Question about Sherwood RX-4109
5 digit code for Sherwood RX-4104 for U-verse remote
SOURCE: need remote code for sherwood
Comcast came and the receiver / tv was not capable of being run by another remote as far as volume, just off and on
Posted on Jul 21, 2008
greenspan
  • 1734 Answers
SOURCE: looking for remote code for sherwood rx4105 to work with comcast
Ask the remote code experts -
They will get it for you.
http://manualfox.com
Posted on Jun 30, 2009
  • 231 Answers
SOURCE: can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Posted on Jul 30, 2009
  • 30 Answers
SOURCE: trying to program my At&t Uverse remote to my
Sherwood Receiver/Amplifier 5027 Sherwood Receiver/Amplifier 5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
  1. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  2. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  3. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
    1. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    2. The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
    1. Point the remote control at the programmed device and press the Power key once.
    2. The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
    1. Repeat steps 1 through 7 to program other devices if needed.
    2. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Posted on Sep 20, 2009
    danbusa
    • 185 Answers
    SOURCE: I need a code to
    Hello! Try the link below this should help:
    http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
    Daniel Busa
    DISH Network Customer Service
    Posted on Jan 25, 2011
    I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
    You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
    Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
    Does the sherwood rx 4105 receiver have analog or digital inputs
    Unfortunately the RX-4105 is a stereo only receiver with only analog L/R inputs. You will have to find a stereo output & go in through one of the stereo inputs.
    Feb 12, 2013 | Sherwood RX-4105 Receiver
    My dish network remote control will not control a sherwood rx-4109 am/fm stere rec.
    Try these codes: 670,646 The steps for programming these remotes are below:
    1.) Hold down the aux button until all four mode buttons are lit.
    2.) Enter the three digit code and press pound (#)
    If those codes fail try the steps below they are for what is called a Power Scan. This should resolve this unless there is a compatibility issue.
    1.) With the desired equipment on, press and hold the correct AUX button until all mode button backlights illuminate (about 3 seconds), then release.
    2.) press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
    3.) Press and release the large red Power button.
    4.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
    Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
    To verify the code works try several different functions for that equipment.
    Daniel Busa
    Feb 22, 2011 | Sherwood RX-4109
    I have a sherwood rc-107 and can't find the code for my grey comcast remote.
    Hi John,
    You may view the manual and code of your remote control, click this link http://www.comcast.com/corporate/customers/customer_support/remotes.html.
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya.
    Feb 19, 2011 | Sherwood RX-4103 Receiver
    I need a code to allow me to use my Dish Network remote to operate my Sherwood RX-4109 receiver.
    Daniel Busa
    Jan 23, 2011 | Sherwood RX-4100 2 Channels Receiver
    Trying to program my At&t Uverse remote to my
    Power on the device
    Sep 05, 2009 | Sherwood RX-4109
    Sherwood rd7103 rec.
    no listing for Sherwood receiver. must do the remote "search" function. here is how:
    1. Turn on your TV.
    2. On the remote control, press TV once.
    3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
    4. Using the number pad, enter 9-9-1. The TV key will blink twice.
    5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
    6. Press the SETUP key once to lock in the code. The TV key will blink twice.
    Hope that helps!
    Feb 28, 2009 | Sherwood RX-4103 Receiver
    Need remote code for sherwood rx-4109
    Jul 20, 2008 | Sherwood Audio Players & Recorders
    Sherwood RX-4109 Logo
    Top Sherwood Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Josh Whitehead
    Josh Whitehead
    Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
