Question about Toshiba TZ55V61 55" Rear Projection Television
TZ-55V61 Convergence There was an earlier posting regarding this, but the question wasn't clear, so I will restate. I am able to change/correct the convergence for the numbers 2,3,5,6,8,9. I cannot move the Blue cross to left for numbers 1,4,7. It can move up and down and to the right slightly. From what I've gathered It seems that I need to replace the IC's. Please confirm. and could you restate the location of the convergence IC's I am ordering a manual, but the sooner I can get this done the better of course. Thanks in advance/ danoii
  • Danny Abrams II Oct 23, 2007
    I have not replaced them yet. I know the IC's are stk, but I'm not sure of the part number. If you have that information, and can somehow illustrate which ones they are, that would be great. Thanks in advance.
    Dano
  • ciani Mar 01, 2009
    1,4,and 7 blue are way out of wack.......what are ICs ? Is it a DIY fix?
Cross' on convergence are not straight lines up and down, left to right. Only on numbers 1,3,7,9
Posted on Oct 05, 2009
I had the same problem but replaced my IC's and now the #1 red looks like it jumped out of line and is higher than the green/blue cross. i can move the red up down left right but not low enough to match up with the other 2?
lay out
1 2 3
4 + 6
7 8 9
Posted on Nov 22, 2008
    Genius:
  • 1,694 Answers
Do you still need assistance?? The convergence IC's are always
on the largest heatsinks in set......have you replaced??....T.
Posted on Oct 23, 2007
  • Vista Electronics Oct 23, 2007
    Did you get the manual??
    part # is Stk392-110 x 2
    IC's are large & mounted to large heat sinks for cooling......T.
SOURCE:
How do you delete/edit a comment/question on Fixya.com?
Currently you cannot edit a problem or comment. Usually what I do is if I make a mistake I just add an additional comment with the information corrected.
Hope that helps!
Aug 24, 2013 | FixYa Computers & Internet
Display looks like you need 3D glasses to view.
Sounds like a convergence problem. Especially since you said that the screen(picture)wasn`t linear anymore.
If the magic/touch focus function doesn`t clear the problem then your convergence modules may be faulty. They are used to align the three tubes (red/green/blue) deflection. If you feel handy with a soldering iron i could assist you in replacing them, otherwise you might need the help of a local repair tech. Hope this help. Good luck
Dec 01, 2009 | Televison & Video
Convergence
Your set has a convergence problem which is a common issue.
Take a look at this solution posted earlier on Fixya. It worked for me.
http://www.fixya.com/support/t2703612-double_red_image
Aug 22, 2009 | Televison & Video
Green and red outline on images but looks clear
Most of the time you can just correct the convergence through the television menu. All that needs to be done is line up the blue and red to the green. If the colors do not move then there may be faulty components in the convergence circuit.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 21, 2009 | Televison & Video
Toshiba 42wh46p convergence problem
Yes Replace Both STKs also CK all low ohm resistors.
Feb 15, 2009 | Toshiba 50H82 50" Rear Projection...
Hitachi 53UWX10B
Good Day, Armenian;
You may have CRT Coolant on one the boards. LOOK very closely for shiny spot on any of the boards. WHY? Because you are saying the TV is having multiple problems. Let me know.
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 53UWX10B 53" Rear Projection...
My Hitachi projection TV needs convergence amps. what are convergence amps?
The convergence amps are usually located on the extreme right side of the chassis looking in from the rear of the set. Located on a large heat sink. If you respond to this post with your correct model number I will post the correct ICs for your model, and you will need to replace the six convergence resistors as well.
Jul 13, 2008 | Televison & Video
Double image, blue and yellow images
convergence ic are going or have loose connection in the convergence amp ic area.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 15, 2008 | Hitachi 43FDX01B TV
Help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
Nov 21, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Red Shadow on scheen
your tv needs to be align take it to a tech so that the tv can get a convergence adjustment it is call color bleeding.these things when a set gets old this wil cost between 440.00 TO $75.00,in this the comb filter and the screen voltage will be checked.
Mar 29, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Open Questions:
Toshiba TZ55V61 55" Rear Projection Television Logo
215 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
