Question about Interex Serial adapter
Interex serial adapter- dip switch settings for Apple G3
I have a GEM 17" monitor hooked up to an Apple Blue and White G3 using and Interex Serial adapter with 10 dip switches on it. In a recent move to another dwelling, the dip switch settings were moved and the monitor will not work now. I need to know the switch settings for this adapter. The 800 number on the switch no longer works. It is 800-513-9744. One one side of the switch that plugs into the Mac is 1a 5 pin female in two rows. The other end of the adapter has 15 pin male in three rows (smaller end that the monitor cable connects to).Is there a way I can find out these settings?
  • normjr Jan 21, 2008
I've been looking for this as well for a looooooong time. just ran across the settings in a old mail BB. link below
http://www.mail-archive.com/g-list@mail.maclaunch.com/msg20641.html
Posted on Oct 18, 2007
    Scholar:
  • 47 Answers
I couldn't find the exact Interex unit info, but cables are all standardized... so try this: http://www.belkin.com/support/download/files/F3H1381revised.pdf
Posted on Sep 13, 2007
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
Apr 13, 2012 | HP vs15 15"LCD Flat Panel Monitor
My zebra 105 se wont print using RS232 serial cable
Make sure the serial dip switch settings match your com port on the computer. You need a null modem cable or adapter.
Mar 04, 2011 | Zebra 105Se Thermal Printer
Need code for interex adapter please help Tomas t.matos2@hotmail.com
MONITOR RESOLUTION SETTING
12" RGB 512x348 13467
13" RGB 640x480 66Hz 1467
PORTRAIT 640x870 23467
VGA/SVGA 640x480/800x600 60 Hz 2367
15" TILT N/A 2467
16" COLOR 832x624 1367
19" COLOR 1024x768 1267
21" COLOR 1152x870 123467
2 PG MONO 1152x870 3467
NTSC N/A 12467
NTSC/PAL N/A 12367
HI-RES 12-14" up to 640x480 1467
MULTI SCAN 14" up to 832x624 146789
MULTI SCAN 16" up to 1024x768 14679
MULTI SCAN 21" up to 1280x1024 14678
Jan 07, 2011 | Interex Serial adapter
I am trying to hook up my monator to the computer(cpu) and only nave one wire to it. I think there should have 2. I was looking for a hookup diagram. Can't find one HELP
There should be two cables coming from your monitor -- one that hooks up to the computer and one that goes to the outlet, for power. The outlet cable looks almost like a normal power cable, with three prongs on one end and three holes on the other end.
The cable that hooks to your computer is likely a serial cable, with a blue connector that hooks up to the blue port on the back of your PC. Instead of the serial connector, you might have a DVI connector, which is skinnier and should have a removable white cap on it. If your computer has a DVI port, than you can use the DVI cable, otherwise you'll have to use the serial cable (with the blue connector).
Hope that helps.
Jul 14, 2010 | Dell Dimension 8200 PC Desktop
PowerMac G3 connections and compatibility
You need a adapter from your serial port to usb/also yu need to update your os to 10.2 or 3
Dec 01, 2008 | Apple iMac G3 Desktop
LCD Problem
hook up the ibook to a external monitor, via the monitor cable, if it comes up, you know its not your motherboard. There should be a monitor icon on your keyboard to switch from laptop monitor to external monitor, it could have been pressed by accident.
Jul 16, 2008 | Apple Computers & Internet
Interex Serial Monitor adaptor
I have the same problem. Did you get an answer?
adtrafiic@comcast.net
I need the code too.
Mar 25, 2008 | Interex Serial adapter
OKI ML280 serial card installation
I believe on the top of the printer towards the back is a panel with a single screw. Under here are dip switches to set the printer.
Jun 18, 2006 | OKI (09002353) Serial Adapter
Interex Serial adapter Logo
433 people viewed this question
Top Interex Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Interex Computer and Internet Expert? Answer questions, earn points and help others
