The speed i get through this modem from aol is diabolical only 0.44 can you please help me the modem number st586vb peterlane06@aol.com
    Scholar:
  • 40 Answers
The problem is not your modem.
The problem is your internet provider connection.
However, if you refuse to take my council you can call AOL as a paying customer and ask for help tweaking your settings which they will help your for free.
After you have spent hours on the phone to no good result, you will change internet service providers *S*
Thank you and good luck.
Posted on Oct 27, 2008
Modem Casn't Get A dile tone
If you are sure your modem drivers are installed (no YELLOW QUESTION MARKS when you access the device manager), try this;
My Computer/Right Click/Properties/Left Click/click Hardware tab/click Device Manager Tab/click Modem/go to properties/click TEST MODEM---this procedure should tell you that the modem PASSED or FAILED.
If the modem FAILED, it is defective and will need to be replaced.
Apr 11, 2009 | HP Pavilion N5250 (F2362M) PC Notebook
I HVE A GATEWAY 1100, IT ONLY RUNS AT 26.6 KBPS. ITS SPOSE TO RUN 49. AOL SAID TO CONTACT YOU BECAUSE IT IS THE MODEM. WE WENT THRU BUFFERS, MODEM, PORTS, ETC, AND STILL 26.6. CAN YOU PLEASE GET ME UP TO...
Call your phone company and tell them that while you are talking on the phone, every once in a while, you notice there is noise. Tell them sometimes the noise gets really bad and it is difficult to hear the person on the other end, but other times it is not even noticeable. They will check the line and maybe change out a segment of cabling, hopefully giving you a better connection.
Modems are twitchy. They can show problems with the line before you actually would notice noise. A small 'white lie' may help the TelCo get things running the way they should be.
Hope this helps.
Sep 26, 2008 | Gateway Computers & Internet
Internet connection for vista
unfortunately, there is nothing that you can copy and transfer from your XP based desktop. The best solution is to call your provider and ask them for a Vista driver update for your usb modem.
Hope this helps.
Apr 11, 2008 | Computers & Internet
Belkin G+ MIMO Modem Router
unistall AOL, clean out temp files, clear history, go to control panel, internet options, Connections tab, remove anything in the dial up and virtual private networks....should be good to go.
Let me know.
Nov 11, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
CAN'T GET AOL DIAL UP CONNECTION TO WORK
This error message normally happens because of a corrupted driver. Reinstall the driver for your modem.If you do not have cd's that came with your computer go too acer's website to download here
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=4309542&CFTOKEN=82834010
Now if that is not the cas maybe you are incorrectly installing aol. Start up your aol. If it specifies broadband at login box change to dialup or go to setup and let aol automactically detect your modem. If problem still persists. Reinstall software when prompted make sure you select dialup. Now if you are using broadband and asking for dialup. Or go to the control panel and remove your modem driver, shut down and restart. It should put the modem back.  Any more questions post comment.
Hope this helps you
Oct 25, 2007 | Acer Aspire 3680 Laptop
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Belkins router not connecting to cable modem
You need to start from beginning. Clear all temp internet files and run this programme Start>Run ipconfig /flushdns and hit enter. Get into the routers settings(probably 192.168.2.1) and ensure in the Lan settings that 'DHCP Server' is on and wireless is enabled.(you might need to be connected by RJ45 lan cable first) If it's a 125mbps router change settings to 54mbps to try that speed first(especially as your wireless cards will be 54 mbps) look in Mac address Filtering is off. Look in the DHCP Client list and see if your pc's were allocated ip addresses, if so it should allow an internet connection. Go to both your pc's wireless cards properties and under TCP/IP properties ensure obtain ip address automatically is checked. Restart both pc's and the router, disconnect cable and try wirelessly
Mar 07, 2007 | Belkin (F5D9230-4) Wireless Router...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
