housing.
Before removing the front panel be sure to disconnect power to the dryer.
GENE
Sep 30, 2011 | Dryers
Dryer running fine but just stopped heating. lint traps all clean.Maytag Neptune MDE5500AYW. HAVE THE DOOR AND FRONT PANEL OFF ALL ELEMENTS LOOK CLEAN AND ATTATCHED. No problem with home power...
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 23, 2011 | Maytag MDE5500AYW Electric Dryer
How to unscrew blower wheel from motor shaft Maytag MDE5500AYW dryer?
If its this type that screws on, go to the front of the motor
remove the belt and attach visegrip pliers, lay dryer on its front ,
remove panel down to blower and put your right hand fingers
inside the blades and snap the wheel to the RIGHT
Be careful you can get a bad cut from the wheel housing.
This is the way I do it all the time.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 25, 2010 | Maytag MDE5500AYW Electric Dryer
Have old Maytag dryer that does not get as hot as it used to. Takes a long time to dry. Burner does come on. Have determined that vent is clear.
How old is this one? If it is a real old model with 2 belts, it could be the blower belt is slipping.
Jan 06, 2010 | Maytag Dryers
Hi Kate,
Tools needed;
SG
Apr 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Hi, I have a Maytag gas Dryer, Legacy series, heavyduty. I clean the lint filter each time used but there is still a build up which I cannot get out unless I remove the filter housing. How do I do this?
you do not have to remove the lint housing all you have to do is go to an applaince store and ask for a lint brush you then take the lint brush and shove it down where the filter goes to loosen the lint turn on your dryer and it will blow it outside
Dec 26, 2008 | Dryers
Install dryer belt
more information needed to specifcally match the model
however dryers are all similar so
generically, UNPLUG dryer
A:top mounted lint filter (kenmore maytag(New))
  • remove lint filter
  • remove screws in lint filter housing
  • with putty knife or other flat blade depress lock tabs at front corners of top body panel
  • tilt top panel up
  • remove screws 1/3 way down each side, remove door switch wires
  • remove front panel set aside
B:dryers with screws at bottom of front panel (maytag speedqueen)
  • remove screws from bottom of front panel
  • tilt front panel up
  • remove door switch wires
All
  • pull drum forward & out
  • examine drum felts, rollers, and slides for wear replace if worn
  • wrap new belt round drum at old wear marks
  • insert drum
  • wrap belt round motor pully
  • pull tensioner pulley hard to end of travel against spring
  • wrap belt round tensioner pulley
  • release tensioner
reassemble
Oct 19, 2008 | GE Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
291 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
