Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Syncmaster 913v I have just unboxed a syncmaster 913v. It would not display from my laptop so I connected a VGA/SVGA test pattern generator. nothing!!!! When I disconect the VGA lead, Check signal appears. I once had a "Not Optimum Mode","Recommanded Mode 1280 x 1024 60Hz"  appear but can not make this happen again. the Screen is ok and the green led seems to stay  on once a signal is detected but no image!!! Is there a common component fault I am looking for?
  • 2 more comments
  • Chips Block Nov 12, 2008
    Same problem. The monitor was purchased in Sept. 2005 and used for a year. Then sat in a box in my basement for a year and now there's no image at all when it's powered on. I've tried resetting the resolution to 1280x1024 and Hz to 60 with no luck. Reinstalled an updated driver. Contacted Samsung's contract repair facility and the person I spoke with said it sounds like the main board may be shot. Don't know how he could detect that over the phone, but I may give it a try, since I have a fairly new monitor that doesn't work. Seems a shame to lob it to the wind.
  • rolfmybes Dec 07, 2008
    Bei meinem Monitor habe ich das gleiche Problem ungeeigneter Modus 1280-1024 bei 60Hz und er läst sich nicht bedienen.Gelegentlich fähr er im Biosmodus mit hoch aber nur bis zum Windows start,dann ungeeigneter Modus.
  • Anonymous Mar 21, 2009
    Ecxactly the same scenario as Chips block!
  • Nerijus Mazuolis May 11, 2010
    hi
    I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
    if you are interested check it.
    Samsung monitor repair manual guide 710n,913v,510n more
    or just enter number in search field: 220409788372
    thank you
    Scholar:
  • 36 Answers
Hi
thank you
Posted on May 15, 2009
Samsung syncmaster 913v gives message ' not optimum mode"
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung lcd 913v self test ok, no image when vga connected
This problem often occurs in samsung SyncMaster LCD monitors.
The solution is open your look for the LCD monitor power supply module (which have PCB connector to the AC power), on that board look for capacitors, now look for broken one which upper part is bloated, like the image below:
If you find a damaged capacitor as in the picture then you should replace it with the same value.
Jan 22, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung monitor syncmaster 913v
Either you messed badly with the system color profile management, or, more likely, the VGA cable is faulty or improperly seated. Try unhooking the PC end of the cable (and, if you got yourself a model with removable cable, also the monitor end), and hook them back again, seating the connectors gently but firmly and tightening the connectors' retainer screws.
Aug 24, 2009 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung SyncMaster 913V it's displaying red lines
Sometimes this happens when the pins on the vga connector are bent. You can either try to straighten them (very carefully with tweezers) - be sure to check both ends, or try a new cable.
Apr 06, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 913v picture rotated 90 degrees
Please press Ctrl-Alt and your arrow keys until the image is straight!
Mar 10, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Syncmaster 913v color problem
Appears to be something in the connection. Check the video cable and pins on the video connector. Also verify the color settings have not been changed on the monitor. There should be an area where you change the RGB levels.
Feb 14, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
498 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
