Question about Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome...
I want to clean the diverter mechanism, but after removing the dome cover, the spout assemly is stuck.
2 Suggested Answers
  • 297 Answers
SOURCE: Tub shower diverter stem on tub spout broke and
you must replace the whole stem.you can get it at homedepot. first take the cover off over the stem. this should screw off or is held on with a allen key.then unscrew stem from valve body.make sure water is off to tub,just in case.
Posted on Jul 15, 2009
Tub spout diverter
Check the basement. There may be a valve (two valves) that someone partially closed in the past to limit how much water was used for a bath.
Dec 21, 2013 | Plumbing
Can I clean tub spout diverter, does it unscrew so I can clean aerator?
Even if you unscrew your diverter, there isn't anything you can do to make it perform any better. It's best to replace your tub spout/diverter combo. I imagine your getting water out of the spout when in shower mode......they do wear out when used a lot. If you decide to change your spout, write back and I can guide you through the process of ID and removal/replacement procedure. But if your not a pretty good handy person, call your plumber to do it 4 u. He would appreciate your business. Good luck with your problem and always know where and how to turn your house water supply off before attempting a plumbing repair. :-)
Jan 28, 2013 | Delta Faucet Delta RP17453 Pull-Down...
I have a tub spout that is stuck. My wife and I want to tile the walls around a tub, and I need to first remove the American Standard T6179/80/81 spout (with diverter) above it, but I can't get it to...
Tub spout threads onto end of pipe. The diverter does not play a role.
Sometimes these things get rusted in place, and you have to bend them getting it off.
When all else fails, get a big pipe wrench and muscle it until it bends up and comes off.
Sounds like you might need a new tub spout ... and might need a new pipe ... be sure to match length of pipe to depth of threads on new spout.
Photos from google-image search for "tub spout removal tool"
http://www.justingermino.com/replacing-bath-tub-spout/
Nov 27, 2010 | American Standard Plumbing
I have a garden tub w/o a shower attached. However, the fixture in the tub is the Delta pull down diverter (dont know why they would put that in a tub w/o a shower). Anyway, the diverter was pulled down...
If it was me... I would replace that spout...
the spout either is threaded on or it has a set screw on the bottom at the back that you loosen and then pull the spout off by pulling straight away from the wall...
Check and see if the spout has the hole for the set screw...if not then twist it counter clockwise and it will turn off...
then repalce the spout with a new one with out the diverter...
heatman101
Aug 05, 2010 | Delta Faucet Delta RP17453 Pull-Down...
Moen shower valves are failing
the diverter is stuck. you have to move it up and down to free it up. the diverter is the mechanism attached to the tub spout that switches the water from shower to tub. you may also need a new diverter if fiddling with it doesn't work.
Jan 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Delta diverted spout is stuck! Can't pull it down
You probably have lime deposits built up which won't allow you to pull it down anymore. Try spraying lime away on it and use an onld toothbrush and work it up in there. If this doesn't work, you can replace the spout with a generic one. The spout should just twist off. Sometimes they can be stubborn. Hopefully this helps.
Apr 03, 2009 | Delta Faucet #RP320 Divert Assembly
Diverter Tub Spout stuck
Its probably just stuck on some lime and mineral deposits. You can try and spray some lime away on it and then try to loosen it. Or you can unscrew the whole spout so you can soak it. If that doesn't work, you can either contact Delta for an exact replacement or you can purchase a generic one.
Apr 01, 2009 | Delta Faucet Delta RP17453 Pull-Down...
Ghroe Seabury 25502 roman tub filler leaking at liftrod control
It can be repaired.
You can see an exploded diagram here
I can post more if you need more specific instructions.
Nov 22, 2008 | Grohe 19.045.000 Seabury Thermostatic...
Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome... Logo
41 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
