Question about Panasonic PV-GS19 Mini DV Digital Camcorder
Blue Horizontal lines and no sound! Please...what to do?
My camera worked fine until I used a tape that had been in the camera when I got my previous camera wet at the beach. And now when I play any tape the LCD has blue horizontal lines across it with no sound. What should I do? Can I clean these myself?
  • 2 more comments
  • dba616 Nov 16, 2007
    I have an identical problem with my PV-GS80. It recorded and played back fine at my daughter's horse show a couple of days back. When we tried to play back again at home (after charging the battery), the blue lines appeared and the sound disappeared. We tried a different tape and it does the same thing. The camera is only 5 months (3-4 recording hours) old. Any thoughts beyond cleaning the heads? Thanks.
  • Anonymous Mar 07, 2008
    After 2-1/2 great years, my Panasonic mini dv camera (pv-gs35) also started doing the blue horizontal lines & no sound. At first rewinding made everything ok; now I can't get rid of the problem. I tried cleaning the heads yesterday. Didn't help.
  • guitarboy Nov 22, 2008
    Same problem here. I've only had the camcorder a year. I've only used it a hand full of times. Wednesday it worked fine. Today, I went to use it again, and in playback, I had the same problems.
    As far as I know, the camera did not do anything but sit there from wednesday to today
  • markymark_cy Nov 26, 2008
    I have a the NV GS 21, too, and the same fault develped after 13 months.. I've bought a tape head cleaner cassette - no improvement.
    If I record to a computer - via firewire / USB data cable the image is perfect..so it has to be a tape head problem .. right?
    I've read elsewhere that this could be an actual circuitry fault and judging by these posts we are suffering a common problem.
    My cam was hardly ever used and not abused.
You should buy a head cleaning tape that fits your tape deck on your camera. They should be at any store that sells electronics, or a general store, such as Wal Mart. Follow the instructions. If that doesn't work, then I don't know what to do.
Posted on Nov 10, 2006
I just posted the same problem i was also at the beach and i saw a lady with the same one filming people surf so i asked her if it happend she seadit has she thought moisture got in through the speaker she seaid it just fixed it self now im sure its a moisture problem
Posted on Nov 02, 2006
SOURCE:
Ag-dvc20p blue stripes in play back mode
Blue stripes in playback is an indication that you need to clean the heads. A Panasonic cleaning tape should work fine.
Jan 22, 2010 | Panasonic AG-DVC200 DV Digital Camcorder
Horizontal grey lines on tape playback
please state the age of your devices. It can help a great lot in solving your problems. The lines that you get aren't continuous, are they? They appear to be going up and down, are different sizes and shift as the tape plays, yes? well, this is simple. You need to clean your recording head.
Sep 23, 2009 | Canon ZR200 Mini DV Digital Camcorder
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Got a brand new samsung d381 camcorder and when you playback recordings there are horizontal green lines across the screen and no sound, what am I doing wrong? or should I send it back as faulty? I have...
SOUNDS LIKE YOUR HEAD IS STUCK OR YOU NEED A DRY CLEANING TAPE RUN TROUGH. SOMETIMES WHEN U USE OLD TAPES THEY ARE DUSTY AND THE DIRT CLOGS THE HEAD. TRY A GOOD TAPE CLEANER
May 28, 2009 | Samsung DouCam VP-D5000i Mini DV Digital...
Horizontal grey lines running whe camcorder in play mode
Its symptoms of dirty / clogged video head. Please use Sony video head cleaning tape to clean video head.
Jan 28, 2009 | Sony Handycam DCR-TRV140E Digital...
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
May 09, 2017 | Sony Handycam DCR-HC14E Mini DV Digital...
Panasonic NV-GS60 with horizontal lines appear on screen
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
vac8
Dec 26, 2008 | Panasonic PV-GS39 Mini DV Digital...
Blue Horizontal Lines
if you dont have time to get it fixed, tap on the side where the tape goes in. I had to tap it a couple of times before everything started work fine again.
May 06, 2008 | Panasonic Palmcorder PV-GS15 Mini DV...
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
Panasonic PV-GS19 Mini DV Digital Camcorder Logo
667 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
