Question about Husqvarna Garden
What is he air fuel mixture setting on husqvarna 25r
3 Suggested Answers
  • 52 Answers
SOURCE: air fuel mixture setting for Ryobi 31cc engine
Make sure your lines have been hooked up correctly. Take a look at the sketch and see if yours looks like this. d0e1722.jpg
Posted on Apr 29, 2010
rycgl
  • 1545 Answers
SOURCE: I need a operating manual for a Husqvarna 25r weed
This is the closest I could get to your exact model. There is a 250R on the site (which includes other models as well). This is the manual for a Husqvarna 26r.
http://lawnandgarden.manualsonline.com/manuals/mfg/husqvarna/26_r.html?idRes=12881032
Posted on Sep 10, 2011
Husqvarna 266se everything is brand new piston,rings cylinder carb coil muffler and it still won't start even checked the timing it is set right
did you replace the worn out seals on the crank shaft?
if not then the compression made when the piston comes down into the sump to push the mixture up in to the cylinder is lost and there is no air to compress for the next power stroke
when the piston goes back up , the low pressure in the sump sucks air past the worn seals and not an air/fuel mix
probably the reason that you thought that you had to replace the rings and piston in the first place
Feb 17, 2016 | Husqvarna Garden
What the proper carb settings for husqvarana 51
The initial fuel mixture settings are 1-1/2 turns from seated on each.
  1. Set at best mixture after running,
  2. Set Idle speed at 2500 rpm
  3. Then for best at full throttle and not exceed 12500 rpm.
  4. If the engine want to go above 12500 rpm enrich the high mixture a little to limit the speed.
Feb 14, 2015 | Husqvarna Chain Saw Handle Models 50 51...
Fuel mix
The oil ratio is 50:1
Here is the website: http://homeguides.sfgate.com/oil-fuel-mixture-farm-tough-husqvarna-chainsaw-83933.html What Is the Oil Fuel Mixture for Farm Tough Husqvarna Chainsaw
Aug 19, 2014 | Husqvarna Chain Saw Handle Models 362 365...
Husqvarna 25r - is this a good model?
The 25R was a badged engineered machine ( not made by Husqvarna ) the first model was a Mitsubushi engine, the later version was a Mariama, both were good machines in there day, they were offered with a line head and a grass blade, they were as you can guess approximatly 25cc, the early version had points condensor ignition, and later on had electronic, parts are now becoming hard to get, so be aware.
May 14, 2013 | Garden
What is the fuel mixture for husqvarna n1485 chainsaw
Mixing ratio
1:50 (2%) with HUSQVARNA two-stroke oil.
1:33 (3%) with oils class JASO FB or ISO EGB formulated for
air-cooled, two-stroke engines
Feb 16, 2013 | Husqvarna Garden
Carburetor setting for Husqvarna 372xp chainsaw
The jet screws are fuel not air screws, the more they are unscrewd the richer the mixture becomes, basic settings are one and a quarter on the L screw and one turn on the H screw, you will have to fine tune from there, idle speed should be around 3000rpm, and max speed should not exceed 13000rpm, this should be set with a suitable engine tacho, when fine tuning always start with the L screw first, start gently screwing it in, the revs will start to increase as it leans off, when it starts to die because its too lean, unscrew until the revs pick up again, as you keep unscrewing you will hear the revs start to drop because it is becoming richer, leave it there, now blip the throttle, it should pick up instantly, if not turn the screw out a further 1/8 of a turn, the H screw is like a govener the more you screw it in the faster it revs, so do not exceed the 13000 rpm or this is a good chance it could seize, before any adjustments the fuel filter in the tank should be clean or replaced, the air filter should be cleaned and fresh fuel should be used.
Jul 03, 2012 | Husqvarna Garden
2008 Husqvarna SM 610 flat spot
Hi, Luka and the usual suspects are:
1. Installation of a different camshaft.
2. Different exhaust system or "STRAIGHT PIPES"
3. Faulty advance curve.
4. Multiple carburetors not in sync.
5. Improperly installed jet kit or wrong kit.
6. Carburetor internal malfunction.
7. Fuel mixture too rich.
8. Fuel mixture too lean.
9. Extremely dirty air filter.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Could use some help with carb issue 610
Husqvarna SM610 Suzuki DR Z400SM Aprilia Pegaso Strada 650
2006 2010 Husqvarna SM610 SM610I TE610 TE610I Workshop Repair Service... $15
Husqvarna Motorcycle Parts Fiche Husky Part Numbers
Husqvarna TE 610E Owner Manual
Oct 09, 2017 | 2008 Husqvarna SM 610
What are mixture screw settings,wind n and how many quarter turns out?
Mot Husqvarnas will run on a basic setting of one turn out on the H screw, and one and a quarter on the L screw, you will have to fine tune from there, they are both fuel not air screws, so the more you unscrew them the richer the mixture becomes.
May 14, 2011 | Husqvarna Garden
What is fuel air mixture screw settings on husqvarna 371k
I will admit that I am not particularly familiar with this manufacturers specific models, but I will state that for most small 2 stoke motors I seem to find that 1.5 turns out seems to be a great place to start for both the high and low speed mixture screws. From there it is all fine tuning to get the most out of the engine while still keeping it rich enough to prevent damage.
May 06, 2009 | Husqvarna Garden
Saw will not start Husqvarna 350
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Dec 04, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
242 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
