Question about Microsoft Zune JS8-00001 Digital Media Player
Zune Lock up
I was using my Zune and out of no where it locked up. Eventually it shut off but now it will not turn on. When I attached it to the computer, it still won't do anything. The battery was completely charged. HELP!!!!
  • Anonymous Oct 27, 2008
    we need a new firmware that's not shite!
    Problem Solver:
  • 9 Answers
Read what happened to mine when it stayed locked all the time.
Maybe it will help
http://www.fixya.com/support/t1371647-unlock_zune
Posted on Dec 15, 2008
  • 3 Answers
This happened to me today actually, all you have to do is hold down the back button and up on the pad and it will reset. =]
Posted on Oct 29, 2008
Open up the case... unplug the battery and put it back.... it will reboot and off you go!!
Posted on Dec 31, 2008
  • Tia Stewart
    Tia Stewart Oct 30, 2013
    how do you open up the case.?
120 Gig Zune Locked Up -Won't Unlock
One other option you may not know of is to hold the down button, and the back button at the same time. This will send the Zune into a deeper "off" state, and may reset your lock command.
If NO other options are working, you should probably try a "hard reset".
This means you will have to open the Zune itself up (you can find simple instructions for this fairly easily online) and pull a small plug out that connects the battery to the Zune itself. Don't worry, your music wont be deleted.
Jun 23, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune doesn't turn on
the electricity power of the car watts its much higer the zune may have over heated the internal plastic pads send it to a expert to examine it
May 16, 2009 | Microsoft Zune 8 MP3 Player
Zune 30 gb broken "lock" button
The Lock button came right out and the wires attached to it broke, right? If so, y'alls pfft.
or, if not...
Go to this website and follow Steps 1 thru 4 ONLY. Picture 4 of Step 4 shows the top of the device to the left and the headphone jack nearest you. The Lock button should be right below the top arrow on the left of Picture 4. To unlock it, slide the switch **away** from the headphone jack.
!!! Please note that this is all strictly assumptions on my part. I have *never* taken my 30gig apart and am strictly working from the pics & past experience w/ micro-electronics. Do Not Take My Words As Being Absolutely Correct !!!
Mar 07, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune lock
If you forget the code, you must erase the device. The Zune device automatically prompts you to erase the data after you enter the incorrect code three times in a row.
To change or disable the screen lock, follow these steps:
  1. On the home screen of your Zune device, select Settings, and then press the center of the Zune pad.
  2. Select Screen Lock, and then press the center of the Zune pad.
  3. Select Disable Screen Lock or Change Lock Code, and then press the center of the Zune pad.
  4. Enter your code to continue, and then follow the prompts on screen.
thanks to our buddies over at microsoft.
Jan 04, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune lock
Zune lock is the switch at the top of the zune correct? Slide it into unlock position.
If it's passworded and you can't get it unlocked
try this:
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
If this helps Rate this a FIX-YA.
Jan 04, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Rene
Make sure hold/lock is not engaged first
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jun 30, 2008 | Microsoft Zune JS8-00001 Digital Media...
Put Zune in pocket, it comes on
Well if you set the lock slider on the top of the player to lock this will disable the player from turning on in your pocket.
Jun 21, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune installation
shens - you must have an internet connection; also, make sure the lock is disengaged and that your computer has a compatible operating system
star - Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Wizard.
for more help, go to:
http://www.zune.net/en-us/support/usersguide/default.htm
Jun 15, 2008 | Microsoft Zune JS8-00001 Digital Media...
30gb zune install
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 21, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
830 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
