Question about RCA F32650 32" TV
No channel line up in guide plus
No channel lineup received inquideplus. have tried the 99999, resetting
  • 2 more comments
  • Anonymous Nov 08, 2008
    no listing on my guide plus
    my guide plus is not working either
  • Anonymous Nov 10, 2008
    worked fine until this weekend, then no new download
  • llmann445 Jan 24, 2009
    On screen programming suddenly came back after January 1 2008. I did find I had to leave it on a different channel (public) as the cable channel seems to have SAP and does not let the lineup load. Once in a while the sound disappears, the TV has to be unplugged to regain the sound and the channel line up disappears until it can be loaded again. It is weird.
Tune your TV to a Public Broadcasting Station before turning it off for the night. You should receive your line-up.
Posted on Jan 18, 2009
Try read the tv manuel or call rca.
Posted on Nov 18, 2008
Panasonic tv model TC-L55ET5 lost 3 digital channels with last update
Those particular digital channels may have been eliminated. The channel lineup changes periodically.
Nov 20, 2016 | Panasonic 55" L55ET5 Viera 3D Full HD...
Failed to receive broadcast e202
The 202 error is usually associated with a bad cable card. In your case, you need to check and see if you have one.
Did you run the Autoprogramming required to load and store the Channels?
If you are attempting to Add digital cable to your TV lineup, you must do that.
And one note -- the digital stations on your TV set will not match the lineup on the Cable box. The box was designed to line up the TV stations according to the guide, but it uses proprietary programming software and hardware to do that.
TV's cannot use the software. so you end up with the low to high frequency channels in your lineup, but it's not similar to the cable channel's lineup.
Try finding USA or TNT lickety-split....you won't.
After doing the full autoprogramming, let me know if you get only the Analog Channels from your Cable provider, or if you get NO channels locking in at all. Either one will likely require replacing the Digital tuner module.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 18, 2011 | Sharp Televison & Video
I have been receiving Guide Plus for the past 5 years, recently it does not work. I get the message, "No channel lineup has been recieved". I have tried to setup several times and all I get is the "no...
Hello. Unplug your set from the wall for two full minutes and then plug it back in and try it again. This will reset it. If that does not do it, call your service provider. J.
Sep 23, 2010 | RCA Televison & Video
Channel wont change. the numbers change but the picture remains the same. always on channel 3. help
Look to see if "GUIDE PLUS" logo is on front of set, if so it is your problem.
Go into customer menu and setup for Guide Plus and enter area code 99999 and when it asks if you have cable box or vcr answer/select NO, the guide plus is your problem.
Try and if this resolved your problem rate this solution as VERY HELPFUL as I do this here for free.
SD TECH
Sep 21, 2010 | RCA P52926 52" Rear Projection Television
I have upgraded my comcast service to an extended version including more channels but no cable box. I've been unable to set up my TIVO dual Series device to get the new channels, it only recognizes the...
Try this first...Press the TiVo button at the top center of the Remote, then > Messages & Settings > Restart or Reset System > Repeat Guided Setup and then follow the onscreen instructions from there.
This should load your new channel lineup into your TiVo.
If all the channels are still not recognized... Press the TiVo button at the top center of the remote, then > Messages & Settings > Settings > Channels > Channel List and then make sure all of the channels you receive are checked.
Jun 08, 2009 | Tivo Series2 Dual Tuner Digital Video...
Have Warning message on DVD 'Your Guide Plus has not received TV Listings. Check your host channel.' What do I do?
Symptoms / Customer Description
TV Guide issues.
Example:
1. Not getting the correct info, or no information.
2. TV Guide giving double channels.
3. TV Guide grid comes up but no information.
[Primary Symptom Code: 118X ]
Solution
TV Guide information comes from the Host Station.
1. If no information on some channels or incorrect information not TV issue, but station not giving any information or incorrect information.
2. If grid comes up, but no TV Guide Info could be
siginal issue.
3. Double stations showing up. Unfortunately double listing is the way it's going to be. They have to send out all possible OTA listings for the area. You can hide the channels that you are not getting.
For these type of issues
Please have the customer call our Customer Support Line 800-222-7669
Our Call Center Rep. will fill out an investigation form with data pulled from the TV. These reports will be sent to Gem Star for their investigation, and the Call Center will get
back to the customer.
Apr 14, 2009 | Televison & Video
Guide Plus
Called the cable company..they said they don't block the signal. sooooo..
first..i unplugged the tv from the power source, and unplugged the cable from the wall. left both off for an hour, and reconnected power and cable.
entered the guide set up...changed the zip code from the area where i actually live to the zip code of the cable provider for my area. here on maui, there is only one provider.
used the editor in guide plus to turn on and off the channel line-up according to the published channels listed in my area tv guide.
24 hours later...voila..!! it WORKS..!! good luck..!!
Oct 16, 2008 | RCA G36705 36" TV
Change channel lineup
1.) Press the TiVo button on the remote (at the top)
2.) Scroll down to "Messages & Settings" and press 'Select' on remote
3.) Scroll down to "Settings" and press 'Select'
4.) Scroll down to "Channels" and press 'Select'
5.) Press 'Select' on "Channel List"
6.) Pressing the "ENTER" button on remote will let you change Channel Line-Up
Aug 28, 2008 | Tivo Series2 TCD649080 Video Recorder
Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Dec 08, 2007 | Panasonic DMR-E85H DVD Recorder
Guide plus+ gold
use the editor in the guide to turn off and on and correct channel numbers. that should do it..!!
Apr 13, 2007 | RCA G36705 36" TV
RCA F32650 32" TV Logo
117 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
